AGX orin 32GB JP7.2 CUDA and tensorRT problems
Hi
HW: AGX Orin 32GB
JP: 7.2
I have several problems about AGX Orin 32GB with JetPack7.2 for super mode.
1, Can I install the cuda-toolkit-13.2.2 instead of cuda-toolkit-13.2.1 ?
We found a bug would decrease the performance of program, so we wanted to install the cuda-toolkit-13.2.2
2, Does the tensorRT 10.16.2 support the DLA? Can you offer the release note ? We used the tensoRT10.7 agao, and it can run in DLA, but now we upgrade the jetpack to JP7.2, and the version of tensoRT is 10.16.2, and it seemed it can’t support DLA
Please help me to check these problems, thank you
If you want dla I think you need to use https://developer.nvidia.com/embedded/jetpack-sdk-622
“JetPack 6.2.2 is the latest production release of JetPack 6. This release includes Jetson Linux 36.5, featuring the Linux Kernel 5.15 and an Ubuntu 22.04-based root file system. The Jetson AI stack packaged with JetPack 6.2.2 includes CUDA 12.6, TensorRT 10.3, cuDNN 9.3, VPI 3.2, DLA 3.1, and DLFW 24.0.”
https://docs.nvidia.com/deeplearning/tensorrt/latest/inference-library/work-with-dla.html
Jetpack 7.2 uses nvidia driver nvidia-smi --query-gpu=driver_version --format=csv,noheader = 595.78.
I would say do not install cuda-13.2.2 because it is based on a different nvidia driver 595.71.05.
I did following to not install but to take a look at 13.2.2 and at least as far as nvcc, its version is same as Jetpack 7.2 nvcc.
wget https://developer.download.nvidia.com/compute/cuda/13.2.2/local_installers/cuda-repo-ubuntu2404-13-2-local_13.2.2-595.71.05-1_arm64.deb
dpkg-deb -R cuda-repo-ubuntu2404-13-2-local_13.2.2-595.71.05-1_arm64.deb .
cd var/cuda-repo-ubuntu2404-13-2-local
dpkg-deb -R cuda-nvcc-13-2_13.2.86-1_arm64.deb .
cd -
var/cuda-repo-ubuntu2404-13-2-local/usr/local/cuda-13.2/bin/nvcc -V
Copyright (c) 2005-2026 NVIDIA Corporation
Built on Fri_May_08_10:52:52_AM_PDT_2026
Cuda compilation tools, release 13.2, V13.2.86
Build cuda_13.2.r13.2/compiler.37953736_0
Hi ,
Does the tensorRT10.16.2 support DLA?
“DLA is not supported in TensorRT 11.0, 11.1, or 11.2. TensorRT 10.7 was the last release that supported DLA. The guidance in this section describes DLA behavior for supported earlier releases.”
  1. Yes, the CUDA package is upgradable.
  2. No. We are still working on this.
TensorRT with DLA support is ready internally.
It will be available with the upcoming release.
