Hi @KevinFFF,
thanks for the quick reply! I indeed missed step 8, so now I can actually see the prints I added to the function. Unfortunately, after the down&up, the cangen can0 runs for a little while and then shows the “no buffer space available” error again.
Here’s the output when I’m following your steps:
$ sudo modprobe mttcan
$ sudo ip link set can0 up type can bitrate 100000 berr-reporting on restart-ms 1000
RTNETLINK answers: Device or resource busy
# don't know if above error is a problem?
$ cangen can0
# runs fine, now short CAN-H/CAN-L
write: No buffer space available
# ... stop shorting
$ sudo ip -d -s link show can0
12: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10
link/can promiscuity 0 minmtu 0 maxmtu 0
can <BERR-REPORTING> state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 1000
bitrate 500000 sample-point 0.870
tq 20 prop-seg 43 phase-seg1 43 phase-seg2 13 sjw 1
mttcan: tseg1 2..255 tseg2 0..127 sjw 1..127 brp 1..511 brp-inc 1
mttcan: dtseg1 1..31 dtseg2 0..15 dsjw 1..15 dbrp 1..15 dbrp-inc 1
clock 50000000
re-started bus-errors arbit-lost error-warn error-pass bus-off
2 6 0 2 2 2 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
RX: bytes packets errors dropped overrun mcast
4980525 689926 6 0 0 0
TX: bytes packets errors dropped carrier collsns
1129 198 0 0 0 0
$ cangen can0
$ sudo ip link set can0 down
$ cangen can0
# runs for a couple of seconds but then prints this again
When looking at dmesg, you can see that the patch is there (I printed each line):
$ sudo dmesg
[ 3430.899903] mttcan c310000.mttcan can0: entered error warning state
[ 3430.906431] mttcan c310000.mttcan can0: entered error passive state
[ 3430.912903] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 3430.918664] mttcan c310000.mttcan can0: IR 0x9800000 PSR 0x77d
[ 3430.924713] mttcan c310000.mttcan can0: entered bus off state
[ 3430.931473] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 3430.937252] mttcan c310000.mttcan can0: IR 0xa000000 PSR 0x7e5
[ 3431.950397] mttcan_controller_config: ctrlmode 10
[ 3431.950423] mttcan c310000.mttcan can0: Bitrate set
[ 3431.950434] mttcan c310000.mttcan can0: wait for bus off seq
[ 3431.962506] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 3431.968252] mttcan c310000.mttcan can0: IR 0xa000000 PSR 0x70d
[ 3431.974301] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
[ 3432.101006] mttcan c310000.mttcan can0: entered error warning state
[ 3432.107504] mttcan c310000.mttcan can0: entered error passive state
[ 3432.113967] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 3432.119722] mttcan c310000.mttcan can0: IR 0x9800000 PSR 0x76d
[ 3432.125776] mttcan c310000.mttcan can0: entered bus off state
[ 3432.132509] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 3432.138261] mttcan c310000.mttcan can0: IR 0xa010000 PSR 0x7e5
[ 3433.134369] mttcan_controller_config: ctrlmode 10
[ 3433.134393] mttcan c310000.mttcan can0: Bitrate set
[ 3433.134405] mttcan c310000.mttcan can0: wait for bus off seq
[ 3433.146486] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 3433.152251] mttcan c310000.mttcan can0: IR 0xa000000 PSR 0x70d
[ 3433.158320] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
[ 3562.140557] mttcan c310000.mttcan can0: inside mttcan_close: netif_stop_queue(dev);
[ 3562.140564] mttcan c310000.mttcan can0: inside mttcan_close: napi_disable(&priv->napi);
[ 3562.140567] mttcan c310000.mttcan can0: inside mttcan_close: mttcan_stop(priv);
[ 3562.140581] mttcan c310000.mttcan can0: inside mttcan_close: free_irq(dev->irq, dev);
[ 3562.140598] mttcan c310000.mttcan can0: inside mttcan_close: priv->ttcan->tx_object = 0;
[ 3562.140600] mttcan c310000.mttcan can0: inside mttcan_close: priv->hwts_rx_en = false;
[ 3576.107601] mttcan c310000.mttcan can0: Bitrate set
[ 3576.107672] mttcan_controller_config: ctrlmode 10
[ 3576.107685] mttcan c310000.mttcan can0: Bitrate set
[ 3576.107747] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
So not sure why it does not work for us…
