AGX Orin backup/restore: To massflash the backup image not stable
We are using a custom carrier board for the AGX Orin with release 36.4.4.
I am following ‘Workflow 3: To massflash the backup image’ in tools/backup_restore/README_backup_restore.txt to perform system backup and restore operations. However, the restore process is unstable. It occasionally reports errors and fails to complete. The error log is as follows:
Tool log:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 1 --network usb0
# Entry added by NVIDIA initrd flash tool
/home/xx/code/nvidia/xx/v11/images/mfi_xx/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
rpcbind: another rpcbind is already running. Aborting
Export list for localhost:
10:45:11.265 - Debug: Checking UFW status and NFS port rules...
10:45:11.327 - Debug: UFW is not active. NFS port is accessible.
10:45:11.328 - Debug: Checking VPN connections...
10:45:11.334 - Debug: IPSec service is not running.
10:45:11.336 - Debug: VPN routes none in tun|tap|ppp|vpn|gpd.
10:45:11.338 - Debug: No VPN connection detected.
/home/xx/code/nvidia/xx/v11/images/mfi_xx/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 1-6 --device-instance 0 --flash-only --network usb0 xxa internal
*  Step 1: Build the flashing environment    *
Create flash environment 0
/home/xx/code/nvidia/xx/v11/images/mfi_xx/bootloader /home/xx/code/nvidia/xx/v11/images/mfi_xx
Finish creating flash environment 0.
*  Step 2: Boot the device with flash initrd image *
/home/xx/code/nvidia/xx/v11/images/mfi_xx/temp_initrdflash/bootloader0 /home/xx/code/nvidia/xx/v11/images/mfi_xx
./tegraflash.py --bl uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --bldtb tegra234-xxa+p3701-0005-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --instance 1-6 --cmd "rcmboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3701-0005-3737-0000_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-xxa+p3701-0005-nv.dtb"    --bct_backup
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
 Entering RCM boot
[   0.0173 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0173 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0173 ] rcm boot with presigned binaries
[   0.0179 ] tegrarcm_v2 --instance 1-6 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0184 ] BR_CID: 0x80012344705DF8A33000000009010280
[   0.0282 ] Sending bct_br
[   0.0365 ] Sending mb1
[   0.0371 ] Sending psc_bl1
[   0.0497 ] Sending bct_mb1
[   0.0562 ] Generating blob for T23x
[   0.0582 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.0589 ] The number of images in blob is 19
[   0.0600 ] blobsize is 121844455
[   0.0602 ] Added binary blob_uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt of size 2093120
[   0.1071 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[   0.1073 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[   0.1074 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[   0.1075 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279808
[   0.1076 ] Not supported type: mb2_applet
[   0.1076 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 440944
[   0.1078 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   0.1079 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[   0.1086 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12079200
[   0.1137 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.1150 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1027008
[   0.1155 ] Added binary blob_tegra234-bpmp-3701-0005-3737-0000_with_odm_sigheader.dtb.encrypt of size 264960
[   0.1156 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[   0.1158 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 415008
[   0.1159 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.1160 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1887312
[   0.1168 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.1170 ] Added binary blob_boot0.img of size 99061760
[   0.1590 ] Added binary blob_tegra234-xxa+p3701-0005-nv.dtb of size 258135
[   0.2143 ] tegrarcm_v2 --instance 1-6 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   0.2147 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[   0.3262 ] Sending bct_mem
[   0.3396 ] Sending blob
[   4.9401 ] RCM-boot started
/home/xx/code/nvidia/xxa/v11/images/mfi_xxa-v11-64gb-251124
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ......Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
10:45:45.363 - Debug: Debug log saved to /tmp/tmp.we5PfdkdiT.
SSH ready
4194304
00:00:23.962 - Info: Serial Number: 1422125066920
00:00:24.008 - Info: Starting to create the GPT for the eMMC.
00:00:24.028 - Debug: Active index file is /mnt/internal/flash.idx
00:00:24.058 - Debug: Number of lines is 18
00:00:24.095 - Debug: max_index=17
00:00:24.505 - Debug: writing item=1, 1:3:primary_gpt,0,20480,mmcblk0_gptmbr.img,20480,fixed-<reserved>-0,eedfa609d108a44b8df2a000cb4ab8494ded48e3
00:00:51.542 - Debug: Writing primary_gpt partition with mmcblk0_gptmbr.img
00:00:52.264 - Debug: 20480 bytes from /mnt/internal/mmcblk0_gptmbr.img to /dev/mmcblk0: 1KB block=20 remainder=0
00:00:52.269 - Debug: dd if=/mnt/internal/mmcblk0_gptmbr.img of=/dev/mmcblk0 bs=1K skip=0  seek=0 count=20
20+0 records in
20+0 records out
20480 bytes (20 kB, 20 KiB) copied, 0.0033471 s, 6.1 MB/s
00:00:52.312 - Debug: Writing primary_gpt partition done
00:00:52.578 - Debug: Writing secondary_gpt partition with mmcblk0_gptbackup.img
00:00:53.653 - Debug: Offset is not aligned to K Bytes, no optimization is applied
00:00:53.657 - Debug: dd if=/mnt/internal/mmcblk0_gptbackup.img of=/dev/mmcblk0 bs=1 skip=0  seek=63585631744 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0229961 s, 735 kB/s
00:00:53.686 - Debug: Writing secondary_gpt partition done
00:00:54.105 - Info: Successfully created the GPT for the eMMC.
00:00:54.125 - Info: Starting to flash the eMMC.
00:00:54.126 - Debug: Flash index file is /mnt/internal/flash.idx
00:00:54.129 - Debug: Active index file is /mnt/internal/flash.idx
00:00:54.130 - Debug: Number of lines is 18
00:00:54.134 - Debug: max_index=17
00:00:54.146 - Info: Starting to flash the QSPI.
QSPI storage size: 67108864 bytes.
00:00:54.133 - Debug: Number of lines is 18
00:00:54.175 - Debug: max_index=17
00:00:54.200 - Debug: writing item=1, 1:3:primary_gpt,0,20480,mmcblk0_gptmbr.img,20480,fixed-<reserved>-0,eedfa609d108a44b8df2a000cb4ab8494ded48e3
00:00:54.214 - Debug: writing item=2, 1:3:secondary_gpt,63585631744,16896,mmcblk0_gptbackup.img,16896,fixed-<reserved>-0,8637d8cff9753cf579688962d29059af09ff94ca
00:00:54.227 - Debug: writing item=3, 1:3:APP,0,62024003584,mmcblk0p1_bak.img,62024003584,fixed-<reserved>-1,c631908efd3ea1d1aa9beb8df200246023b5e3ba
00:00:54.966 - Debug: Formatting APP partition /dev/mmcblk0p1 ...
mke2fs 1.46.5 (30-Dec-2021)
Discarding device blocks: done
Creating filesystem with 15142579 4k blocks and 3792896 inodes
Filesystem UUID: 0f2330c1-eb6b-461f-8dbb-6638d671f11f
Superblock backups stored on blocks:
        32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
        4096000, 7962624, 11239424
Allocating group tables: done
Writing inode tables: done
Creating journal (65536 blocks): done
Writing superblocks and filesystem accounting information: done
00:01:06.164 - Debug: Formatting APP parition done
00:01:06.289 - Debug: Formatting APP partition /dev/mmcblk0p1 ...
" -x -I 'zstd -T0' -pf /mnt/internal/mmcblk0p1_bak.img  --warning=no-timestamp --numeric-owner --xattrs --xattrs-include=*  -C  /tmp/ci-DY8X7mVKFk
MEMERASE: Input/output error
Uart log:
[   54.204151] 00:00:54.200 - Debug: writing item=1, 1:3:primary_gpt,0,20480,mmcblk0_gptmbr.img,20480,fixed-<reserved>-0,eedfa609d108a44b8df2a000cb4ab8494ded48e3
[   54.204151]
[   54.217528] 00:00:54.214 - Debug: writing item=2, 1:3:secondary_gpt,63585631744,16896,mmcblk0_gptbackup.img,16896,fixed-<reserved>-0,8637d8cff9753cf579688962d29059af09ff94ca
[   54.217528]
[   54.230812] 00:00:54.227 - Debug: writing item=3, 1:3:APP,0,62024003584,mmcblk0p1_bak.img,62024003584,fixed-<reserved>-1,c631908efd3ea1d1aa9beb8df200246023b5e3ba
[   54.230812]
[   54.969882] 00:00:54.966 - Debug: Formatting APP partition /dev/mmcblk0p1 ...
bash-5.1# [   66.168946] 00:01:06.164 - Debug: Formatting APP parition done
[   66.287786] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[   66.293069] 00:01:06.289 - Debug: Formatting APP partition /dev/mmcblk0p1 ...
[  117.917581] ------------[ cut here ]------------
[  117.917589] WARNING: CPU: 2 PID: 876 at /home/xx/code/nvidia/xxa/v11/Linux_for_Tegra/source/kernel_out/nvidia-oot/drivers/spi/spi-tegra210-quad.c:1406 tegra_qspi_transfer_one_message+0x36c/0x7b4 [spi_tegra210_quad]
[  117.917610] Modules linked in: usb_f_rndis u_ether spi_tegra210_quad(O) tegra_mce(O) stusb160x nvethernet(O) nvpps(O) ipv6 tegra_xudc ucsi_ccg typec_ucsi typec libcomposite pwm_fan pwm_tegra tegra_bpmp_thermal nvme nvme_core pcie_tegra194 phy_tegra194_p2u r8168(O)
[  117.917633] CPU: 2 PID: 876 Comm: mtd_debug Tainted: G           O      5.15.148-tegra #1
[  117.917636] Hardware name: NVIDIA NAMTSO xxA/Jetson, BIOS 36.4.4-gcid-41062509 06/16/2025
[  117.917638] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[  117.917641] pc : tegra_qspi_transfer_one_message+0x36c/0x7b4 [spi_tegra210_quad]
[  117.917644] lr : tegra_qspi_transfer_one_message+0x2d0/0x7b4 [spi_tegra210_quad]
[  117.917646] sp : ffff80000e1535a0
[  117.917647] x29: ffff80000e1535a0 x28: ffff00008f316c80 x27: ffff000f695d26d0
[  117.917649] x26: ffff80000e153848 x25: 0000000000000000 x24: ffff000f695d2600
[  117.917651] x23: ffff000f695d2000 x22: ffff000f695d3800 x21: 0000000000000000
[  117.917653] x20: ffff80000e153750 x19: ffff80000e153848 x18: 0000000000000000
[  117.917655] x17: 000000040044ffff x16: 005000f5b5503510 x15: 0000000000000000
[  117.917658] x14: ffff0000801dcd80 x13: ffff56a6f20a9000 x12: 00000000b464d91d
[  117.917660] x11: 0000000000000000 x10: ab6bfff3632ce41a x9 : f4397b68d8270096
[  117.917662] x8 : ffff00008f317bd8 x7 : 0000000000000003 x6 : 00000000eece0f29
[  117.917664] x5 : 00000000410fd420 x4 : 0000000000c0000e x3 : 0000000000000000
[  117.917667] x2 : 0000000000000000 x1 : 0000000000000000 x0 : 0000000000000000
[  117.917670] Call trace:
[  117.917672]  tegra_qspi_transfer_one_message+0x36c/0x7b4 [spi_tegra210_quad]
[  117.917674]  __spi_pump_messages+0x384/0x7f0
[  117.917689]  __spi_sync+0x2d0/0x310
[  117.917693]  spi_sync+0x3c/0x60
[  117.917695]  spi_mem_exec_op+0x30c/0x440
[  117.917698]  spi_nor_read_sr+0xa8/0x140
[  117.917703]  spi_nor_wait_till_ready_with_timeout+0xc0/0x460
[  117.917706]  spi_nor_erase+0x218/0x640
[  117.917707]  mtd_erase+0x118/0x1d0
[  117.917712]  mtdchar_ioctl+0xf08/0x1000
[  117.917715]  mtdchar_unlocked_ioctl+0x60/0xe0
[  117.917718]  __arm64_sys_ioctl+0xb4/0x100
[  117.917722]  invoke_syscall+0x5c/0x130
[  117.917727]  el0_svc_common.constprop.0+0x64/0x110
[  117.917730]  do_el0_svc+0x74/0xa0
[  117.917732]  el0_svc+0x28/0x80
[  117.917737]  el0t_64_sync_handler+0xa4/0x130
[  117.917738]  el0t_64_sync+0x1a4/0x1a8
[  117.917741] ---[ end trace 612eb88f23658d66 ]---
[  118.922659] tegra-qspi 3270000.spi: transfer timeout
[  118.922661] tegra-qspi 3270000.spi: error in transfer, fifo status 0x00c00004
[  118.923057] spi_master spi0: failed to transfer one message from queue
This issue occurs intermittently (it is probabilistic). How can I resolve this?
Any update on this issue?
Please provide the full log (flashing log/uart log) for us to review.
Hello @DavidDDD
Please check the logs:
Flashing log:
agx-orin-restore-error-flash-tool-251203.txt
Uart log:
agx-orin-restore-error-uart-debug-log-251203.txt (67.2 KB)
Any update?
Please try using the developer kit instead of the custom carrier board and check if the issue persists.
Hello @DavidDDD
I have not been able to reproduce this issue on the Jetson AGX Orin DevKit so far.
If this is an issue with our custom board, how should I proceed with troubleshooting? Since the SPI Flash is located on the AGX Orin module itself, rather than on our custom carrier board, how should we approach solving this?
Do you build your own custom kernel image for your custom board?
Yes, we build the custom kernel image.
You need to build the OOT after building the custom kernel.
Did you follow the developer guide to build the OOT?
Yes, I follow the docs to build all source code.
Any update?
If I use `flash.sh` to flash the image there will be no issues.
sudo ./flash.sh my_board internal
But we need to fix the backup/restore issues for mass flash.
Anyone can help ?
Please try using initrd script to check whether issue exists.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh jetson-agx-orin-devkit mmcblk0p1
Hello @DavidDDD
I got the same error with `sudo ./tools/kernel_flash/l4t_initrd_flash.sh jetson-agx-orin-devkit mmcblk0p1`
[   59.837978] ------------[ cut here ]------------
[   59.837986] WARNING: CPU: 2 PID: 2307 at /home/nick/code/nvidia/nd004a/v11/Linux_for_Tegra/source/kernel_out/nvidia-oot/drivers/spi/spi-tegra210-quad.c:1406 tegra_qspi_transfer_one_message+0x36c/0x7b4 [spi_tegra210_quad]a
[   59.838003] Modules linked in: usb_f_rndis(E) u_ether(E) spi_tegra210_quad(OE) tegra_mce(OE) stusb160x(E) nvethernet(OE) nvpps(OE) ipv6(E) tegra_xudc(E) ucsi_ccg(E) typec_ucsi(E) typec(E) libcomposite(E) pwm_fan(E) pwm_tegra(E) tegra_bpmp_thermal(E) nvme(E) nvme_core(E) pcie_tegra194(E) phy_tegra194_p2u(E) r8168(OE)
[   59.838027] CPU: 2 PID: 2307 Comm: mtd_debug Tainted: G           OE     5.15.148-tegra #1
[   59.838030] Hardware name: NVIDIA NAMTSO ND004A/Jetson, BIOS 36.4.4-gcid-41062509 06/16/2025
[   59.838032] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[   59.838034] pc : tegra_qspi_transfer_one_message+0x36c/0x7b4 [spi_tegra210_quad]
[   59.838037] lr : tegra_qspi_transfer_one_message+0x2d0/0x7b4 [spi_tegra210_quad]
[   59.838039] sp : ffff80000fcf35a0
[   59.838040] x29: ffff80000fcf35a0 x28: ffff0000809f5d00 x27: ffff00076b7a86d0
[   59.838042] x26: ffff80000fcf3848 x25: 0000000000000000 x24: ffff00076b7a8600
[   59.838044] x23: ffff00076b7a8000 x22: ffff0000829fb000 x21: 0000000000000000
[   59.838046] x20: ffff80000fcf3750 x19: ffff80000fcf3848 x18: 0000000000000000
[   59.838048] x17: 0000000000000000 x16: ffffcc4c74cb1920 x15: 0000000000000003
[   59.838049] x14: ffff33bb23417000 x13: 0000000000000000 x12: 0000000000000400
[   59.838051] x11: 0000000000003700 x10: df222123e3d9358f x9 : 9d8ff96617f712ab
[   59.838053] x8 : ffff0000809f6c58 x7 : 000000000000b67e x6 : 0000000080f4170e
[   59.838055] x5 : 00000000410fd420 x4 : 0000000000c0000e x3 : 0000000000000000
[   59.838057] x2 : 0000000000000000 x1 : 0000000000000000 x0 : 0000000000000000
[   59.838060] Call trace:
[   59.838062]  tegra_qspi_transfer_one_message+0x36c/0x7b4 [spi_tegra210_quad]
[   59.838064]  __spi_pump_messages+0x384/0x7f0
[   59.838076]  __spi_sync+0x2d0/0x310
[   59.838079]  spi_sync+0x3c/0x60
[   59.838081]  spi_mem_exec_op+0x30c/0x440
[   59.838084]  spi_nor_read_sr+0xa8/0x140
[   59.838088]  spi_nor_wait_till_ready_with_timeout+0xc0/0x460
[   59.838090]  spi_nor_erase+0x218/0x640
[   59.838092]  mtd_erase+0x118/0x1d0
[   59.838095]  mtdchar_ioctl+0xf08/0x1000
[   59.838098]  mtdchar_unlocked_ioctl+0x60/0xe0
[   59.838100]  __arm64_sys_ioctl+0xb4/0x100
[   59.838104]  invoke_syscall+0x5c/0x130
[   59.838109]  el0_svc_common.constprop.0+0x64/0x110
[   59.838112]  do_el0_svc+0x74/0xa0
[   59.838114]  el0_svc+0x28/0x80
[   59.838118]  el0t_64_sync_handler+0xa4/0x130
[   59.838120]  el0t_64_sync+0x1a4/0x1a8
[   59.838123] ---[ end trace b50f5183eeffff0b ]---
[   60.843298] tegra-qspi 3270000.spi: transfer timeout
[   60.843306] tegra-qspi 3270000.spi: error in transfer, fifo status 0x00c00004
[   60.843692] spi_master spi0: failed to transfer one message from queue
Uart log:
agx-orin-initrd-flash-error-uart-debug-log-251211.txt (87.0 KB)
Flash tool:
agx-orin-initrd-flash-error-flash-tool-251211.txt (247.0 KB)
Hello @DavidDDD
I have change the spi driver to fix this issue, now it looks has no spi errors.
But I found other issues that the initrd flash is not stable, it sometimes will also fail.
What’s the suggested way for mass production flashing ?
Any update?
Hi
Are the UART log and flash log the same as the ones you provided earlier?
If not, please provide the latest logs.
Hello @DavidDDD
Upon further investigation, I found that the flashing process is not failing; rather, the USB RNDIS speed has slowed down, causing the flashing time to increase significantly.
We are using a custom carrier board, and the USB OTG is configured as USB 2.0. Under normal conditions, the initrd flash USB speed is around 20MB/s, resulting in a fast restore process where everything works as expected.
However, sometimes the initrd flash USB speed drops to only about 4MB/s, making the restore process extremely slow. Do you know why this might be happening?
Normal Speed:
Abnormal Speed:
Have all USB relevant compliace test passed?
