According to Xavier TRM V1.3p which revised on 20191004.
In Table 7.7, Peak bandwidth in C-PHY is changed from 109 (3.0 x 2.28 x 4 x 4) to 91 (2.5 x 2.28 x 4 x 4). That means the original design of C-PHY is 3Gs/s and TRM V1.3p modify it to 2.5Gs/s.
Moreover, in Table 7.10 System Lvel Peak Bandwidth, there are 3 PHY mode on C-PHY depending on different NVCSI clock and lane clock.
Target VLV LV SV
BW/Trio 1.68 Gs/s 2.0 Gs/s 3.0 Gs/s
Totaol BW 61 Gbps 73 Gbps 109 Gps
Lane clock 240MHz 286 MHz 428.6 MHz
NVCSI clock 240MHz 314 MHz 428.6 MHz
I have one questions:
What is the default value of NVCSI CLK? How to modify
please modify the property settings in camera device tree, especially the pixel_clk_hz,
you may also check Sensor Software Driver Programming for reference,
besides,
please refer to this reference driver for using CPHY interface, $L4T_Sources/r32.6.1/Linux_for_Tegra/source/public/hardware/nvidia/platform/t19x/common/kernel-dts/t19x-common-modules/tegra194-camera-e3331-a00.dtsi
* Copyright (c) 2017-2019, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
host1x {
vi@15c10000 {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
e3331_vi_in0: endpoint {
port-index = <0>;
bus-width = <3>;
remote-endpoint = <&e3331_csi_out0>;
nvcsi@15a00000 {
num-channels = <1>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3331_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <3>;
remote-endpoint = <&e3331_imx318_out0>;
port@1 {
reg = <1>;
e3331_csi_out0: endpoint@1 {
remote-endpoint = <&e3331_vi_in0>;
i2c@3180000 {
tca9546@70 {
i2c@0 {
imx318_a@10 {
compatible = "nvidia,imx318";
reg = <0x10>;
/* Physical dimensions of sensor */
physical_w = "6.811";
physical_h = "5.254";
sensor_model = "imx318";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
dvdd-reg = "vdig";
has-eeprom;
* ==== Modes ====
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* == Signal properties ==
* phy_mode = "";
* PHY mode used by the MIPI lanes for this device
* tegra_sinterface = "";
* CSI Serial interface connected to tegra
* Incase of virtual HW devices, use virtual
* For SW emulated devices, use host
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* == Image format Properties ==
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* line_length = "";
* Pixel line length (width) for sensor mode.
* == Source Control Settings ==
* Gain factor used to convert fixed point integer to float
* Gain range [min_gain/gain_factor, max_gain/gain_factor]
* Gain step [step_gain/gain_factor is the smallest step that can be configured]
* Default gain [Default gain to be initialized for the control.
* use min_gain_val as default for optimal results]
* Framerate factor used to convert fixed point integer to float
* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
* Default Framerate [Default framerate to be initialized for the control.
* use max_framerate to get required performance]
* Exposure factor used to convert fixed point integer to float
* For convenience use 1 sec = 1000000us as conversion factor
* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
* Default Exposure Time [Default exposure to be initialized for the control.
* Set default exposure based on the default_framerate for optimal exposure settings]
* gain_factor = ""; (integer factor used for floating to fixed point conversion)
* min_gain_val = ""; (ceil to integer)
* max_gain_val = ""; (ceil to integer)
* step_gain_val = ""; (ceil to integer)
* default_gain = ""; (ceil to integer)
* Gain limits for mode
* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* step_exp_time = ""; (ceil to integer)
* default_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (sec)
* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
* min_framerate = ""; (ceil to integer)
* max_framerate = ""; (ceil to integer)
* step_framerate = ""; (ceil to integer)
* default_framerate = ""; (ceil to integer)
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
mode0 { /*IMX318_MODE_5488X4112_30FPS*/
mclk_khz = "24000";
num_lanes = "3";
phy_mode = "CPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "20";
active_w = "5488";
active_h = "4112";
mode_type = "bayer";
pixel_phase = "bggr";
csi_pixel_bit_depth = "10";
line_length = "5488";
inherent_gain = "1";
mclk_multiplier = "31.25";
pix_clk_hz = "750000000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16"; /* 1.0 */
max_gain_val = "256"; /* 16.0 */
step_gain_val = "1"; /* 0.125 */
default_gain = "16";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "1500000"; /* 1.5 */
max_framerate = "30000000"; /* 30 */
step_framerate = "1";
default_framerate= "30000000";
min_exp_time = "34"; /* us */
max_exp_time = "550385"; /* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3331_imx318_out0: endpoint {
port-index = <0>;
bus-width = <3>;
remote-endpoint = <&e3331_csi_in0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* Set this to the highest pix_clk_hz out of all available modes.
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <3>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <800000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. 鈥渞ear鈥?or 鈥渇ront鈥?
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "e3331_rear_22N02A";
position = "rear";
orientation = "1";
drivernode0 {
pcl_id = "v4l2_sensor";
devname = "imx318 30-0010";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@0/imx318_a@10";
1 There are three configuration modes for pixel_CLK_HZ in the document. Which one is used on AGX?
2 Could you please tell me the configuration in the device tree corresponding to pixel_clk_HZ? pix_clk_hz = “750000000”; ! max_pixel_rate = < 800000>; !
they’re based-on different variables. all these three formulas should result in the same pixel clock values, you must configure pix_clk_hz correctly to avoid potential issues.
max_pixel_rate, it’s the max pixel rate for the ISP ISO use-case, you may keep it as default or configure it as your highest pix_clk_hz out of all available sensor modes.
hello JerryChang
1 I use the following command to read the rate. The result is different when the graph is not displayed and when the graph is displayed. What is the reason?
