我们自研的主板上使用的是JETPACK6.2 现在需要升级到JETPACK6.2.1,请教下这种小版本的升级能否在线升级啊?如果可以的话是否有相应执行命令?
Unfortunately, the provided context does not contain specific information about Jetson AGX Orin JETPACK62 and JETPACK621. However, I can provide some general information about Jetson AGX Orin and its related topics.
Jetson AGX Orin is a series of NVIDIA Jetson modules, which are designed for edge AI and robotics applications. The Jetson AGX Orin series is part of the NVIDIA Jetson Orin series, which also includes the Jetson Orin NX and Jetson Orin Nano series.
The NVIDIA Jetson Linux Developer Guide provides a comprehensive guide for developers working with the Jetson Orin series, including the Jetson AGX Orin. The guide covers topics such as software architecture, boot architecture, software features, and hardware references.
Some of the key features of the Jetson AGX Orin series include:
- High-performance computing and AI capabilities
- Support for multiple cameras and sensors
- Advanced power management and thermal management
- Support for various operating systems, including Linux
However, without more specific information, it is difficult to provide a detailed comparison between JETPACK62 and JETPACK621. If you could provide more context or clarify what you are looking for, I would be happy to try and assist you further.
In general, the Jetson AGX Orin series is designed to provide high-performance computing and AI capabilities for edge AI and robotics applications. If you are working with the Jetson AGX Orin series, I recommend consulting the NVIDIA Jetson Linux Developer Guide for more detailed information on how to develop and optimize your applications.
If you have any further questions or would like more information on a specific topic, please let me know and I will do my best to assist you.
请问有人帮忙看下吗?
Running an OTA update may cause your device to fail to boot if you are using a custom kernel image or DTB, because the OTA will replace them with the official packages.
Please refer to elinux provided commands to avoid self-built kernel be overwritten.
您好 方便提供下链接吗?
刚看了下 内核部分我没有进行修改,修改的是设备树和pinmux,如果我使用OTA更新是否会覆盖我修改的pinmux?
Yes.
Please follow the mentioned commands and check whether any issues.
