AGX Orin camera different csi interface hardware differences
Hello,nv team
During the development of Jetson Orin Camera, we found that CSI6/7 has many more problems than CSI0/1/2/3/4/5.
For example, when CSI6/7 is connected to two 8M-YUV(max96712) cameras at the same time, the probability of failure to receive picture and show bad frames is much higher than that of other ports.
Although our hardware engineers have made a lot of efforts to optimize the CSI6/7 port, which is higher than the requirements of the hardware reference manual.
So I want to ask what is the difference between Orin CSI6/7 and other ports?
Current issues:(Sometimes it will time out)
type or paste code here
     kworker/4:2-141     [004] ....   320.007096: rtcpu_nvcsi_intr: tstamp:10763377743 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007096: rtcpu_nvcsi_intr: tstamp:10763378316 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007096: rtcpu_nvcsi_intr: tstamp:10763378316 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000002
     kworker/4:2-141     [004] ....   320.007097: rtcpu_nvcsi_intr: tstamp:10763378316 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007097: rtcpu_nvcsi_intr: tstamp:10763378316 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000002
     kworker/4:2-141     [004] ....   320.007097: rtcpu_nvcsi_intr: tstamp:10763379172 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007098: rtcpu_nvcsi_intr: tstamp:10763379172 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007098: rtcpu_nvcsi_intr: tstamp:10763379721 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007099: rtcpu_nvcsi_intr: tstamp:10763379721 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007099: rtcpu_nvcsi_intr: tstamp:10763380265 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007099: rtcpu_nvcsi_intr: tstamp:10763380265 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007100: rtcpu_nvcsi_intr: tstamp:10763380814 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007100: rtcpu_nvcsi_intr: tstamp:10763380814 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007100: rtcpu_nvcsi_intr: tstamp:10763381362 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007101: rtcpu_nvcsi_intr: tstamp:10763381362 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007101: rtcpu_nvcsi_intr: tstamp:10763381982 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007102: rtcpu_nvcsi_intr: tstamp:10763381982 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007102: rtcpu_nvcsi_intr: tstamp:10763382529 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007102: rtcpu_nvcsi_intr: tstamp:10763382529 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007103: rtcpu_nvcsi_intr: tstamp:10763383078 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007103: rtcpu_nvcsi_intr: tstamp:10763383078 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007103: rtcpu_nvcsi_intr: tstamp:10763383629 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007104: rtcpu_nvcsi_intr: tstamp:10763383629 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007104: rtcpu_nvcsi_intr: tstamp:10763384180 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007105: rtcpu_nvcsi_intr: tstamp:10763384180 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
     kworker/4:2-141     [004] ....   320.007105: rtcpu_nvcsi_intr: tstamp:10763384732 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
Suppose there’s no differene for all CSI port.
What’s your BSP version?
Do you check latest release?
bsp version:jetpack 5.0.1 \5.1.1\ 6.0(ga)
No one replied to me,this problem has always existed.
It’s CPHY or DPHY? Decrease the speed help on it?
(1)DPHY
(2)Dual 8m-camera requires at least 2.3g/lane x 4, so I can’t slow down.
Please update to r35.5 to confirm if update RCE firmware help on your case.
