Hardware Platform (Jetson / GPU) : Nvidia AGX Orin [64GB Developer kit]
Issue Type(questions, new requirements, bugs) : Bugs
I am trying to run the Yolo Pose detection with Jetpack 6.3 and Deepstream 7.1 but I keep getting this error and the application doesn’t keep running for 30 minutes and keeps crashing on random intervals. Whereas, the application runs fine without any crash in Jetpack 5.1 and Deepstream 6.3.
- Set nvvideoconvert property to ‘disable-passthrough’=1 as suggested in the forum.(Error: unable to draw shapes onto video frame by GPU when asked to draw bbox on multi-sink - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums)
- Found the same error as we are getting in forum but still the issue hasn’t been resolved(Cuda Error Illegal Address - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums)
- Tried different input FPS from Webcam (i.e 5,10,15,25) but still crashing for all combination.
- Tried with different trackers of Deepstream.
- Checked if we were running out of memory but the memory access was constant around 2 to 3.5 GB
There are two types of error i am getting randomly
1.
ERROR: Failed to make stream wait on event, cuda err_no:700, err_str:cudaErrorIllegalAddress
libnvosd (1386):(ERROR) : cuGraphicsEGLRegisterImage failed : 700
ERROR: Preprocessor transform input data failed., nvinfer error:NVDSINFER_CUDA_ERROR
0:06:10.250301857 332222 0xaaaadd1abd80 WARN nvinfer gstnvinfer.cpp:1420:gst_nvinfer_input_queue_loop:<pgie> error: Failed to queue input batch for inferencing
ERROR: gst-resource-error-quark: Unable to draw shapes onto video frame by GPU (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvdsosd/gstnvdsosd.c(645): gst_nvds_osd_transform_ip (): /GstPipeline:pipeline0/GstNvDsOsd:nvdsosd
GPUassert: an illegal memory access was encountered /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvmultiobjecttracker/src/modules/cuDCFv2/cuDCFFrameTransformTexture.cu 611
!![Exception] GPUassert failed
An exception occurred. GPUassert failed
gstnvtracker: Low-level tracker lib returned error 1
CUDA Runtime error cudaFreeHost(host_) # an illegal memory access was encountered, code = cudaErrorIllegalAddress [ 700 ] in file /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvll_osd/memory.hpp:78
CUDA Runtime error cudaFree(device_) # an illegal memory access was encountered, code = cudaErrorIllegalAddress [ 700 ] in file /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvll_osd/memory.hpp:79
track_keypoints1 {}
2.
0:00:39.962909330 262869 0xaaab1480d980 WARN nvinfer gstnvinfer.cpp:1420:gst_nvinfer_input_queue_loop:<pgie> error: Failed to queue input batch for inferencing
ERROR: gst-stream-error-quark: Failed to queue input batch for inferencing (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1420): gst_nvinfer_input_queue_loop (): /GstPipeline:pipeline0/GstNvInfer:pgie
[WARN ] 2025-03-12 15:31:23 (cudaErrorIllegalAddress)
[ERROR] 2025-03-12 15:31:23 Error destroying cuda device:
[ERROR] 2025-03-12 15:31:23 Error destroying cuda device: nN
terminate called after throwing an instance of 'nv::cuda::RuntimeException'
what(): cudaErrorIllegalAddress:
Aborted (core dumped)
