AGX Orin devkit shuts down when trying to reboot
Hi, My AGX Orin devkit shuts down when I try to reboot it from the command line (I use sudo reboot now). I need to manually power it on for it to come online. This has happened 10-15 times in the past week. Is this a known issue? Is there a solution to this?
Maybe you could enable the uart print and see what got printed when such issue happened.
Thanks, will try this out.
