AGX Orin 64GB DevKit (P3730) will not enter force recovery mode
Hardware: Jetson AGX Orin 64GB Developer Kit Model: P3730 Carrier board: P3737 S/N: 1423426605721 Host: Ubuntu 24.04, SDK Manager 2.4.1 Problem: the board does not enter force recovery mode. lsusb always reports 0955:7045 “Tegra On-Platform Operator”, never APX, regardless of the method used. The system was left in a broken state after an interrupted download/update. The board powers on (blue LED) but does not boot: no video output, no network, and 192.168.55.1 does not respond over USB. Tried: - Force Recovery button + Reset button - Force Recovery button + Power button - Holding Force Recovery while connecting power - Jumper on J42 automation header, pins 1 (GND) and 2 (FORCE_RECOVERY_N), verified with a multimeter - Two different USB-C cables (both confirmed to carry data) - Both USB-C ports (J24 rear and J40 side) SDK Manager always shows “Could not detect a board”. Is there any other way to force recovery on this board, or does this indicate a hardware failure?
Please access the system and run below commands to check whether the device in recovery mode.
sudo reboot --force forced-recovery
Thank you for the reply.
Unfortunately I cannot run that command because I have no access
to the system at all. Here is the full situation:
The board powers on: the blue LED turns on and stays on.
But it does not boot:
  • No video output on DisplayPort (black screen, no BIOS, no UEFI,
    no boot messages). Pressing F2 / Esc / Del does nothing.
  • No network on the RJ45 port.
  • 192.168.55.1 does not respond over USB.
  • No serial output either.
Since there is no shell and no video, I cannot execute
“sudo reboot --force forced-recovery”.
What I have already tried to force recovery from the hardware side:
  • Force Recovery button + Reset button
  • Force Recovery button + Power button
  • Holding Force Recovery while connecting power
  • Jumper on J42 automation header between pin 1 (GND) and pin 2
    (FORCE_RECOVERY_N). Pin 1 was verified with a multimeter
    (continuity to chassis ground).
  • Two different USB-C data cables (both confirmed working: the
    device disappears from lsusb when unplugged)
  • Both USB-C ports (J24 rear and J40 side)
In every case, lsusb on the Ubuntu host reports:
Bus 001 Device 00X: ID 0955:7045 NVIDIA Corp. Tegra On-Platform Operator
It never changes to APX. SDK Manager 2.4.1 always shows
Model: P3730 / Carrier: P3737 / S/N: 1423426605721
The board became unresponsive after an interrupted software update.
Is there any way to force recovery purely from the host side, or
does this indicate the boot firmware is corrupted beyond recovery?
Would this be covered under warranty?
Please try below methods also
  • For the Jetson AGX Orin developer kit (Powered off):
    1. Ensure that the developer kit is powered off.
    2. Press and hold down the Force Recovery button.
    3. Press, then release the Power button.
    4. Release the Force Recovery button.
  • For the Jetson AGX Orin developer kit (Powered on):
    1. Ensure that the developer kit is powered on.
    2. Press Force Recovery button + Reset button
This might help:
unplug power.
plug power in.
tap esc key until you get into bios.
Device Manager
Nvidia Configuration
Boot Configuration
scroll down and spacebar to select “Boot into Recovery”
Or use a different usb cable.
