Debug OV5693 on jetpack4.6, AGX development board, and find that the mips signal of the sensor is not shown, the kernel will crash
100% reproduction process, comment to err in the ov5693_start_streaming function in the ov5693.c driver = ov5693_write_table(priv, mode_table[OV5693_MODE_START_STREAM]);
The serial port debug is as follows:
[61.775332] tegra194-vi5 15c10000.vi: no reply from camera processor
[61.775490] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[61.776266] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[61.780217] Unable to handle kernel NULL pointer dereference at virtual address 00000010
[61.780374] Mem abort info:
[61.780432] ESR = 0x96000005
[61.780490] Exception class = DABT (current EL), IL = 32 bits
[61.783459] SET = 0, FnV = 0
[61.786329] EA = 0, S1PTW = 0
[61.789754] Data abort info:
[61.792463] ISV = 0, ISS = 0x00000005
[61.796381] CM = 0, WnR = 0
[61.799534] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc3d0198000
[61.806106] [0000000000000010] *pgd=0000000000000000, *pud=0000000000000000
[61.813247] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[61.818762] Modules linked in: ov5693 bnep fuse xt_conntrack ipt_MASQUERADE nf_nat_masquerade_ipv4 nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_conntrack_ipv4 nf_conntrack_ipv4 nf_conntrack_ipv4 nf_conntrack_p
[61.848616] CPU: 1 PID: 8914 Comm: vi-output, ov56 Not tainted 4.9.253-tegra #917
[61.856031] Hardware name: Jetson-AGX (DT)
[61.860233] task: ffffffc3e9aa3800 task.stack: ffffffc379038000
[61.866013] PC is at _raw_write_lock+0x30/0x58
[61.870213] LR is at destroy_buffer_table+0x40/0xd8
[61.875457] pc: [] lr: [] pstate: 20c00045
[61.882459] sp: ffffffc37903bc70
[61.885956] x29: ffffffc37903bc70 x28: 0000000000000000
[61.891203] x27: 0000000000000000 x26: 0000000000000000
[61.896467] x25: 0000000000000010 x24: 0000000000000098
[61.902493] x23: 0000000000000018 x22: ffffff8009087618
[61.907654] x21: 0000000000000000 x20: ffffffc38574cc00
[61.912730] x19: 0000000000000010 x18: 0000000000000000
[61.918504] x17: 0000000000000002 x16: 0000000000000003
[61.924191] x15: 0000000000172016 x14: 0000000000000000
[61.929879] x13: 000000000012ef86 x12: 0000000000000000
[61.935567] x11: 00000000000a71e7 x10: 0000000000000001
[61.941002] x9: ffffffc37903ba80 x8: 0000000000000000
[61.947029] x7: ffffffc3c040f0c0 x6: ffffffc3801073c1
[61.952543] x5: ffffff800852d904 x4: ffffffbf0e0041d0
[61.957879] x3: 0000000000000000 x2: ffffffc3801073c0
[61.963219] x1: 0000000000000000 x0: 0000000080000000
[61.968301]
[61.969964] Process vi-output, ov56 (pid: 8914, stack limit = 0xffffffc379038000)
[61.976955] Call trace:
[61.979497] [] _raw_write_lock+0x30/0x58
[61.984571] [] destroy_buffer_table+0x40/0xd8
[61.990172] [] vi_capture_shutdown+0xd4/0x130
[61.995771] [] vi_channel_close_ex+0x34/0x88
[62.001113] [] vi5_channel_error_recover+0x48/0x1c8
[62.007321] [] tegra_channel_error_recover+0x80/0xb8
[62.013445] [] tegra_channel_kthread_capture_dequeue+0xf8/0x1c0
[62.020360] [] kthread+0xec/0xf0
[62.024996] [] ret_from_fork+0x10/0x30
[62.030250] —[ end trace a408d2331cebe6a3 ]—
[62.037619] note: vi-output, ov56[8914] exited with preempt_count 1
[62.064440] tegra194-vi5 15c10000.vi: vi_capture_release: setup channel first
[62.069765] video4linux video0: vi capture release failed
Please tell me why
