Dear ALL,
I am using the AGX Orin and AGX Orin Industrial modules, and the upper operating temperature of both modules exceeds 80 ° C under the datasheet. However, I found that when the temperature reached 55℃, the module could not be turned on. The temperature went down and returned to normal.
I saw in the forum that TX1 has a default protection temperature. Does AGX Orin have the same default protection temperature as TX1? Is there a patch that can lift this restriction?
Thank you for your reply, I am using the customized carrier board, L4T 35.5.
I tested it, and after two hours at 55 ° C, it won’t start. When the temperature drops, it becomes normal.
Yes, I’m using the AGX Orin Industrial module. I have used the SDKManager reflash module and the SDK version is 5.1.3.
I’m not connected to the screen right now. You mentioned ‘enable UEFI logs’, is it in the UEFI menu? So I have to press the ESC key when the device is turned on?
I don’t know how many log files are in there. Can you tell me in advance which log I should get?
