I’ve acquired an AGX at GTC and came home to use my KVM which uses a large monitor 49"W - but I got no video.
I moved the AGX with the same DP cable to another, smaller monitor, and I was able to see it boot-up.
Does anyone know if there is a solution/option or am I looking to switch to a smaller monitor?
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
Thanks ~0409
If no KVM is involved, will it work?
