AGX orin 64G USB 3.2 cannot connect to Zed mini camera for use?
AGX orin 64G USB 3.2 cannot connect to Zed mini camera for use? Is anyone using it normally?
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
Sorry, are you a robot? I haven’t used the depth algorithm yet, I just watched the zed-mini camera on Ubuntu 20.04’s Cheese and it won’t work after restarting. I have to unplug and plug it again to see the image.
By default we support UVC driver. If the camera supports the driver, please try the steps:
Jetson AGX Orin FAQ
Q: I have a USB camera. How can I launch it on AGX Orin?
The latest release is Jetpack 6.1. If you are using previous release, we would suggest upgrade to latest version.
