AGX HDMI interface shows abnormal display after firmware update on 2K resolution monitor,After successful burning, HDMI does not display when it first starts up
The PINMUX pin configuration is as follows:
The burning configuration file in BSP is as follows:
PINMUX_CONFIG=“Orin-jetson_agx_orin-pinmux.dtsi”;
GPIO_CONFIG=“Orin-jetson_agx_orin-gpio-default.dtsi”;
PMC_CONFIG=“Orin-jetson_agx_orin-padvoltage-default.dtsi”;
OVERLAY_DTB_FILE+=“,tegra234-dcb-p3767-0000-hdmi.dtbo”;
DCE_OVERLAY_DTB_FILE=“tegra234-dcb-p3767-0000-hdmi.dtbo”;参考知识
57/1000
Use the command “sudo./flash. sh jetson agx orin devkit mmcblk0p1” to burn,After successful burning, the system automatically restarts and there is no display on HDMI. Use the debug serial port to check the terminal error. The complete error message is as follows:
▒▒I/TC: WARNING: Test UEFI variable auth key is being used !
I/TC: WARNING: UEFI variable protection is not fully enabled !
MmInstallProtocolInterface: 24E70042-D5C5-4260-8C39-0AD3AA32E93D 0
ESC to enter Setup.
F11 to enter Boot Manager Menu.
s to enter Shell.
Enter to continue boot.
▒▒MmInstallProtocolInterface: 7CE88FB3-4BD7-4679-87A8-A8D8DEE50D2B 0
▒▒L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel…
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Measured initrd data into PCR 9
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services…
▒▒MmInstallProtocolInterface: 27ABF055-B1B8-4C26-8048-748F37BAA2DF 0
▒▒[ 0.000000] Booting Linux on physical CPU 0x0000010000 [0x410fd421]
[ 0.000000] Linux version 6.8.12-1021-tegra (buildbrain@74e043fc-6c96-4a54-a660-50b30a72108d-97k4-j97dd) (aarch64-none-linux-gnu-gcc (crosstool-NG 1.26.0) 13.2.0, GNU ld (crosstool-NG 1.26.0) 2.40) #1 SMP PREEMPT Thu Aug 6 21:56:04 PDT 2026 ()
[ 0.000000] KASLR enabled
[ 0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.7 by EDK II
[ 0.000000] efi: RTPROP=0x81e4ae698 TPMFinalLog=0x819f50000 SMBIOS=0xffff0000 SMBIOS 3.0=0x81e0b0000 MEMATTR=0x8193ef018 ESRT=0x81898ab18 TPMEventLog=0x81895d018 INITRD=0x81895ff98 RNG=0x818958018 MEMRESERVE=0x81895fd18
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x000000081898ab18 to 0x000000081898ab50.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000803a00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x0000000803a00000..0x00000008139fffff (262144 KiB) map reusable linux,cma
[ 0.000000] OF: reserved mem: 0x0000000825cc0000..0x0000000825ebffff (2048 KiB) nomap non-reusable ramoops_carveout
[ 0.000000] OF: reserved mem: 0x0000000826980000..0x0000000826bfffff (2560 KiB) map non-reusable pva-carveout
[ 0.000000] OF: reserved mem: 0x0000000832e00000..0x0000000833dfffff (16384 KiB) nomap non-reusable fsi-carveout
[ 0.000000] OF: reserved mem: 0x0000000835e00000..0x000000083747ffff (23040 KiB) nomap non-reusable framebuffer@8,35E00000
[ 0.000000] OF: reserved mem: 0x0000000849800000..0x000000087fffffff (892928 KiB) nomap non-reusable vpr-carveout
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x000000083fffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x825b17b00-0x825b1afff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000083fffffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000081675ffff]
[ 0.000000] node 0: [mem 0x0000000816760000-0x000000081887ffff]
[ 0.000000] node 0: [mem 0x0000000818880000-0x0000000818a6ffff]
[ 0.000000] node 0: [mem 0x0000000818a70000-0x0000000818a7ffff]
[ 0.000000] node 0: [mem 0x0000000818a80000-0x0000000819f4ffff]
[ 0.000000] node 0: [mem 0x0000000819f50000-0x0000000819f5ffff]
[ 0.000000] node 0: [mem 0x0000000819f60000-0x000000081c56ffff]
[ 0.000000] node 0: [mem 0x000000081c570000-0x000000081e4affff] t23x_general System firmware
[ 0.000000] node 0: [mem 0x000000081e4b0000-0x00000008219fffff] version 39.2.1-gcid-46758480
[ 0.000000] node 0: [mem 0x0000000821a00000-0x0000000821bfffff] date 2026-08-07T04:48:32+00:00
[ 0.000000] node 0: [mem 0x0000000821c00000-0x0000000825c6ffff]
[ 0.000000] node 0: [mem 0x000000083c000000-0x000000083fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000083fffffff]
[ 0.000000] On node 0, zone Normal: 25488 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.5
[ 0.000000] percpu: Embedded 31 pages/cpu s89256 r8192 d29528 u126976
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected QARMA5 algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 video=efifb:off console=tty0 efi_pstore.pstore_disable=1 pstore.backend=ramoops efi=runtime nvme.use_threaded_interrupts=1 swiotlb=2048 pci=pcie_bus_perf bl_prof_dataptr=2031616@0x821A10000 bl_prof_ro_ptr=65536@0x821A00000
[ 0.000000] Unknown kernel command line parameters “bl_prof_dataptr=2031616@0x821A10000 bl_prof_ro_ptr=65536@0x821A00000”, will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7908464
[ 0.000000] Policy zone: Normal
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 8.
[ 0.000000] software IO TLB: mapped [mem 0x00000000ffbe0000-0x00000000fffe0000] (4MB)
[ 0.000000] Memory: 31122024K/32141760K available (21248K kernel code, 5878K rwdata, 13332K rodata, 11584K init, 640K bss, 757592K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[ 0.000000] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000000] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000354] Console: colour dummy device 80x25
[ 0.000360] printk: legacy console [tty0] enabled
[ 0.000534] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000541] pid_max: default: 32768 minimum: 301
[ 0.000583] LSM: initializing lsm=capability,landlock,yama,apparmor,integrity
[ 0.000595] landlock: Up and running.
[ 0.000597] Yama: becoming mindful.
[ 0.000626] AppArmor: AppArmor initialized
[ 0.000677] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000703] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001553] rcu: Hierarchical SRCU implementation.
[ 0.001561] rcu: Max phase no-delay instances is 1000.
[ 0.002990] Tegra Revision: A01 SKU: 210 CPU Process: 0 SoC Process: 0
[ 0.004202] Remapping and enabling EFI services.
[ 0.004805] smp: Bringing up secondary CPUs …
[ 0.005074] Detected PIPT I-cache on CPU1
[ 0.005110] GICv3: CPU1: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.005126] CPU1: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.005383] Detected PIPT I-cache on CPU2
[ 0.005404] GICv3: CPU2: found redistributor 10200 region 0:0x000000000f500000
[ 0.005414] CPU2: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.005650] Detected PIPT I-cache on CPU3
[ 0.005669] GICv3: CPU3: found redistributor 10300 region 0:0x000000000f520000
[ 0.005677] CPU3: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.007796] Detected PIPT I-cache on CPU4
[ 0.007833] GICv3: CPU4: found redistributor 20000 region 0:0x000000000f540000
[ 0.007848] CPU4: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.008108] Detected PIPT I-cache on CPU5
[ 0.008129] GICv3: CPU5: found redistributor 20100 region 0:0x000000000f560000
[ 0.008139] CPU5: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.008376] Detected PIPT I-cache on CPU6
[ 0.008397] GICv3: CPU6: found redistributor 20200 region 0:0x000000000f580000
[ 0.008406] CPU6: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.008661] Detected PIPT I-cache on CPU7
[ 0.008682] GICv3: CPU7: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.008691] CPU7: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.008728] smp: Brought up 1 node, 8 CPUs
[ 0.008761] SMP: Total of 8 processors activated.
[ 0.008763] CPU: All CPU(s) started at EL2
[ 0.008766] CPU features: detected: 32-bit EL0 Support
[ 0.008768] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.008772] CPU features: detected: Common not Private translations
[ 0.008774] CPU features: detected: CRC32 instructions
[ 0.008776] CPU features: detected: Data cache clean to Point of Persistence
[ 0.008780] CPU features: detected: Generic authentication (architected QARMA5 algorithm)
[ 0.008782] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.008785] CPU features: detected: LSE atomic instructions
[ 0.008788] CPU features: detected: Privileged Access Never
[ 0.008790] CPU features: detected: RAS Extension Support
[ 0.008792] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.008826] alternatives: applying system-wide alternatives
[ 0.011435] CPU features: detected: Hardware dirty bit management on CPU0-7
[ 0.012163] devtmpfs: initialized
[ 0.020525] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.020536] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.021863] pinctrl core: initialized pinctrl subsystem
[ 0.023037] SMBIOS 3.6.0 present.
[ 0.023045] DMI: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 39.2.1-gcid-46758480 08/07/2026
[ 0.023289] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.023810] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.023941] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.024072] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.024088] audit: initializing netlink subsys (disabled)
[ 0.024137] audit: type=2000 audit(0.024:1): state=initialized audit_enabled=0 res=1
[ 0.024833] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.024836] thermal_sys: Registered thermal governor ‘user_space’
[ 0.024840] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.024861] cpuidle: using governor menu
[ 0.024970] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.025022] ASID allocator initialised with 32768 entries
[ 0.025872] Serial: AMBA PL011 UART driver
[ 0.030611] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/processing-engine@2908000
[ 0.030622] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/asrc@2910000
[ 0.030629] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amixer@290bb00
[ 0.030634] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903b00
[ 0.030640] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903a00
[ 0.030645] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903900
[ 0.030650] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903800
[ 0.030655] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903300
[ 0.030660] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903200
[ 0.030665] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903100
[ 0.030670] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903000
[ 0.030675] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/mvc@290a200
[ 0.030679] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/mvc@290a000
[ 0.030684] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902600
[ 0.030689] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902400
[ 0.030694] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902200
[ 0.030699] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902000
[ 0.030704] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/dmic@2904200
[ 0.030709] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901500
[ 0.030714] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901300
[ 0.030719] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901100
[ 0.030724] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000
[ 0.030729] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/admaif@290f000
[ 0.030735] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000: Fixed dependency cycle(s) with /bus@0/i2c@31e0000/audio-codec@1c
[ 0.030744] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030754] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901100: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030764] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901300: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030775] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901500: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030785] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030795] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030804] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902400: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030814] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902600: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030824] /bus@0/aconnect@2900000/ahub@2900800/amx@2903000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030834] /bus@0/aconnect@2900000/ahub@2900800/amx@2903100: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030844] /bus@0/aconnect@2900000/ahub@2900800/amx@2903200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030854] /bus@0/aconnect@2900000/ahub@2900800/amx@2903300: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030865] /bus@0/aconnect@2900000/ahub@2900800/adx@2903800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030875] /bus@0/aconnect@2900000/ahub@2900800/adx@2903900: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030885] /bus@0/aconnect@2900000/ahub@2900800/adx@2903a00: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030895] /bus@0/aconnect@2900000/ahub@2900800/adx@2903b00: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030906] /bus@0/aconnect@2900000/ahub@2900800/dmic@2904200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030916] /bus@0/aconnect@2900000/ahub@2900800/processing-engine@2908000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030926] /bus@0/aconnect@2900000/ahub@2900800/mvc@290a000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030935] /bus@0/aconnect@2900000/ahub@2900800/mvc@290a200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030945] /bus@0/aconnect@2900000/ahub@2900800/amixer@290bb00: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030957] /bus@0/aconnect@2900000/ahub@2900800/admaif@290f000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.030971] /bus@0/aconnect@2900000/ahub@2900800/asrc@2910000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031018] /bus@0/i2c@31e0000/audio-codec@1c: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000
[ 0.031039] /bus@0/padctl@3520000/ports/usb2-0: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@1
[ 0.031046] /bus@0/padctl@3520000/ports/usb2-1: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@0
[ 0.031052] /bus@0/padctl@3520000/ports/usb3-0: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@0
[ 0.031058] /bus@0/padctl@3520000/ports/usb3-1: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@1
[ 0.031084] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-0
[ 0.031089] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-1
[ 0.031095] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-1
[ 0.031100] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-0
[ 0.031111] /bus@0/interrupt-controller@f400000: Fixed dependency cycle(s) with /bus@0/interrupt-controller@f400000
[ 0.031156] /bus@0/aon@c000000: Fixed dependency cycle(s) with /bus@0/aon@c000000
[ 0.031654] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/processing-engine@2908000
[ 0.031662] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/asrc@2910000
[ 0.031668] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amixer@290bb00
[ 0.031673] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903b00
[ 0.031679] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903a00
[ 0.031684] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903900
[ 0.031689] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903800
[ 0.031695] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903300
[ 0.031700] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903200
[ 0.031705] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903100
[ 0.031710] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903000
[ 0.031716] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/mvc@290a200
[ 0.031721] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/mvc@290a000
[ 0.031726] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902600
[ 0.031731] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902400
[ 0.031736] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902200
[ 0.031741] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902000
[ 0.031746] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/dmic@2904200
[ 0.031751] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901500
[ 0.031756] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901300
[ 0.031761] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901100
[ 0.031766] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000
[ 0.031772] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/admaif@290f000
[ 0.031777] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000: Fixed dependency cycle(s) with /bus@0/i2c@31e0000/audio-codec@1c
[ 0.031787] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031799] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901100: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031810] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901300: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031822] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901500: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031833] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031844] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031855] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902400: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031867] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902600: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031878] /bus@0/aconnect@2900000/ahub@2900800/amx@2903000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031890] /bus@0/aconnect@2900000/ahub@2900800/amx@2903100: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031903] /bus@0/aconnect@2900000/ahub@2900800/amx@2903200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031915] /bus@0/aconnect@2900000/ahub@2900800/amx@2903300: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031927] /bus@0/aconnect@2900000/ahub@2900800/adx@2903800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031939] /bus@0/aconnect@2900000/ahub@2900800/adx@2903900: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031951] /bus@0/aconnect@2900000/ahub@2900800/adx@2903a00: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031962] /bus@0/aconnect@2900000/ahub@2900800/adx@2903b00: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031975] /bus@0/aconnect@2900000/ahub@2900800/dmic@2904200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031987] /bus@0/aconnect@2900000/ahub@2900800/processing-engine@2908000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.031998] /bus@0/aconnect@2900000/ahub@2900800/mvc@290a000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.032010] /bus@0/aconnect@2900000/ahub@2900800/mvc@290a200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.032021] /bus@0/aconnect@2900000/ahub@2900800/amixer@290bb00: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.032035] /bus@0/aconnect@2900000/ahub@2900800/admaif@290f000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.032050] /bus@0/aconnect@2900000/ahub@2900800/asrc@2910000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.032881] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 15, base_baud = 0) is a SBSA
[ 0.032894] printk: legacy console [ttyAMA0] enabled
[ 2.315091] /bus@0/i2c@31e0000/audio-codec@1c: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000
[ 2.327167] /bus@0/padctl@3520000/ports/usb2-0: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@1
[ 2.337807] /bus@0/padctl@3520000/ports/usb2-1: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@0
[ 2.348442] /bus@0/padctl@3520000/ports/usb3-0: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@0
[ 2.359076] /bus@0/padctl@3520000/ports/usb3-1: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@1
[ 2.371570] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-0
[ 2.382209] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-1
[ 2.392844] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-1
[ 2.403477] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-0
[ 2.416091] /bus@0/aon@c000000: Fixed dependency cycle(s) with /bus@0/aon@c000000
[ 2.424200] /bus@0/memory-controller@2c00000/external-memory-controller@2c60000: Fixed dependency cycle(s) with /bpmp
[ 2.434879] /bpmp: Fixed dependency cycle(s) with /bus@0/memory-controller@2c00000/external-memory-controller@2c60000
[ 2.448238] Modules: 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[ 2.455304] Modules: 0 pages in range for non-PLT usage
[ 2.455306] Modules: 511056 pages in range for PLT usage
[ 2.460784] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 2.472916] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 2.479194] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 2.485993] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 2.492270] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 2.499069] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 2.505347] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 2.512146] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 2.518912] ACPI: Interpreter disabled.
[ 2.523765] iommu: Default domain type: Translated
[ 2.528569] iommu: DMA domain TLB invalidation policy: strict mode
[ 2.534971] SCSI subsystem initialized
[ 2.538815] usbcore: registered new interface driver usbfs
[ 2.544321] usbcore: registered new interface driver hub
[ 2.549649] usbcore: registered new device driver usb
[ 2.555024] pps_core: LinuxPPS API ver. 1 registered
[ 2.559998] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 2.569152] PTP clock support registered
[ 2.573215] EDAC MC: Ver: 3.0.0
[ 2.576697] ARM FF-A: FFA_VERSION returned not supported
[ 2.582036] scmi_core: SCMI protocol bus registered
[ 2.587099] efivars: Registered efivars operations
[ 2.592283] FPGA manager framework
[ 2.595730] Advanced Linux Sound Architecture Driver Initialized.
[ 2.602091] vgaarb: loaded
[ 2.604967] clocksource: Switched to clocksource arch_sys_counter
[ 2.611198] VFS: Disk quotas dquot_6.6.0
[ 2.615141] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.622240] AppArmor: AppArmor Filesystem Enabled
[ 2.626966] pnp: PnP ACPI: disabled
[ 2.631710] NET: Registered PF_INET protocol family
[ 2.636716] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.647376] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 2.656199] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 2.663965] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.672859] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 2.681050] TCP: Hash tables configured (established 262144 bind 65536)
[ 2.687712] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 2.694886] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 2.702541] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 2.708322] RPC: Registered named UNIX socket transport module.
[ 2.714257] RPC: Registered udp transport module.
[ 2.718967] RPC: Registered tcp transport module.
[ 2.723677] RPC: Registered tcp-with-tls transport module.
[ 2.729170] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.735626] PCI: CLS 0 bytes, default 64
[ 2.739615] Unpacking initramfs…
[ 2.743070] kvm [1]: IPA Size Limit: 48 bits
[ 2.747363] kvm [1]: GICv3: no GICV resource entry
[ 2.752163] kvm [1]: disabling GICv2 emulation
[ 2.756624] kvm [1]: GIC system register CPU interface enabled
[ 2.762481] kvm [1]: vgic interrupt IRQ9
[ 2.766428] kvm [1]: VHE mode initialized successfully
[ 2.772068] Initialise system trusted keyrings
[ 2.776543] Key type blacklist registered
[ 2.780605] workingset: timestamp_bits=42 max_order=23 bucket_order=0
[ 2.787225] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.793170] NFS: Registering the id_resolver key type
[ 2.798244] Key type id_resolver registered
[ 2.802434] Key type id_legacy registered
[ 2.806455] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.813173] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.820588] ntfs: driver 2.1.32 [Flags: R/O].
[ 2.825016] 9p: Installing v9fs 9p2000 file system support
[ 2.830566] integrity: Platform Keyring initialized
[ 2.848708] Key type asymmetric registered
[ 2.852812] Asymmetric key parser ‘x509’ registered
[ 2.857714] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 2.865126] io scheduler mq-deadline registered
[ 2.869662] io scheduler kyber registered
[ 2.873692] io scheduler bfq registered
[ 2.882836] Freeing initrd memory: 11108K
[ 2.887354] EINJ: ACPI disabled.
[ 2.900988] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.908382] msm_serial: driver initialized
[ 2.912628] SuperH (H)SCI(F) driver initialized
[ 2.917240] STM32 USART driver initialized
[ 2.921710] printk: legacy console [ttyTCU0] enabled
[ 5.685651] arm-smmu 8000000.iommu: probing hardware configuration…
[ 5.698003] arm-smmu 8000000.iommu: SMMUv2 with:
[ 5.702749] arm-smmu 8000000.iommu: stage 1 translation
[ 5.708202] arm-smmu 8000000.iommu: stage 2 translation
[ 5.713668] arm-smmu 8000000.iommu: nested translation
[ 5.719030] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 5.726365] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 5.733165] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 5.739786] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 5.746402] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 5.753100] arm-smmu 8000000.iommu: preserved 0 boot mappings
[ 5.759727] arm-smmu 10000000.iommu: probing hardware configuration…
[ 5.766435] arm-smmu 10000000.iommu: SMMUv2 with:
[ 5.771261] arm-smmu 10000000.iommu: stage 1 translation
[ 5.776806] arm-smmu 10000000.iommu: stage 2 translation
[ 5.782350] arm-smmu 10000000.iommu: nested translation
[ 5.787811] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 5.795234] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 5.802121] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 5.808821] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 5.815526] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 5.822269] arm-smmu 10000000.iommu: preserved 0 boot mappings
[ 5.828688] arm-smmu 12000000.iommu: probing hardware configuration…
[ 5.835397] arm-smmu 12000000.iommu: SMMUv2 with:
[ 5.840226] arm-smmu 12000000.iommu: stage 1 translation
[ 5.845774] arm-smmu 12000000.iommu: stage 2 translation
[ 5.851325] arm-smmu 12000000.iommu: nested translation
[ 5.856784] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 5.864210] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 5.871097] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 5.877800] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 5.884504] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 5.891253] arm-smmu 12000000.iommu: preserved 0 boot mappings
[ 5.899562] loop: module loaded
[ 5.903188] megasas: 07.727.03.00-rc1
[ 5.909116] tun: Universal TUN/TAP device driver, 1.6
[ 5.914653] thunder_xcv, ver 1.0
[ 5.917989] thunder_bgx, ver 1.0
[ 5.921318] nicpf, ver 1.0
[ 5.924561] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 5.931992] hns3: Copyright (c) 2017 Huawei Corporation.
[ 5.937459] hclge is initializing
[ 5.940878] e1000: Intel(R) PRO/1000 Network Driver
[ 5.945897] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 5.951804] e1000e: Intel(R) PRO/1000 Network Driver
[ 5.956910] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 5.963000] igb: Intel(R) Gigabit Ethernet Network Driver
[ 5.968550] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 5.974279] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 5.980719] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 5.986924] sky2: driver version 1.30
[ 5.991095] PPP generic driver version 2.4.2
[ 5.995602] VFIO - User Level meta-driver version: 0.3
[ 6.002143] usbcore: registered new interface driver usb-storage
[ 6.009486] i2c_dev: i2c /dev entries driver
[ 6.014760] pps_ldisc: PPS line discipline registered
[ 6.021514] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[ 6.030973] sdhci: Secure Digital Host Controller Interface driver
[ 6.037326] sdhci: Copyright(c) Pierre Ossman
[ 6.042093] Synopsys Designware Multimedia Card Interface Driver
[ 6.048647] sdhci-pltfm: SDHCI platform and OF driver helper
[ 6.055638] ledtrig-cpu: registered to indicate activity on CPUs
[ 6.062107] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000001
[ 6.068978] tegra-bpmp bpmp: Adding to iommu group 0
[ 6.074875] tegra-bpmp bpmp: firmware: 684d9490f24f1c33cad8-bfff9e30f72
▒▒debugfs initialized
▒▒[ 7.662631] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 7.672609] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 7.681840] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 7.691416] hid: raw HID events driver (C) Jiri Kosina
[ 7.696854] usbcore: registered new interface driver usbhid
[ 7.702596] usbhid: USB HID core driver
[ 7.710246] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 7.719653] optee: probing for conduit method.
▒▒I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
▒▒[ 7.724248] optee: revision 4.6 (565c76420cf641dd)
[ 7.782659] optee: dynamic shared memory is enabled
[ 7.792746] optee: initialized driver
[ 7.796557] Driver ‘optee’ was unable to register with bus_type ‘arm_ffa’ because the bus was not initialized.
[ 7.807859] usbcore: registered new interface driver snd-usb-audio
[ 7.814550] u32 classifier
[ 7.817341] input device check on
[ 7.821115] Actions configured
[ 7.824662] NET: Registered PF_PACKET protocol family
[ 7.829893] 9pnet: Installing 9P2000 support
[ 7.834316] Key type dns_resolver registered
[ 7.841390] registered taskstats version 1
[ 7.845687] Loading compiled-in X.509 certificates
[ 7.851443] Loaded X.509 cert ‘Build time autogenerated kernel key: ec804eb170e00f516f62af1d1c810ac5ad3b170e’
[ 7.863785] AppArmor: AppArmor sha256 policy hashing enabled
[ 7.880099] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 7.887672] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 7.896262] serial-tegra 3100000.serial: Adding to iommu group 1
[ 7.902483] serial-tegra 3100000.serial: RX in PIO mode
[ 7.907867] serial-tegra 3100000.serial: TX in PIO mode
[ 7.913332] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 133, base_baud = 0) is a TEGRA_UART
[ 7.922769] serial-tegra 3140000.serial: Adding to iommu group 1
[ 7.928974] serial-tegra 3140000.serial: RX in PIO mode
[ 7.934356] serial-tegra 3140000.serial: TX in PIO mode
[ 7.939795] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 134, base_baud = 0) is a TEGRA_UART
[ 7.949193] serial-tegra 3110000.serial: RX in PIO mode
[ 7.954576] serial-tegra 3110000.serial: TX in PIO mode
[ 7.960027] 3110000.serial: ttyTHS4 at MMIO 0x3110000 (irq = 135, base_baud = 0) is a TEGRA_UART
[ 7.969419] serial-tegra 3130000.serial: RX in PIO mode
[ 7.974801] serial-tegra 3130000.serial: TX in PIO mode
[ 7.980240] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 136, base_baud = 0) is a TEGRA_UART
[ 8.006003] [drm] Initialized simpledrm 1.0.0 20200625 for chosen:framebuffer on minor 0
[ 8.029857] Console: switching to colour frame buffer device 320x90
[ 8.045070] simple-framebuffer chosen:framebuffer: [drm] fb0: simpledrmdrmfb frame buffer device
[ 8.055749] tegra_rtc c2a0000.rtc: registered as rtc1
[ 8.061023] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 8.067609] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 8.075221] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 8.082477] tegra-i2c 3190000.i2c: Adding to iommu group 1
[ 8.089648] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 8.096836] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[ 8.104093] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[ 8.111081] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000: Fixed dependency cycle(s) with /bus@0/i2c@31e0000/audio-codec@1c
[ 8.122929] /bus@0/i2c@31e0000/audio-codec@1c: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000
[ 8.135031] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 8.142322] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-0
[ 8.153340] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-1
[ 8.164339] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-1
[ 8.175323] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-0
[ 8.186674] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 8.197880] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2008000 KHz, changing to: 2035200 KHz
[ 8.210839] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[ 8.218378] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-0
[ 8.225300] mmc0: CQHCI version 5.10
[ 8.229413] /bus@0/padctl@3520000/ports/usb2-0: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@1
[ 8.244084] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-1
[ 8.255081] /bus@0/padctl@3520000/ports/usb2-1: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@0
[ 8.266304] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-0
[ 8.277284] /bus@0/padctl@3520000/ports/usb3-0: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@0
[ 8.279313] mmc0: SDHCI controller on 3460000.mmc [3460000.mmc] using ADMA 64-bit
[ 8.288244] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-1
[ 8.288262] /bus@0/padctl@3520000/ports/usb3-1: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@1
[ 8.318414] tegra-xusb 3610000.usb: Adding to iommu group 3
[ 8.339985] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 8.349716] tegra-xusb 3610000.usb: xHCI Host Controller
[ 8.355233] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 8.363728] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000000810
[ 8.373287] tegra-xusb 3610000.usb: irq 147, io mem 0x03610000
[ 8.379414] tegra-xusb 3610000.usb: xHCI Host Controller
[ 8.384926] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 8.392681] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 8.400345] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[ 8.408955] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.416489] mmc0: Command Queue Engine enabled
[ 8.416607] usb usb1: Product: xHCI Host Controller
[ 8.416636] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 8.416648] usb usb1: Manufacturer: Linux 6.8.12-1021-tegra xhci-hcd
[ 8.416889] mmcblk0: mmc0:0001 DG4064 59.2 GiB
[ 8.421264] usb usb1: SerialNumber: 3610000.usb
[ 8.425483] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 8.427057] hub 1-0:1.0: USB hub found
[ 8.433333] mmcblk0boot0: mmc0:0001 DG4064 4.00 MiB
[ 8.439431] hub 1-0:1.0: 4 ports detected
[ 8.439828] mmcblk0boot1: mmc0:0001 DG4064 4.00 MiB
[ 8.445341] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08
[ 8.449324] mmcblk0rpmb: mmc0:0001 DG4064 4.00 MiB, chardev (509:0)
[ 8.455710] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.495898] usb usb2: Product: xHCI Host Controller
[ 8.500985] usb usb2: Manufacturer: Linux 6.8.12-1021-tegra xhci-hcd
[ 8.507724] usb usb2: SerialNumber: 3610000.usb
[ 8.512929] hub 2-0:1.0: USB hub found
[ 8.516855] hub 2-0:1.0: 4 ports detected
[ 8.523071] sdhci-tegra 3400000.mmc: Adding to iommu group 4
[ 8.523986] irq: IRQ156: trimming hierarchy from :bus@0:pmc@c360000
[ 8.536457] irq: IRQ158: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 8.536498] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 8.537755] irq: IRQ159: trimming hierarchy from :bus@0:pmc@c360000
[ 8.556062] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 8.565246] clk: Disabling unused clocks
[ 8.646894] ALSA device list:
[ 8.650859] No soundcards found.
[ 8.664012] irq: IRQ160: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 8.676822] mmc1: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[ 8.687152] Freeing unused kernel memory: 11584K
[ 8.692928] Run /init as init process
[ 8.708892] Checking overlayfs setting…
[ 8.725135] Overlayfs is disabled…
[ 8.738454] Root device found: mmcblk0p1
[ 8.783812] Found dev node: /dev/mmcblk0p1
[ 8.844979] usb 1-4: new high-speed USB device number 2 using tegra-xusb
[ 9.013477] EXT4-fs (mmcblk0p1): mounted filesystem b8c46140-05a8-4ba4-bdea-412899896ffa r/w with ordered data mode. Quota mode: none.
[ 9.025606] usb 1-4: New USB device found, idVendor=174c, idProduct=2174, bcdDevice= 0.01
[ 9.035100] Rootfs mounted over mmcblk0p1
[ 9.036209] usb 1-4: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 9.043242] Switching from initrd to actual rootfs
[ 9.049548] usb 1-4: Product: ASMT2307
[ 9.049552] usb 1-4: Manufacturer: ASMT
[ 9.049554] usb 1-4: SerialNumber: 111122223333004C
[ 9.050528] hub 1-4:1.0: USB hub found
[ 9.079170] hub 1-4:1.0: 4 ports detected
[ 9.143559] systemd[1]: System time before build time, advancing clock.
[ 9.149145] usb 2-3: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[ 9.181642] usb 2-3: New USB device found, idVendor=174c, idProduct=3274, bcdDevice= 0.01
[ 9.190999] usb 2-3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 9.199162] usb 2-3: Product: ASMT2307
[ 9.199672] NET: Registered PF_INET6 protocol family
[ 9.199921] usb 2-3: Manufacturer: ASMT
[ 9.201654] Segment Routing with IPv6
[ 9.201774] usb 2-3: SerialNumber: 111122223333004C
[ 9.206520] hub 2-3:1.0: USB hub found
[ 9.207433] In-situ OAM (IOAM) with IPv6
[ 9.209115] hub 2-3:1.0: 4 ports detected
[ 9.254197] systemd[1]: systemd 255.4-1ubuntu8.16 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 9.289741] systemd[1]: Detected architecture arm64.
[ 9.295939] systemd[1]: Detected first boot.
[ 9.307843] systemd[1]: Hostname set to <localhost.localdomain>.
[ 9.319149] systemd[1]: Initializing machine ID from random generator.
[ 9.357148] systemd[1]: Using hardware watchdog ‘NVIDIA Tegra186 WDT’, version 0, device /dev/watchdog0
[ 9.369052] systemd[1]: Watchdog running with a timeout of 2min.
[ 9.404981] usb 1-4.1: new low-speed USB device number 3 using tegra-xusb
[ 9.542391] usb 1-4.1: New USB device found, idVendor=1c4f, idProduct=0034, bcdDevice= 1.10
[ 9.551989] usb 1-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.560390] usb 1-4.1: Product: Usb Mouse
[ 9.565316] usb 1-4.1: Manufacturer: SIGMACHIP
[ 9.579565] input: SIGMACHIP Usb Mouse as /devices/platform/bus@0/3610000.usb/usb1/1-4/1-4.1/1-4.1:1.0/0003:1C4F:0034.0001/input/input1
[ 9.596639] hid-generic 0003:1C4F:0034.0001: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-3610000.usb-4.1/input0
[ 9.704975] usb 1-4.2: new low-speed USB device number 4 using tegra-xusb
[ 9.844982] usb 1-4.2: New USB device found, idVendor=09da, idProduct=2268, bcdDevice= 1.12
[ 9.854488] usb 1-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.862808] usb 1-4.2: Product: USB Keyboard
[ 9.867970] usb 1-4.2: Manufacturer: SONiX
[ 9.884120] input: SONiX USB Keyboard as /devices/platform/bus@0/3610000.usb/usb1/1-4/1-4.2/1-4.2:1.0/0003:09DA:2268.0002/input/input2
[ 9.888291] systemd[1]: Populated /etc with preset unit settings.
[ 9.954522] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 9.986958] systemd[1]: /etc/systemd/system/nvcpupowerfix.service:37: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 10.051813] systemd[1]: Queued start job for default target nv-oobe.target.
[ 10.069224] hid-generic 0003:09DA:2268.0002: input,hidraw1: USB HID v1.11 Keyboard [SONiX USB Keyboard] on usb-3610000.usb-4.2/input0
[ 10.089599] input: SONiX USB Keyboard Consumer Control as /devices/platform/bus@0/3610000.usb/usb1/1-4/1-4.2/1-4.2:1.1/0003:09DA:2268.0003/input/input3
[ 10.106078] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ 10.116766] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[ 10.131791] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[ 10.143113] systemd[1]: Reached target slices.target - Slice Units.
[ 10.151803] systemd[1]: Reached target swap.target - Swaps.
[ 10.161284] input: SONiX USB Keyboard System Control as /devices/platform/bus@0/3610000.usb/usb1/1-4/1-4.2/1-4.2:1.1/0003:09DA:2268.0003/input/input4
[ 10.161377] hid-generic 0003:09DA:2268.0003: input,hidraw2: USB HID v1.11 Device [SONiX USB Keyboard] on usb-3610000.usb-4.2/input1
[ 10.190108] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[ 10.202549] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[ 10.217042] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[ 10.228930] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ 10.240681] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[ 10.250891] systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket.
[ 10.256986] usb 1-4.3: new full-speed USB device number 5 using tegra-xusb
[ 10.270506] systemd[1]: systemd-oomd.socket - Userspace Out-Of-Memory (OOM) Killer Socket was skipped because of an unmet condition check (ConditionPathExists=/proc/pressure/memory).
[ 10.288514] systemd[1]: systemd-pcrextend.socket - TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 10.307736] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ 10.318906] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ 10.365079] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System…
[ 10.379730] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System…
[ 10.394911] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System…
[ 10.401862] usb 1-4.3: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[ 10.414072] usb 1-4.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 10.438109] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System…
[ 10.454098] systemd[1]: Starting systemd-journald.service - Journal Service…
[ 10.468526] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout…
[ 10.483333] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes…
[ 10.487193] systemd-journald[210]: Collecting audit messages is disabled.
[ 10.504954] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs…
[ 10.521520] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod…
[ 10.534951] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore…
[ 10.547861] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse…
[ 10.562805] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop…
[ 10.572196] fuse: init (API version 7.39)
[ 10.581031] systemd[1]: Starting modprobe@nvme_fabrics.service - Load Kernel Module nvme_fabrics…
[ 10.597609] systemd[1]: Starting nvfb-udev.service - NVIDIA specific first-boot udev script…
[ 10.610274] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 10.628817] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules…
[ 10.640669] systemd[1]: systemd-pcrlock-file-system.service - Lock File Systems to TPM2 PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 10.658681] systemd[1]: systemd-pcrlock-machine-id.service - Lock Machine ID to TPM2 PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 10.676528] systemd[1]: systemd-pcrmachine.service - TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 10.679897] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 10.695007] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems…
[ 10.709217] Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 10.720846] Loaded X.509 cert ‘wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600’
[ 10.730953] systemd[1]: systemd-tpm2-setup-early.service - TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 10.749518] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices…
[ 10.766445] systemd[1]: Started systemd-journald.service - Journal Service.
[ 10.775248] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 10.777977] Bridge firewalling registered
[ 10.778623] EXT4-fs (mmcblk0p1): re-mounted b8c46140-05a8-4ba4-bdea-412899896ffa.
[ 10.781189] hsp_mailbox_client: loading out-of-tree module taints kernel.
[ 10.827724] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 5
[ 10.828299] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 10.831105] bc00000.rtcpu:hsp-vm1: camrtc_hsp_vm_read_boot_log: RTCPU boot complete
▒▒TCU debug prints will be routed to traces.
▒▒[ 10.855799] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee02ff size=131840
[ 10.855890] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 10.855925] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x512]=0x1900-0x1b80 TX[1x512]=0x1b80-0x1e00
[ 10.855949] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1e00-0x3e80 TX[1x8192]=0x3e80-0x5f00
[ 10.855970] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5f00-0xaf80 TX[64x320]=0xaf80-0x10000
[ 10.855990] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0x10000-0x18080 TX[512x64]=0x18080-0x20100
[ 10.856008] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x128]=0x20100-0x20200 TX[1x128]=0x20200-0x20300
[ 10.856253] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (161)
[ 10.856257] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 10.856500] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=dfa4cae106f00e37b6d2d53e94a5c9636b9cc011
[ 10.856673] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[ 10.856675] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[ 10.856676] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[ 10.856678] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[ 10.856680] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[ 10.856681] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[ 10.856685] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 10.856688] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 10.856690] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 10.856692] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 10.856694] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 10.856695] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 10.856696] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 10.867856] tegra-camera-rtcpu-debugfs bc00000.rtcpu:ivc-bus:dbg@2: nvidia,mem-map[1] node has no device
[ 10.884977] [RCE] TCU debug prints will be routed to traces.
[ 10.897090] tegra-camera-rtcpu-debugfs bc00000.rtcpu:ivc-bus:dbg@2: nvidia,mem-map[2] node has no device
[ 11.112137] tegra-camera-rtcpu-debugfs bc00000.rtcpu:ivc-bus:dbg@2: nvidia,mem-map[3] node has no device
[ 11.126280] camchar: rtcpu character device driver loaded
[ 11.143915] mc: Linux media interface: v0.10
[ 11.157154] videodev: Linux video capture interface: v2.00
[ 11.179734] tegra-host1x 13e00000.host1x: Adding to iommu group 6
[ 11.190403] host1x-context 13e00000.host1x.host1x-ctx.0: Adding to iommu group 7
[ 11.190496] host1x-context 13e00000.host1x.host1x-ctx.1: Adding to iommu group 8
[ 11.190569] host1x-context 13e00000.host1x.host1x-ctx.2: Adding to iommu group 9
[ 11.190630] host1x-context 13e00000.host1x.host1x-ctx.3: Adding to iommu group 10
[ 11.225325] host1x-context 13e00000.host1x.host1x-ctx.4: Adding to iommu group 11
[ 11.234278] host1x-context 13e00000.host1x.host1x-ctx.5: Adding to iommu group 12
[ 11.234354] host1x-context 13e00000.host1x.host1x-ctx.6: Adding to iommu group 13
[ 11.234426] host1x-context 13e00000.host1x.host1x-ctx.7: Adding to iommu group 14
[ 11.234499] host1x-context 13e00000.host1x.host1x-ctx.8: Adding to iommu group 15
[ 11.234569] host1x-context 13e00000.host1x.host1x-ctx.9: Adding to iommu group 16
[ 11.234636] host1x-context 13e00000.host1x.host1x-ctx.10: Adding to iommu group 17
[ 11.234717] host1x-context 13e00000.host1x.host1x-ctx.11: Adding to iommu group 18
[ 11.234788] host1x-context 13e00000.host1x.host1x-ctx.12: Adding to iommu group 19
[ 11.234844] host1x-context 13e00000.host1x.host1x-ctx.13: Adding to iommu group 20
[ 11.234930] host1x-context 13e00000.host1x.host1x-ctx.14: Adding to iommu group 21
[ 11.235003] host1x-context 13e00000.host1x.host1x-ctx.15: Adding to iommu group 22
[ 11.241449] systemd-journald[210]: Received client request to flush runtime journal.
[ 11.305502] tegra-soc-hwpm f100000.hwpm: Adding to iommu group 23
[ 11.360189] tegra-vic 15340000.vic: Adding to iommu group 24
[ 11.370227] tegra-nvdec 15480000.nvdec: Adding to iommu group 25
[ 11.381312] tegra-nvenc 154c0000.nvenc: Adding to iommu group 26
[ 11.391889] tegra-nvjpg 15380000.nvjpg: Adding to iommu group 27
[ 11.401469] tegra-nvjpg 15540000.nvjpg: Adding to iommu group 28
[ 11.414690] tegra-ofa 15a50000.ofa: Adding to iommu group 29
[ 11.422786] [drm] Initialized tegra 1.0.99 20120330 for 13e00000.host1x.drm on minor 1
[ 11.448175] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 11.460222] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 11.469720] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 11.480993] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 11.490402] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 11.500977] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 11.513010] tegra-camrtc-capture-isp tegra-capture-isp: capture_isp_probe: Probe-time fuse cache initialized - mask=0x1, num_devices=1
[ 11.531930] tegra194-isp5 14800000.isp: Adding to iommu group 30
[ 11.542214] camera-diag: Limiting to 1 ISP instance(s) for this chip
[ 11.550601] camera-diag: Failed to find ISP device node
[ 11.551557] camera-diagnostics bc00000.rtcpu:ivc-bus:diag@5: Failed to initialize diagnostic channel: -19
[ 11.567595] camera-diagnostics bc00000.rtcpu:ivc-bus:diag@5: Probe failed with error: -19
▒▒I/TC: WARNING (insecure configuration): Failed to get monotonic counter for REE FS, using 0
I/TC: WARNING (insecure configuration): Failed to commit dirh counter 2
▒▒[ 11.815445] audit: type=1400 audit(1780673791.668:2): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“cam” pid=376 comm=“apparmor_parser”
[ 11.817012] audit: type=1400 audit(1780673791.668:3): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“brave” pid=374 comm=“apparmor_parser”
[ 11.847732] audit: type=1400 audit(1780673791.668:4): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“Discord” pid=370 comm=“apparmor_parser”
[ 11.847740] audit: type=1400 audit(1780673791.672:5): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=4D6F6E676F444220436F6D70617373 pid=371 comm=“apparmor_parser”
[ 11.847742] audit: type=1400 audit(1780673791.672:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“buildah” pid=375 comm=“apparmor_parser”
[ 11.847745] audit: type=1400 audit(1780673791.672:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“QtWebEngineProcess” pid=372 comm=“apparmor_parser”
[ 11.847747] audit: type=1400 audit(1780673791.672:8): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“1password” pid=369 comm=“apparmor_parser”
[ 11.847749] audit: type=1400 audit(1780673791.672:9): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“balena-etcher” pid=373 comm=“apparmor_parser”
[ 11.847752] audit: type=1400 audit(1780673791.688:10): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“crun” pid=386 comm=“apparmor_parser”
[ 11.847754] audit: type=1400 audit(1780673791.688:11): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“ch-checkns” pid=382 comm=“apparmor_parser”
▒▒[TS:1018458327]Starting RmBootstrap
[TS:1018459562]Registered event_type:[0] for dce_core_ipc_type:[1]
[TS:1018460757]Registered event_type:[1] for dce_core_ipc_type:[3]
[TS:1018461652]dce_ipc State Initialized
[TS:1018463093]RmBootstrap completed successfully
▒▒[ 12.631481] ucsi_ccg 1-0008: i2c_transfer failed -121
[ 12.632744] ucsi_ccg 1-0008: ucsi_ccg_init failed - -121
[ 12.645207] ucsi_ccg: probe of 1-0008 failed with error -121
[ 17.113520] kauditd_printk_skb: 123 callbacks suppressed
[ 17.113528] audit: type=1400 audit(1792487726.740:135): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“libreoffice-soffice” pid=481 comm=“apparmor_parser”
[ 17.137504] audit: type=1400 audit(1792487726.740:136): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“libreoffice-soffice//gpg” pid=481 comm=“apparmor_parser”
[ 19.105185] iommu smmu.0x0000000010000000: IOMMU driver was not able to establish FW requested direct mapping.
[ 20.776300] NVIDIA OOBE will launch Gnome Initial Setup application…
[ 20.797356] audit: type=1400 audit(1792487730.424:137): apparmor=“DENIED” operation=“capable” class=“cap” profile=“/usr/sbin/dhcpd” pid=1727 comm=“dhcpd” capability=21 capname=“sys_admin”
[ 23.316369] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
▒▒[TS:1375208833]RmDeInit completed successfully
▒▒[ 24.217963] nvmap_deinit_ivc_queue: IVC context not initialized
[ 24.351499] nvgpu: 17000000.gpu gp10b_tegra_clks_control:159 [ERR] could not turn on clock 2
[ 24.361919] ------------[ cut here ]------------
[ 24.366703] WARNING: CPU: 0 PID: 242 at drivers/clk/clk.c:1200 clk_core_disable+0x1c0/0x200
[ 24.367595] —[ end trace 0000000000000000 ]—
[ 24.381223] ------------[ cut here ]------------
[ 24.386026] WARNING: CPU: 0 PID: 242 at drivers/clk/clk.c:1059 clk_core_unprepare+0x228/0x260
[ 24.386740] —[ end trace 0000000000000000 ]—
[ 24.402581] CPU:0, Error: cbb-fabric@0x13a00000, irq=33
[ 24.407975] **************************************
[ 24.412915] CPU:0, Error:cbb-fabric, Errmon:64
[ 24.417501] Error Code : TIMEOUT_ERR
[ 24.421556]
[ 24.423088] Error Code : TIMEOUT_ERR
[ 24.427136] MASTER_ID : TSECA_NONSECURE
[ 24.431455] Address : 0x155c0124
[ 24.435143] Cache : 0x3 – Bufferable Modifiable
[ 24.440443] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 24.447447] Access_Type : Read
[ 24.450956] Access_ID : 0x0
[ 24.450957] Fabric_Id : 0x0
[ 24.457437] Fabric : cbb-fabric
[ 24.461044] Slave_Id : 0x3
[ 24.464198] Burst_length : 0x0
[ 24.467706] Burst_type : 0x1
[ 24.471040] Beat_size : 0x2
[ 24.474281] VQC : 0x0
[ 24.477069] GRPSEC : 0x7f
[ 24.480136] FALCONSEC : 0x0
[ 24.483379] HOST1X_SLV_TIMEOUT_STATUS : 0x1
[ 24.487955] **************************************
Exception Type: 0
DFAR: 0x00000000 DFSR: 0x00001c06 ADFSR: 0x00500000
IFAR: 0x00000000 IFSR: 0x00000000 AIFSR: 0x00000000
PC: 0x408d9974 LR: 0x408c7c23 SP: 0x0dcddc08 PSR: 0x8000003f
R0: 0x41d03ab8 R1: 0x00000001 R2: 0x0dcddc18 R3: 0x0dc871a9
R4: 0x00000000 R5: 0x41c952b4 R6: 0x41c96498 R7: 0x0dcddc08
R8: 0x00000000 R9: 0x41d03ab8 R10: 0x00000000 R11: 0x0dcddca8
R12: 0x00000000
Data abort in user mode
Synchronous external abort (dfsr=0x00001808), AXI slave error on write to 0x13e2c000
r0_usr 0x13e2c000
r1_usr 0x00000000
r2_usr 0x00000000
r3_usr 0x00002710
r4_usr 0x00000000
r5_usr 0x00000001
r6_usr 0x50015108
r7_usr 0x0c360480
r8_usr 0x00000000 r8_fiq 0x00000000
r9_usr 0x500151c4 r9_fiq 0x00000000
r10_usr 0x50001021 r10_fiq 0x00000000
r11_usr 0x00000000 r11_fiq 0x00000000
r12_usr 0x000015dd r12_fiq 0x00000000
sp_usr 0x50195df0 sp_fiq 0x50010820 sp_irq 0x50010c00
sp_svc 0x50011400 sp_abt 0x50010770 sp_und 0x50010800
lr_usr 0x50054fcb lr_fiq 0x00000000 lr_irq 0x5000c551
lr_svc 0x5000b833 lr_abt 0x50001028 lr_und 0x00000000
pc 0x50001020
spsr 0x60000030
fpscr 0x00000000
00: base: 50000000 size: 00800000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
01: base: 00000000 size: 40000000 XN P_RW U_RW Shareable strongly-ordered
02: base: 00000000 size: 00000040 X P_RO U_NA Non-shareable outer: WB, no WA inner: WB, no WA
03: base: 50000000 size: 00010000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.1: base: 50020000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.2: base: 50040000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.3: base: 50060000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.4: base: 50080000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.5: base: 500a0000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.6: base: 500c0000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
05.1: base: 500c4000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.2: base: 500c8000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.3: base: 500cc000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.4: base: 500d0000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.5: base: 500d4000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.6: base: 500d8000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.7: base: 500dc000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
06: base: 50180000 size: 00080000 XN P_RO U_NA Non-shareable outer: WB, no WA inner: WB, no WA
07: base: 50780000 size: 00080000 XN P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
08: base: 50202000 size: 00002000 XN P_RW U_RW Non-shareable outer: WT, no WA inner: WT, no WA
10: base: 40070000 size: 00010000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
15: base: 50194000 size: 00002000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
mail worker 0@0x50248b9c sp 0x50195df0 stack: 50194000 - 50195ffc
Per task regions for mail worker 0
04: base: 50194000 size: 00002000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
Enable MMIO: 1, Enable data R/W: 1
call stack:
sp 0x50195df0 pc 0x50001020
sp 0x50195df0 pc 0x50054fca
sp 0x50195e30 pc 0x500553e6
sp 0x50195e60 pc 0x50055370
sp 0x50195e70 pc 0x50037530
sp 0x50195eb8 pc 0x50035642
sp 0x50195ed8 pc 0x50036e7a
sp 0x50195ee8 pc 0x5003a0f2
sp 0x50195f00 pc 0x50036dd0
sp 0x50195fa8 pc 0x5004daac
sp 0x50195fe0 pc 0x50069766
sp 0x50195ff8 pc 0xaaaaaaaa
eht_idx_find: 0xaaaaaaaa not a valid code address
no eidx for 0xaaaaaaaa
▒▒[ 24.689317] CPU:0, Error: dce-fabric@0xde00000, irq=32
[ 24.689332] **************************************
[ 24.689334] CPU:0, Error:dce-fabric, Errmon:2
[ 24.689341] Error Code : TIMEOUT_ERR
[ 24.689349]
[ 24.689351] Error Code : TIMEOUT_ERR
[ 24.689352] MASTER_ID : DCE
[ 24.689353] Address : 0x155c0114
[ 24.689355] Cache : 0x1 – Bufferable
[ 24.689357] Protection : 0x3 – Privileged, Non-Secure, Data Access
[ 24.689360] Access_Type : Write
[ 24.689361] Access_ID : 0x0
[ 24.689362] Fabric_Id : 0x0
[ 24.689363] Fabric : cbb-fabric
[ 24.689368] Slave_Id : 0x3
[ 24.689369] Burst_length : 0x0
[ 24.689371] Burst_type : 0x1
[ 24.689371] Beat_size : 0x2
[ 24.689372] VQC : 0x0
[ 24.689373] GRPSEC : 0x3f
[ 24.689374] FALCONSEC : 0x0
[ 24.689377] HOST1X_SLV_TIMEOUT_STATUS : 0xfffda000
[ 24.689380] **************************************
[ 24.691577] CPU:0, Error: dce-fabric@0xde00000, irq=32
[ 24.691579] **************************************
[ 24.691580] CPU:0, Error:dce-fabric, Errmon:2
[ 24.691586] Error Code : DECODE_ERR
[ 24.691594]
[ 24.691595] Error Code : DECODE_ERR
[ 24.691596] MASTER_ID : DCE
[ 24.691597] Address : 0xbf1830
[ 24.691598] Cache : 0xf – Bufferable Modifiable Read-Allocate Write-Allocate
[ 24.691599] Protection : 0x3 – Privileged, Non-Secure, Data Access
[ 24.691601] Access_Type : Read
[ 24.691602] Access_ID : 0x0
[ 24.691603] Fabric_Id : 0x0
[ 24.691604] Fabric : cbb-fabric
[ 24.691605] Slave_Id : 0x36
[ 24.691606] Burst_length : 0x0
[ 24.691607] Burst_type : 0x1
[ 24.691608] Beat_size : 0x2
[ 24.691609] VQC : 0x0
[ 24.691610] GRPSEC : 0x3f
[ 24.691611] FALCONSEC : 0x0
[ 24.691614] **************************************
[ 24.718340] CPU:0, Error: cbb-fabric@0x13a00000, irq=33
[ 24.718367] **************************************
[ 24.718369] CPU:0, Error:cbb-fabric, Errmon:2
[ 24.718376] Error Code : TIMEOUT_ERR
[ 24.718387]
[ 24.718389] Error Code : TIMEOUT_ERR
[ 24.718391] MASTER_ID : CCPLEX
[ 24.718393] Address : 0x13e4819c
[ 24.718395] Cache : 0x1 – Bufferable
[ 24.718400] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 24.718404] Access_Type : Read
[ 24.718406] Access_ID : 0x15
[ 24.718407] Fabric_Id : 0x0
[ 24.718409] Fabric : cbb-fabric
[ 24.718417] Slave_Id : 0x3
[ 24.718418] Burst_length : 0x0
[ 24.718420] Burst_type : 0x1
[ 24.718422] Beat_size : 0x2
[ 24.718423] VQC : 0x0
[ 24.718425] GRPSEC : 0x7e
[ 24.718426] FALCONSEC : 0x0
[ 24.718430] HOST1X_SLV_TIMEOUT_STATUS : 0x1
[ 24.718434] **************************************
[ 24.718469] WARNING: CPU: 0 PID: 3541 at drivers/soc/tegra/cbb/tegra234-cbb.c:653 tegra234_cbb_isr+0x158/0x174
[ 24.718905] —[ end trace 0000000000000000 ]—
[ 24.758564] CPU:0, Error: bpmp-fabric@0xd600000, irq=31
[ 24.758580] **************************************
[ 24.758583] CPU:0, Error:bpmp-fabric, Errmon:2
[ 24.758592] Error Code : TIMEOUT_ERR
[ 24.758602]
[ 24.758604] Error Code : TIMEOUT_ERR
[ 24.758606] MASTER_ID : BPMP_FW
[ 24.758609] Address : 0x13e2c000
[ 24.758612] Cache : 0x0 – Device Non-Bufferable
[ 24.758617] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 24.758621] Access_Type : Write
[ 24.758624] Access_ID : 0x0
[ 24.758626] Fabric_Id : 0x0
[ 24.758629] Fabric : cbb-fabric
[ 24.758635] Slave_Id : 0x3
[ 24.758637] Burst_length : 0x0
[ 24.758639] Burst_type : 0x1
[ 24.758641] Beat_size : 0x2
[ 24.758642] VQC : 0x0
[ 24.758644] GRPSEC : 0x7d
[ 24.758645] FALCONSEC : 0x0
[ 24.758650] **************************************
[ 34.661194] dce: dce_client_ipc_wait:377 Client [0] unexpected err: [-110]
[ 34.661212] dce: dce_ipc_send_message_sync:569 Error in waiting for ack
[ 44.901193] dce: dce_client_ipc_wait:377 Client [0] unexpected err: [-110]
[ 44.901210] dce: dce_ipc_send_message_sync:569 Error in waiting for ack
[ 45.296010] [drm:nv_drm_exit [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0xfffffffe] Failed to allocate NvKmsKapiDevice
Ubuntu 24.04.4 LTS localhost.localdomain ttyTCU0
localhost login:
