AGX Orin Developer Kit - M.2 Key-M slot does not train, no NVMe detected
NVIDIA Customer Care (incident 260731-000054) asked us to open a thread here so
the Jetson team can confirm whether this unit requires an RMA.
Device:
Part number:   945-13730-0055-000
Serial number: 1795225101003
L4T:           R36.5.0 (JetPack 6), kernel 5.15.185-tegra
Shipped:       2026-01-27
This is one of two AGX Orin Developer Kits awarded to our group through NVIDIA’s
academic hardware grant (Robotics and Edge AI track), so there is no retail
purchase behind it.
Problem:
The M.2 Key-M slot on this unit does not recognise any NVMe SSD we have tried.
No block device appears and no PCIe endpoint is enumerated on that slot.
The board is otherwise functional: it boots normally from eMMC, and the M.2
Key-E slot enumerates its Wi-Fi card without any issues.
Testing performed:
We tried several different NVMe drives in the M.2 Key-M slot of this unit -
none were detected. To rule out the drives themselves, we tested the same
drives in our second AGX Orin Developer Kit, running the same L4T version,
where they worked without any issues. This points to a fault in the M.2 slot
rather than the drives.
Diagnostics (SSD inserted in the M.2 Key-M slot):
PCIe link training, from the kernel log of the current boot:
tegra194-pcie 14100000.pcie: Link up
tegra194-pcie 14160000.pcie: Phy link never came up
tegra194-pcie 141a0000.pcie: Phy link never came up
Only the x1 controller, which carries the Key-E Wi-Fi card, trains a link.
Neither x4 controller does. Please let us know which of the two corresponds to
the M.2 Key-M slot on this carrier board if that is relevant for the diagnosis.
Device-tree state (from /proc/device-tree/bus@0/pcie@*/status and num-lanes);
every other PCIe controller on this board is disabled:
pcie@14100000   status=okay   lanes=1
pcie@14160000   status=okay   lanes=4
pcie@141a0000   status=okay   lanes=4
lspci shows only the root bridge and the Wi-Fi adapter, no NVMe controller:
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1)
0001:01:00.0 Network controller: Realtek RTL8822CE
With a known-good SSD in the slot, no PCIe endpoint is enumerated, no
/dev/nvme* device is created, and the system runs entirely from the 57 GB eMMC.
Can you confirm whether this is a hardware fault requiring an RMA? We are happy
to run any further diagnostics or provide the full dmesg output if that would
help.
Thank you,
Clara
~0930
Is same NVMe able to get detected when you put it on another NV devkit?
Is this devkit not able to detect any M.2 SSD since day 1?
