Agx orin 64G 采用sdkmanger刷机失败(刷jetapck5.1.2版本)
设备为:agx orin 64G, 采用sdkmanger刷 5.12版本的镜像,最终失败,请问这个版本有什么特别的吗? 换电脑、换数据线都试过了, 刷不了官方的镜像。
Based on the provided context, it seems like you are asking about the Jetson AGX Orin 64GB and its SDK Manager, specifically the 512 version.
The Jetson AGX Orin series is a line of NVIDIA Jetson modules that are designed for edge AI and robotics applications. The Jetson AGX Orin 64GB is a specific module in this series that comes with 64GB of memory.
SDK Manager is a tool provided by NVIDIA for managing the software development kit (SDK) for Jetson modules. It allows users to install, update, and manage the SDK, as well as configure the module’s settings.
However, the provided context does not specifically mention the SDK Manager version 512. It’s possible that you are referring to a specific version of the SDK Manager that is compatible with the Jetson AGX Orin 64GB module.
To provide more information, here are some key points about the Jetson AGX Orin series and SDK Manager:
  • The Jetson AGX Orin series is based on the NVIDIA Ampere architecture and provides high-performance computing and AI capabilities.
  • The Jetson AGX Orin 64GB module comes with 64GB of memory and is designed for demanding edge AI and robotics applications.
  • SDK Manager is a tool provided by NVIDIA for managing the SDK for Jetson modules.
  • SDK Manager allows users to install, update, and manage the SDK, as well as configure the module’s settings.
  • The SDK Manager version may vary depending on the specific module and software version.
If you are looking for more information about the Jetson AGX Orin 64GB module or SDK Manager, I recommend checking the official NVIDIA documentation and resources for more details.
Here is a comparison of the Jetson AGX Orin series modules:
  • Jetson AGX Orin Developer Kit: This is a development kit that includes the Jetson AGX Orin module, a carrier board, and other accessories.
  • Jetson AGX Orin 64GB: This is a specific module in the Jetson AGX Orin series that comes with 64GB of memory.
  • Jetson AGX Orin Industrial: This is a ruggedized version of the Jetson AGX Orin module that is designed for industrial applications.
  • Jetson AGX Orin 32GB: This is a specific module in the Jetson AGX Orin series that comes with 32GB of memory.
The Jetson Orin NX series and Jetson Orin Nano series are also mentioned in the context, but they are different modules with different specifications and features.
I hope this information helps. Let me know if you have any further questions.
最后的报错提示
Please install the latest version like JP5.1.5 to cross check whether the issue exists.
JP5.1.5 可以烧录; 已经试过了。 因为我们一直用的是JP5.1.2版本,想知道为什么刷不上5.1.2了
In most cases, it’s related to PCN problem.
Please visit Log in | NVIDIA Developer to download AGX Orin PCN and flash again.
agx orin 64 的PCN编号如何获取?
Please review the mentioned PCN download center and install overlay based on your bsp.
