version: AGX Ori 5.0.2 rev.1
When I run command :
$sudo ./flash.sh jetson-agx-orin-lcfc mmcblk0p1
*** Flashing target device started. ***
File “./tegraflash.py”, line 1305, in
chip = chip.replace(’ ', ’ ')
AttributeError: ‘NoneType’ object has no attribute ‘replace’
Failed flashing t186ref.
刷机log.txt (24.6 KB)
Are you sure your board could be flashed if not using your own board config?
Yes.I am sure.As you can see the log :
[ 0.0937 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.1028 ] File rcm_state open failed
[ 0.1029 ] ERROR: failed to read rcm_state
This place throw the exception. I don’t know why.
That does not matter. Even running the default one shall have same log.
if I run by adding “–no-flash” option.It can run ok. My environment is ‘Vmware+Ubuntu18.04’.
kayccc
November 2, 2022, 4:19am
#8
VM is not supported and suggest to have Ubuntu 20.04 as host for development environment setip.
system
Closed
November 16, 2022, 4:19am
#9
