AGX Orin Auto Power On Delay time
Hi
I referred to the answer in the following link and designed an auto-power-on circuit. However, we found that if AC_OK is directly shorted to 3V3_AO, the Button MCU P0.6 pin and VDD will power up at the same time. This causes the Button MCU to complete initialization before the rising-edge active signal of AC_OK is applied, and under this scenario, the button MCU does not output the power-on enable signal.
To address this issue, we pulled AC_OK up to 3V3_AO and designed a buffer + RC delay circuit. However, we still observed that the auto-power-on detection occasionally fails. The issue can only be improved when another 100nF capacitors are populated.
Therefore, we would like to know: Is a delay required for the auto-power-on function of the button MCU? If so, how long should the delay be to ensure safe operation? Is there any issue with our current circuit design?
Thank you.
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
Based on the provided context, I found a relevant answer in the Community Solutions section.
According to the accepted solution in Topic #303877, “Yes, pulling it to 3.3V_AO will enable auto power-on function.”
However, the question also asks about the delay time required for the auto-power-on function of the button MCU. In Topic #227533, it is mentioned that “VDDIN_PWR_BAD_N should go up at the same time as MV. … The purpose is to get HV/MV ready before enable MODULE_POWER_ON.” Additionally, it is stated that “The button MCU FW applies to many jetson projects. For other projects, VIN_PWR_ON will control the buck/boost converter for HV/MV. It will need more time to get ready compared to Concord.”
Although the exact delay time is not specified, it is implied that some delay is necessary to ensure safe operation. The provided context does not provide a specific value for the delay time, but it suggests that the delay time may vary depending on the specific project and hardware configuration.
Regarding the circuit design, the provided context does not explicitly mention any issues with the current design. However, it is mentioned that adding another 100nF capacitor improved the issue, which suggests that the circuit design may need to be adjusted to ensure reliable operation.
In summary, pulling ACOK_CON up to 3.3V_AO is required to enable auto power-on, and some delay is necessary to ensure safe operation. However, the exact delay time is not specified in the provided context, and the circuit design may need to be adjusted to ensure reliable operation.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
ACOK is edge triggered so the 3V3_AO (power to the Button MCU) needs to be stable before ACOK asserts, otherwise the MCU misses the rising edge. It looks like your design deviated from the P3737 carrier board reference, which reduced the delay enough that the MCU doesn’t reliably detect ACOK rising.
Per the note below in the Jetson AGX Orin Series Design Guide (including AGX Orin Industrial), designs using the EFM8SB10F8G-A-QFN20 MPU for power button control must replicate the circuitry from the latest P3737 carrier board reference exactly to work with the NVIDIA-provided binary.
Adding a cap to delay the ACOK edge is the right approach, but I can’t advise on the specific value since that would need to be validated against your power sequencing.
