Hi everyone,
I use the command clone Orin image failed, the command is sudo ./flash.sh -r -k APP -G clone.img jetson-agx-orin-devkit mmcblk0p1
the failed log is
Copying nv_boot_control.conf to rootfs Skip generating system.img
Existing tbcfile(/home/ubuntu/work/JetPacks/JetPack5.0/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
Skip generating EFI system partition image.
EFI system partition image (esp.img) not found.
