Hi Jetson Teams,
We designed the carrier board based on AGX Orin by ourselves. Our test team found in the process of power failure and restart that the system based on Jetpack 5.x or Jetpack 6.x could not be started after restarting 700+, and the Image needed to be re-burned.
This is the Boot log for jetpack 5.x
[0000.062] I> MB1 (version: 1.4.0.1-t234-54845784-08e631ca)
[0000.067] I> t234-A01-0-Silicon (0x12347) Prod
[0000.071] I> Boot-mode : Coldboot
[0000.075] I> Entry timestamp: 0x00000000
[0000.078] I> last_boot_error: 0x0
[0000.082] I> BR-BCT: preprod_dev_sign: 0
[0000.085] I> rst_source: 0x0, rst_level: 0x0
[0000.089] I> Task: SE error check
[0000.093] I> Task: Bootchain select WAR set
[0000.097] I> Task: Enable SLCG
[0000.099] I> Task: CRC check
[0000.102] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0000.109] I> Task: Initialize MB2 params
[0000.114] I> MB2-params @ 0x40060000
[0000.117] I> Task: Crypto init
[0000.120] I> Task: Perform MB1 KAT tests
[0000.124] I> Task: NVRNG health check
[0000.127] I> NVRNG: Health check success
[0000.131] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.137] I> Task: Enabling and initialization of Bandwidth limiter
[0000.143] I> No request to configure MBWT settings for any PC!
[0000.149] I> Task: Secure debug controls
[0000.153] I> Task: strap war set
[0000.156] I> Task: Initialize SOC Therm
[0000.160] I> Task: Program NV master stream id
[0000.164] I> Task: Verify boot mode
[0000.170] I> Task: Alias fuses
[0000.173] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.180] I> Task: Print SKU type
[0000.183] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.188] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.192] I> FUSE_OPT_TPC_DISABLE = 0x00000004
[0000.197] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.201] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.205] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.210] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.214] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.218] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.223] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.227] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.231] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.235] I> FUSE_SKU_INFO_0 = 0xd2
[0000.238] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.243] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.246] I> SKU: Prod
[0000.248] I> Task: Boost clocks
[0000.251] I> Initializing PLLC2 for AXI_CBB.
[0000.256] I> AXI_CBB : src = 35, divisor = 0
[0000.260] I> Task: Voltage monitor
[0000.263] I> VMON: Vmon re-calibration and fine tuning done
[0000.268] I> Task: UPHY init
[0000.273] I> HSIO UPHY init done
[0000.276] W> Skipping GBE UPHY config
[0000.280] I> Task: Boot device init
[0000.283] I> Boot_device: QSPI_FLASH instance: 0
[0000.288] I> Qspi clock source : pllc_out0
[0000.292] I> QSPI Flash: Macronix 64MB
[0000.296] I> QSPI-0l initialized successfully
[0000.300] I> Task: TSC init
[0000.303] I> Task: Load membct
[0000.305] I> RAM_CODE 0x4000401
[0000.309] I> Loading MEMBCT
[0000.311] I> Slot: 0
[0000.313] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.319] I> Binary name: MEM-BCT-0
[0000.322] I> Size of crypto header is 8192
[0000.326] I> Size of crypto header is 8192
[0000.330] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.336] I> BCH of MEM-BCT-0 read from storage
[0000.340] I> BCH address is : 0x40050000
[0000.344] I> MEM-BCT-0 header integrity check is success
[0000.350] I> Binary magic in BCH component 0 is MEM0
[0000.354] I> component binary type is 0
[0000.358] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.365] I> MEM-BCT-0 binary is read from storage
[0000.370] I> MEM-BCT-0 binary integrity check is success
[0000.375] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.381] I> RAM_CODE 0x4000401
[0000.387] I> RAM_CODE 0x4000401
[0000.391] I> Task: Load Page retirement list
[0000.395] I> Task: SDRAM params override
[0000.398] I> Task: Save mem-bct info
[0000.402] I> Task: Carveout allocate
[0000.405] I> RCM blob carveout will not be allocated
[0000.410] I> Update CCPLEX IST carveout from MB1-BCT
[0000.415] I> ECC region[0]: Start:0x0, End:0x0
[0000.419] I> ECC region[1]: Start:0x0, End:0x0
[0000.424] I> ECC region[2]: Start:0x0, End:0x0
[0000.428] I> ECC region[3]: Start:0x0, End:0x0
[0000.432] I> ECC region[4]: Start:0x0, End:0x0
[0000.436] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0000.442] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.447] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.452] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.456] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.467] I> allocated(CO:44) base:0x849800000 size:0x36800000 align: 0x100000
[0000.474] I> allocated(CO:31) base:0x840000000 size:0x8000000 align: 0x8000000
[0000.481] I> allocated(CO:43) base:0x83c000000 size:0x4000000 align: 0x200000
[0000.488] I> allocated(CO:39) base:0x839e00000 size:0x2200000 align: 0x10000
[0000.495] I> allocated(CO:20) base:0x836000000 size:0x2000000 align: 0x2000000
[0000.502] I> allocated(CO:24) base:0x834000000 size:0x2000000 align: 0x2000000
[0000.509] I> allocated(CO:28) base:0x832000000 size:0x2000000 align: 0x2000000
[0000.516] I> allocated(CO:29) base:0x830000000 size:0x2000000 align: 0x2000000
[0000.524] I> allocated(CO:22) base:0x848000000 size:0x1000000 align: 0x1000000
[0000.531] I> allocated(CO:41) base:0x838e00000 size:0x1000000 align: 0x100000
[0000.538] I> allocated(CO:35) base:0x838000000 size:0xe00000 align: 0x10000
[0000.545] I> allocated(CO:02) base:0x849000000 size:0x800000 align: 0x800000
[0000.552] I> allocated(CO:03) base:0x82f800000 size:0x800000 align: 0x800000
[0000.558] I> allocated(CO:06) base:0x82f000000 size:0x800000 align: 0x800000
[0000.565] I> allocated(CO:56) base:0x82e800000 size:0x800000 align: 0x200000
[0000.572] I> allocated(CO:07) base:0x82e400000 size:0x400000 align: 0x400000
[0000.579] I> allocated(CO:33) base:0x82e000000 size:0x400000 align: 0x200000
[0000.586] I> allocated(CO:23) base:0x82de00000 size:0x200000 align: 0x200000
[0000.593] I> allocated(CO:01) base:0x82dd00000 size:0x100000 align: 0x100000
[0000.600] I> allocated(CO:05) base:0x82dc00000 size:0x100000 align: 0x100000
[0000.607] I> allocated(CO:08) base:0x82db00000 size:0x100000 align: 0x100000
[0000.614] I> allocated(CO:09) base:0x82da00000 size:0x100000 align: 0x100000
[0000.621] I> allocated(CO:15) base:0x82d900000 size:0x100000 align: 0x100000
[0000.628] I> allocated(CO:17) base:0x82d800000 size:0x100000 align: 0x100000
[0000.635] I> allocated(CO:27) base:0x82d700000 size:0x100000 align: 0x100000
[0000.642] I> allocated(CO:42) base:0x82d600000 size:0x100000 align: 0x100000
[0000.649] I> allocated(CO:54) base:0x82d580000 size:0x80000 align: 0x80000
[0000.655] I> allocated(CO:34) base:0x82d570000 size:0x10000 align: 0x10000
[0000.662] I> allocated(CO:72) base:0x82d370000 size:0x200000 align: 0x10000
[0000.669] I> allocated(CO:47) base:0x82ce00000 size:0x400000 align: 0x200000
[0000.676] I> allocated(CO:48) base:0x82d350000 size:0x20000 align: 0x10000
[0000.683] I> allocated(CO:69) base:0x82d330000 size:0x20000 align: 0x10000
[0000.690] I> allocated(CO:49) base:0x82d320000 size:0x10000 align: 0x10000
[0000.696] I> allocated(CO:50) base:0x82d310000 size:0x10000 align: 0x10000
[0000.703] I> allocated(CO:52) base:0x82d300000 size:0x10000 align: 0x10000
[0000.710] I> NSDRAM base: 0x80000000, end: 0x82d370000, size: 0x7ad370000
[0000.717] I> Task: Thermal check
[0000.720] I> max_chip_limit = 105
[0000.723] I> min_chip_limit = -28
[0000.726] I> max temp read = 41
[0000.729] I> min temp read = 40
[0000.732] I> Task: Update FSI SCR with thermal fuse data
[0000.737] I> Task: Enable WDT 5th expiry
[0000.741] I> Task: I2C register
[0000.744] I> Task: Set I2C bus freq
[0000.747] I> Task: Reset FSI
[0000.750] I> Task: Pinmux init
[0000.753] I> Task: Prod config init
[0000.757] I> Task: Pad voltage init
[0000.760] I> Task: Prod init
[0000.763] I> Task: Program rst req config reg
[0000.767] I> Task: Common rail init
[0000.770] I> DONE: Thermal config
[0000.774] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.782] I> DONE: SOC rail config
[0000.786] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.792] I> DONE: MEMIO rail config
[0000.796] I> DONE: GPU rail info
[0000.799] I> DONE: CV rail info
[0000.802] I> Task: Mem clock src
[0000.805] I> Task: Misc. board config
[0000.809] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.815] I> Task: SDRAM init
[0000.818] I> MemoryType: 4 MemBctRevision: 9
[0000.824] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 9
[0000.832] I> MSS CAR: Init PLLM
[0000.835] I> MSS CAR: Init PLLHUB
[0000.840] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.851] I> SDRAM initialized!
[0000.854] I> SDRAM Size in Total 0x800000000
[0000.858] I> Task: Dram Ecc scrub
[0000.861] I> Task: DRAM alias check
[0000.878] I> Task: Program NSDRAM carveout
[0000.882] I> NSDRAM carveout encryption is enabled
[0000.886] I> Program NSDRAM carveout
[0000.890] I> Task: Register checker
[0000.894] I> Task: Enable clock-mon
[0000.908] I> FMON: Fmon re-programming done
[0000.912] I> Task: Mapper init
[0000.915] I> Task: SC7 Context Init
[0000.918] I> Task: CCPLEX IST init
[0000.921] I> Task: CPU WP0
[0000.924] I> Loading MCE
[0000.927] I> Slot: 0
[0000.929] I> Binary[8] block-22784 (partition size: 0x80000)
[0000.934] I> Binary name: MCE
[0000.937] I> Size of crypto header is 8192
[0000.941] I> Size of crypto header is 8192
[0000.945] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0000.951] I> BCH of MCE read from storage
[0000.955] I> BCH address is : 0x4003e000
[0000.959] I> MCE header integrity check is success
[0000.964] I> Binary magic in BCH component 0 is MTSM
[0000.969] I> component binary type is 8
[0000.972] I> Size of crypto header is 8192
[0000.976] I> strt_pg_num(22800) num_of_pgs(357) read_buf(0x40000000)
[0000.984] I> MCE binary is read from storage
[0000.989] I> MCE binary integrity check is success
[0000.994] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.000] I> Size of crypto header is 8192
[0001.011] I> Size of crypto header is 8192
[0001.015] I> Sending WP0 mailbox command to PSC
[0001.024] I> Task: XUSB Powergate
[0001.027] I> Skipping powergate XUSB.
[0001.031] I> Task: MB1 fixed firewalls
[0001.037] W> Firewall readback mismatch
[0001.042] I> Task: Load bpmp-fw
[0001.045] I> Slot: 0
[0001.047] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.053] I> Binary name: BPMP_FW
[0001.056] I> Size of crypto header is 8192
[0001.060] I> Size of crypto header is 8192
[0001.064] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.070] I> BCH of BPMP_FW read from storage
[0001.074] I> BCH address is : 0x807fe000
[0001.078] I> BPMP_FW header integrity check is success
[0001.083] I> Binary magic in BCH component 0 is BPMF
[0001.088] I> component binary type is 15
[0001.091] I> Size of crypto header is 8192
[0001.095] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.113] I> BPMP_FW binary is read from storage
[0001.119] I> BPMP_FW binary integrity check is success
[0001.124] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.131] I> Slot: 0
[0001.133] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.138] I> Binary name: BPMP_FW_DTB
[0001.142] I> Size of crypto header is 8192
[0001.146] I> Size of crypto header is 8192
[0001.150] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.156] I> BCH of BPMP_FW_DTB read from storage
[0001.160] I> BCH address is : 0x807fc000
[0001.164] I> BPMP_FW_DTB header integrity check is success
[0001.170] I> Binary magic in BCH component 0 is BPMD
[0001.174] I> component binary type is 16
[0001.178] I> Size of crypto header is 8192
[0001.182] I> strt_pg_num(13072) num_of_pgs(493) read_buf(0x807be5f0)
[0001.191] I> BPMP_FW_DTB binary is read from storage
[0001.196] I> BPMP_FW_DTB binary integrity check is success
[0001.202] I> Binary BPMP_FW_DTB loaded successfully at 0x807be5f0 (0x3d840)
[0001.209] I> Task: BPMP fw ast config
[0001.212] I> Task: Load psc-fw
[0001.215] I> Slot: 0
[0001.217] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.223] I> Binary name: PSC_FW
[0001.226] I> Size of crypto header is 8192
[0001.230] I> Size of crypto header is 8192
[0001.234] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.240] I> BCH of PSC_FW read from storage
[0001.244] I> BCH address is : 0x80ffe000
[0001.248] I> PSC_FW header integrity check is success
[0001.253] I> Binary magic in BCH component 0 is PFWP
[0001.258] I> component binary type is 17
[0001.261] I> Size of crypto header is 8192
[0001.265] I> strt_pg_num(21264) num_of_pgs(717) read_buf(0x80fa4600)
[0001.276] I> PSC_FW binary is read from storage
[0001.281] I> PSC_FW binary integrity check is success
[0001.285] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[0001.292] I> Task: Load nvdec-fw
[0001.295] I> Slot: 0
[0001.297] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.303] I> Binary name: NVDEC
[0001.305] I> Size of crypto header is 8192
[0001.309] I> Size of crypto header is 8192
[0001.313] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.320] I> BCH of NVDEC read from storage
[0001.324] I> BCH address is : 0x800fe000
[0001.327] I> NVDEC header integrity check is success
[0001.332] I> Binary magic in BCH component 0 is NDEC
[0001.337] I> component binary type is 7
[0001.341] I> Size of crypto header is 8192
[0001.345] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.354] I> NVDEC binary is read from storage
[0001.359] I> NVDEC binary integrity check is success
[0001.364] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.370] I> Size of crypto header is 8192
[0001.381] I> Task: Load tsec-fw
[0001.384] I> TSEC-FW load support not enabled
[0001.388] I> Task: GPIO interrupt map
[0001.392] I> Task: SC7 context save
[0001.395] I> Slot: 0
[0001.397] I> Binary[27] block-0 (partition size: 0x100000)
[0001.403] I> Binary name: BR_BCT
[0001.406] I> Size of crypto header is 8192
[0001.410] I> Size of crypto header is 8192
[0001.414] I> Size of crypto header is 8192
[0001.418] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.424] I> BR_BCT binary is read from storage
[0001.428] I> BR_BCT binary integrity check is success
[0001.433] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.439] I> Slot: 0
[0001.441] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.447] I> Binary name: SC7-FW
[0001.450] I> Size of crypto header is 8192
[0001.454] I> Size of crypto header is 8192
[0001.458] I> Size of crypto header is 8192
[0001.462] I> Size of crypto header is 8192
[0001.466] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.472] I> BCH of SC7-FW read from storage
[0001.476] I> BCH address is : 0xa0002000
[0001.480] I> SC7-FW header integrity check is success
[0001.485] I> Binary magic in BCH component 0 is WB0B
[0001.489] I> component binary type is 13
[0001.493] I> Size of crypto header is 8192
[0001.497] I> strt_pg_num(23824) num_of_pgs(347) read_buf(0xa0004000)
[0001.505] I> SC7-FW binary is read from storage
[0001.510] I> SC7-FW binary integrity check is success
[0001.515] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b440)
[0001.521] I> Slot: 0
[0001.523] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.529] I> Binary name: PSC_RF
[0001.532] I> Size of crypto header is 8192
[0001.536] I> Size of crypto header is 8192
[0001.540] I> Size of crypto header is 8192
[0001.544] I> Size of crypto header is 8192
[0001.548] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f440)
[0001.554] I> BCH of PSC_RF read from storage
[0001.558] I> BCH address is : 0xa002f440
[0001.562] I> PSC_RF header integrity check is success
[0001.567] I> Binary magic in BCH component 0 is PSCR
[0001.572] I> component binary type is 22
[0001.575] I> Size of crypto header is 8192
[0001.579] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031440)
[0001.587] I> PSC_RF binary is read from storage
[0001.592] I> PSC_RF binary integrity check is success
[0001.596] I> Binary PSC_RF loaded successfully at 0xa0031440 (0x1be60)
[0001.606] I> Task: Save WP0 payload to SC7 ctx
[0001.610] I> Task: Load MB2rf binary to SC7 ctx
[0001.614] I> Slot: 0
[0001.616] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.622] I> Binary name: MB2_RF
[0001.625] I> Size of crypto header is 8192
[0001.629] I> Size of crypto header is 8192
[0001.633] I> Size of crypto header is 8192
[0001.637] I> Size of crypto header is 8192
[0001.641] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d6aa0)
[0001.647] I> BCH of MB2_RF read from storage
[0001.651] I> BCH address is : 0xa00d6aa0
[0001.655] I> MB2_RF header integrity check is success
[0001.660] I> Binary magic in BCH component 0 is MB2R
[0001.665] I> component binary type is 14
[0001.669] I> Size of crypto header is 8192
[0001.672] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d8aa0)
[0001.680] I> MB2_RF binary is read from storage
[0001.685] I> MB2_RF binary integrity check is success
[0001.690] I> Binary MB2_RF loaded successfully at 0xa00d8aa0 (0x1bfc0)
[0001.696] I> Task: Save fuse alias data to SC7 ctx
[0001.701] I> Task: Save PMIC data to SC7 ctx
[0001.705] I> Task: Save Pinmux data to SC7 ctx
[0001.709] I> Task: Save Pad Voltage data to SC7 ctx
[0001.714] I> Task: Save controller prod data to SC7 ctx
[0001.719] I> Task: Save prod cfg data to SC7 ctx
[0001.723] I> Task: Save I2C bus freq data to SC7 ctx
[0001.728] I> Task: Save SOCTherm data to SC7 ctx
[0001.732] I> Task: Save FMON data to SC7 ctx
[0001.737] I> Task: Save VMON data to SC7 ctx
[0001.741] I> Task: Save TZDRAM data to SC7 ctx
[0001.745] I> Task: Save GPIO int data to SC7 ctx
[0001.749] I> Task: Save clock data to SC7 ctx
[0001.754] I> Task: Save debug data to SC7 ctx
[0001.758] I> Task: Save MBWT data to SC7 ctx
[0001.766] I> SC7 context save done
[0001.769] I> Task: Load MB2/Applet/FSKP
[0001.773] I> Loading MB2
[0001.775] I> Slot: 0
[0001.777] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.783] I> Binary name: MB2
[0001.785] I> Size of crypto header is 8192
[0001.789] I> Size of crypto header is 8192
[0001.793] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.799] I> BCH of MB2 read from storage
[0001.803] I> BCH address is : 0x8007e000
[0001.807] I> MB2 header integrity check is success
[0001.812] I> Binary magic in BCH component 0 is MB2B
[0001.817] I> component binary type is 6
[0001.820] I> Size of crypto header is 8192
[0001.824] I> strt_pg_num(8464) num_of_pgs(838) read_buf(0x80000000)
[0001.835] I> MB2 binary is read from storage
[0001.840] I> MB2 binary integrity check is success
[0001.845] I> Binary MB2 loaded successfully at 0x80000000 (0x68b10)
[0001.851] I> Task: Map CCPLEX SHARED carveout
[0001.855] I> Task: Prepare MB2 params
[0001.859] I> Task: Dram ecc test
[0001.862] I> Task: Misc NV security settings
[0001.866] I> NVDEC sticky bits programming done
[0001.870] I> Successfully powergated NVDEC
[0001.874] I> Task: Disable/Reload WDT
[0001.878] I> Task: Program misc carveouts
[0001.882] I> Program IPC carveouts
[0001.885] I> Task: Disable SCPM/POD reset
[0001.889] I> SLCG Global override status := 0x0
[0001.894] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-934581f8)
I> Emulation:
I> Entry timestamp: 0x001d4ddc
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x82e800000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002050)
I> Task: Check MC errors (0x5000204c)
I> Task: Enable hot-plug capability (0x500290f8)
I> Task: TZDRAM heap init (0x5001a0fc)
I> Task: PSC mailbox init (0x50018864)
I> Task: Crypto init (0x50006874)
I> Task: Enable GP-SE clock (0x500021b4)
I> Task: Measured Boot init (0x5001c04c)
I> Task: fTPM silicon identity init (0x5001c1f8)
I> fTPM is not enabled.
I> Task: OEM SC7 context save init (0x5001b598)
I> Task: I2C register (0x50002010)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001ff8)
I> Task: Program CBB PCIE AMAP regions (0x5001bcf8)
I> Task: Boot device init (0x50001f40)
I> Task: Partition Manager Init (0x50001f20)
I> Active chain: 0
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Task: Load and authenticate registered FWs (0x5001f064)
I> Task: Load AUXP FWs (0x50028c7c)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Active chain: 0
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Active chain: 0
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x82db00000
I> Active chain: 0
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x82d800000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x836000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9486464 bytes
I> dce: plain binary integrity check is success
I> Active chain: 0
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x836000000
I> Active chain: 0
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x82e400000
I> Successfully register APE FW context save task with MB2 loader
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x82dc00000
I> Successfully register XUSB FW context save task with MB2 loader
I> Task: Carveout setup (0x500217e4)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50018738)
I> Task: Enable FSI VMON (0x50018234)
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings (0x50018318)
I> FSITHERM max temp = 42
I> FSITHERM min temp = 41
I> Task: Restore XUSB sec (0x50001ef4)
I> Task: Enable FSI SE clock (0x50018cc0)
I> Enable FSI-SE clock and 10ms delay...
I> Task: Initialize SBSA UART CAR (0x50002118)
I> Task: Initialize CPUBL Params (0x50019cac)
I> CPUBL-params @ 0x832000000
I> Task: Ratchet update (0x5002a194)
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data (0x50019a78)
I> Task: Revoke PKC fuse (0x50001d40)
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save (0x5001b874)
I> Task: Unpowergate APE (0x50019428)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x50025cf0)
I> OEM firewalls configured
I> Task: Powergate APE (0x5001959c)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x50026144)
I> Task: Unhalt AUXPs (0x50028f00)
I> Unhalting SPE..
I> Enabling combined UART
spe: early_init
vic initialized
tsc initialized
aon lic initialized
spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
spe: SafeRTOS v8.4
spe: init
scheduler initialized
aon hsp initialized
tag initialized
tcu initialized
bpmp ipc initialized
spe: late init
cpu_nic clock initialized
apb clock initialized
pm initialized
bpmp hsp initialized
top1 hsp initialized
ccplex ipc initialized
spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit (0x500188e4)
I> Sending opcode 0x4d420802 to psc
INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x848002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
I> Received ACK from psc
I> TasINFO: MONITOR: user task addr:0x848022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init...
INFO: enter idle task.
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is fcc6f4f897ab64a32c3de470c48f0036
bpmp: combined binary md5 is a414c625926dbe27334a57bddff625ec
bpmp: firmware tag is a414c625926dbe27334a-fcc6f4f897a
Control register check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
Write control check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 0f18000b != actual value: 00000000 address: 13a159c8
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
k: Start secure NOR provision (0x5001bb10)
I> Task: Load FSI keyblob (0x50018d08)
I> Skipping FSI key blob coinitialized avfs_clk_platform
initialized powergate
py
I> Task: Unhalt AUXPs (0x50028f08)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE uninitialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
halt successful
I> DCE unhalt successful
[ 2.365026] Camera-FW on t234-rce-safe started
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50019dd0)
I> Task: Load TOS (0x500TCU early console enabled.
1a560)
I> Active chain: 0
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
I> cpubl : oem authentication of header done
I> cpubl : meta-blob integrity check is success.
initialized emc
initialized emc_mrq
I> cpubl : will be decompressed at 0x82ce00000
I> version 1initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
Bin 1initialized uphy
BCheckSum 0 content_size 0 Coinitialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
I> Reserved10 0 BlockMaxSize 5 Reserinitialized clk_cal_late
initialized noc_late
initialized cvc
ved11 0
initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable sdmmc4_axicif
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq[ 2.536895] Camera-FW on t234-rce-safe ready SHA1=55ecd57d (crt 12.962 ms,
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
total boot 185.890 ms)
I> cpubl : decompressed to 3215488 bytes
I> cpubl: plain binary integrity check is success
I> Active chain: 0
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> NSDRAM carveout base: 0x80000000, size: 0x7ad370000
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x82ce00000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x83fdc7000
I> Relocating OP-TEE dtb from: 0x83fefec50 to 0x83c000860, size: 0x2886
I> [0] START: 0x80000000, SIZE: 0x7ad370000
I> [1] START: 0x832000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Active chain: 0
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x82e800200
I> EKB detected (length: 0x410) @ VA:0x82e800200
I> Task: Prepare TOS params (0x5001a4d8)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x83c000860
I> Task: OEM SC7 context save (0x5001b970)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50028f94)
I> Task: Program display sticky bits (0x50028f10)
I> Task: Storage device deinit (0x500020bc)
DCE: FW Boot Done
I> Task: SMMU external bypass disable (0x50018848)
I> Task: SMMU init (0x50018764)
I> Task: Program GICv3 registers (0x50029034)
I> Task: Audit firewall settings (0x50025f44)
I> Task: Bootchain failure check (0x500025c8)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
NOTICE: BL31: v2.6(release):cec9a2bc3
NOTICE: BL31: Built : 20:19:41, Feb 19 2024
I/TC: Physical secure memory base 0x83c040000 size 0x3fc0000
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.22 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Feb 20 04:28:56 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 5.0-35550185 built on 2024-02-20T04:21:22+00:00)
I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
E/TC:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0
E/LD: init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
E/TC:?? 00 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
e[2Je[04De[=3he[2Je[09D
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
ASSERT [VariableStandaloneMm] /dvs/git/dirty/git-master_linux/out/nvidia/optee.t234-uefi/StandaloneMmOptee_RELEASE/edk2/MdeModulePkg/Universal/Variable/RuntimeDxe/Variable.c(3264): !(((INTN)(RETURN_STATUS)(Status)) < 0)
This is the Boot log for jetpack 6.x
[0000.061] I> MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0000.066] I> t234-A01-0-Silicon (0x12347) Prod
[0000.070] I> Boot-mode : Coldboot
[0000.073] I> Entry timestamp: 0x00000000
[0000.077] I> last_boot_error: 0x0
[0000.080] I> BR-BCT: preprod_dev_sign: 0
[0000.084] I> rst_source: 0x0, rst_level: 0x0
[0000.088] I> Task: SE error check
[0000.091] I> Task: Bootchain select WAR set
[0000.095] I> Task: Enable SLCG
[0000.098] I> Task: CRC check
[0000.101] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0000.108] I> Task: Initialize MB2 params
[0000.112] I> MB2-params @ 0x40060000
[0000.116] I> Task: Crypto init
[0000.119] I> Task: Perform MB1 KAT tests
[0000.123] I> Task: NVRNG health check
[0000.126] I> NVRNG: Health check success
[0000.130] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.136] I> Task: Enabling and initialization of Bandwidth limiter
[0000.142] I> No request to configure MBWT settings for any PC!
[0000.148] I> Task: Secure debug controls
[0000.152] I> Task: strap war set
[0000.155] I> Task: Initialize SOC Therm
[0000.158] I> Task: Program NV master stream id
[0000.163] I> Task: Verify boot mode
[0000.168] I> Task: Alias fuses
[0000.172] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.179] I> Task: Print SKU type
[0000.182] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.192] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.196] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.200] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.209] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.222] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.226] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.230] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.235] I> FUSE_SKU_INFO_0 = 0xd0
[0000.242] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.251] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.256] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.261] I> BPMP NAFLL lock success.
[0000.265] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.269] I> Initializing PLLC2 for AXI_CBB.
[0000.274] I> AXI_CBB : src = 35, divisor = 0
[0000.278] I> Task: Voltage monitor
[0000.281] I> VMON: Vmon re-calibration and fine tuning done
[0000.286] I> Task: UPHY init
[0000.291] I> HSIO UPHY init done
[0000.294] W> Skipping GBE UPHY config
[0000.298] I> Task: Boot device init
[0000.301] I> Boot_device: QSPI_FLASH instance: 0
[0000.306] I> Qspi clock source : pllc_out0
[0000.310] I> QSPI Flash: Macronix 64MB
[0000.314] I> QSPI-0l initialized successfully
[0000.318] I> Task: TSC init
[0000.321] I> Task: Load membct
[0000.324] I> RAM_CODE 0x4000431
[0000.327] I> Loading MEMBCT
[0000.329] I> Slot: 0
[0000.331] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.337] I> Binary name: MEM-BCT-0
[0000.340] I> Size of crypto header is 8192
[0000.344] I> Size of crypto header is 8192
[0000.348] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.354] I> BCH of MEM-BCT-0 read from storage
[0000.359] I> BCH address is : 0x40050000
[0000.362] I> MEM-BCT-0 header integrity check is success
[0000.368] I> Binary magic in BCH component 0 is MEM0
[0000.372] I> component binary type is 0
[0000.376] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.383] I> MEM-BCT-0 binary is read from storage
[0000.388] I> MEM-BCT-0 binary integrity check is success
[0000.393] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.400] I> RAM_CODE 0x4000431
[0000.405] I> RAM_CODE 0x4000431
[0000.409] I> Task: Load Page retirement list
[0000.413] I> Task: SDRAM params override
[0000.417] I> Task: Save mem-bct info
[0000.420] I> Task: Carveout allocate
[0000.424] I> RCM blob carveout will not be allocated
[0000.428] I> Update CCPLEX IST carveout from MB1-BCT
[0000.433] I> ECC region[0]: Start:0x0, End:0x0
[0000.438] I> ECC region[1]: Start:0x0, End:0x0
[0000.442] I> ECC region[2]: Start:0x0, End:0x0
[0000.446] I> ECC region[3]: Start:0x0, End:0x0
[0000.450] I> ECC region[4]: Start:0x0, End:0x0
[0000.455] I> Non-ECC region[0]: Start:0x80000000, End:0x1080000000
[0000.461] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.465] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.470] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.475] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.485] I> allocated(CO:44) base:0x1049800000 size:0x36800000 align: 0x100000
[0000.492] I> allocated(CO:31) base:0x1040000000 size:0x8000000 align: 0x8000000
[0000.500] I> allocated(CO:43) base:0x103c000000 size:0x4000000 align: 0x200000
[0000.507] I> allocated(CO:39) base:0x1039e00000 size:0x2200000 align: 0x10000
[0000.514] I> allocated(CO:20) base:0x1036000000 size:0x2000000 align: 0x2000000
[0000.521] I> allocated(CO:24) base:0x1034000000 size:0x2000000 align: 0x2000000
[0000.528] I> allocated(CO:28) base:0x1032000000 size:0x2000000 align: 0x2000000
[0000.535] I> allocated(CO:29) base:0x1030000000 size:0x2000000 align: 0x2000000
[0000.543] I> allocated(CO:22) base:0x1048000000 size:0x1000000 align: 0x1000000
[0000.550] I> allocated(CO:35) base:0x1038e00000 size:0x1000000 align: 0x100000
[0000.557] I> allocated(CO:41) base:0x102f000000 size:0x1000000 align: 0x100000
[0000.564] I> allocated(CO:02) base:0x1049000000 size:0x800000 align: 0x800000
[0000.571] I> allocated(CO:03) base:0x1038000000 size:0x800000 align: 0x800000
[0000.578] I> allocated(CO:06) base:0x102e800000 size:0x800000 align: 0x800000
[0000.585] I> allocated(CO:56) base:0x102e000000 size:0x800000 align: 0x200000
[0000.592] I> allocated(CO:07) base:0x1038800000 size:0x400000 align: 0x400000
[0000.599] I> allocated(CO:33) base:0x102dc00000 size:0x400000 align: 0x200000
[0000.606] I> allocated(CO:19) base:0x102d980000 size:0x280000 align: 0x10000
[0000.613] I> allocated(CO:23) base:0x1038c00000 size:0x200000 align: 0x200000
[0000.620] I> allocated(CO:01) base:0x102d800000 size:0x100000 align: 0x100000
[0000.627] I> allocated(CO:05) base:0x102d700000 size:0x100000 align: 0x100000
[0000.634] I> allocated(CO:08) base:0x102d600000 size:0x100000 align: 0x100000
[0000.641] I> allocated(CO:09) base:0x102d500000 size:0x100000 align: 0x100000
[0000.648] I> allocated(CO:12) base:0x102d400000 size:0x100000 align: 0x100000
[0000.655] I> allocated(CO:15) base:0x102d300000 size:0x100000 align: 0x100000
[0000.662] I> allocated(CO:17) base:0x102d200000 size:0x100000 align: 0x100000
[0000.670] I> allocated(CO:27) base:0x102d100000 size:0x100000 align: 0x100000
[0000.677] I> allocated(CO:42) base:0x102d000000 size:0x100000 align: 0x100000
[0000.684] I> allocated(CO:54) base:0x102d900000 size:0x80000 align: 0x80000
[0000.690] I> allocated(CO:34) base:0x102cff0000 size:0x10000 align: 0x10000
[0000.697] I> allocated(CO:72) base:0x102cdf0000 size:0x200000 align: 0x10000
[0000.704] I> allocated(CO:47) base:0x102c800000 size:0x400000 align: 0x200000
[0000.711] I> allocated(CO:50) base:0x102c600000 size:0x200000 align: 0x100000
[0000.718] I> allocated(CO:52) base:0x102cdc0000 size:0x30000 align: 0x10000
[0000.725] I> allocated(CO:48) base:0x102cda0000 size:0x20000 align: 0x10000
[0000.732] I> allocated(CO:69) base:0x102cd80000 size:0x20000 align: 0x10000
[0000.739] I> allocated(CO:49) base:0x102cd70000 size:0x10000 align: 0x10000
[0000.746] I> NSDRAM base: 0x80000000, end: 0x102cdf0000, size: 0xfacdf0000
[0000.752] I> Task: Thermal check
[0000.756] I> Using min_chip_limit as min_tmon_limit
[0000.760] I> Using max_chip_limit as max_tmon_limit
[0000.765] I> BCT max_tmon_limit = 105
[0000.768] I> BCT min_tmon_limit = -28
[0000.772] I> BCT max_tmon_limit = 105
[0000.775] I> BCT min_tmon_limit = -28
[0000.779] I> SKU specific max_chip_limit = 105
[0000.783] I> SKU specific min_chip_limit = -28
[0000.788] I> BCT max_chip_limit = 105
[0000.791] I> BCT min_chip_limit = -28
[0000.794] I> enable_soctherm_polling = 0
[0000.798] I> max temp read = 38
[0000.801] I> min temp read = 37
[0000.804] I> Enabling thermtrip
[0000.807] I> Task: Update FSI SCR with thermal fuse data
[0000.812] I> Task: Enable WDT 5th expiry
[0000.816] I> Task: I2C register
[0000.819] I> Task: Set I2C bus freq
[0000.822] I> Task: Reset FSI
[0000.825] I> Task: Pinmux init
[0000.829] I> Task: Prod config init
[0000.832] I> Task: Pad voltage init
[0000.835] I> Task: Prod init
[0000.838] I> Task: Program rst req config reg
[0000.842] I> Task: Common rail init
[0000.846] I> DONE: Thermal config
[0000.849] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.858] I> DONE: SOC rail config
[0000.861] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.868] I> DONE: MEMIO rail config
[0000.871] I> DONE: GPU rail info
[0000.875] I> DONE: CV rail info
[0000.878] I> Task: Mem clock src
[0000.881] I> Task: Misc. board config
[0000.885] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.891] I> Task: SDRAM init
[0000.894] I> MemoryType: 4 MemBctRevision: 8
[0000.900] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0000.908] I> MSS CAR: Init PLLM
[0000.911] I> MSS CAR: Init PLLHUB
[0000.916] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.927] I> SDRAM initialized!
[0000.930] I> SDRAM Size in Total 0x1000000000
[0000.934] I> Task: Dram Ecc scrub
[0000.938] I> Task: DRAM alias check
[0000.954] I> Task: Program NSDRAM carveout
[0000.958] I> NSDRAM carveout encryption is enabled
[0000.963] I> Program NSDRAM carveout
[0000.966] I> Task: Register checker
[0000.970] I> Task: Enable clock-mon
[0000.984] I> FMON: Fmon re-programming done
[0000.988] I> Task: Mapper init
[0000.991] I> Task: SC7 Context Init
[0000.994] I> Task: CCPLEX IST init
[0000.998] I> Task: CPU WP0
[0001.001] I> Loading MCE
[0001.003] I> Slot: 0
[0001.005] I> Binary[8] block-22784 (partition size: 0x80000)
[0001.011] I> Binary name: MCE
[0001.013] I> Size of crypto header is 8192
[0001.017] I> Size of crypto header is 8192
[0001.021] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.028] I> BCH of MCE read from storage
[0001.031] I> BCH address is : 0x4003e000
[0001.035] I> MCE header integrity check is success
[0001.040] I> Binary magic in BCH component 0 is MTSM
[0001.045] I> component binary type is 8
[0001.048] I> Size of crypto header is 8192
[0001.052] I> strt_pg_num(22800) num_of_pgs(350) read_buf(0x40000000)
[0001.061] I> MCE binary is read from storage
[0001.065] I> MCE binary integrity check is success
[0001.070] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.076] I> Size of crypto header is 8192
[0001.087] I> Size of crypto header is 8192
[0001.091] I> Sending WP0 mailbox command to PSC
[0001.100] I> Task: XUSB Powergate
[0001.103] I> Skipping powergate XUSB.
[0001.107] I> Task: MB1 fixed firewalls
[0001.113] W> Firewall readback mismatch
[0001.118] I> Task: Load bpmp-fw
[0001.121] I> Slot: 0
[0001.123] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.128] I> Binary name: BPMP_FW
[0001.132] I> Size of crypto header is 8192
[0001.136] I> Size of crypto header is 8192
[0001.140] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.146] I> BCH of BPMP_FW read from storage
[0001.150] I> BCH address is : 0x807fe000
[0001.154] I> BPMP_FW header integrity check is success
[0001.159] I> Binary magic in BCH component 0 is BPMF
[0001.164] I> component binary type is 15
[0001.167] I> Size of crypto header is 8192
[0001.171] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.189] I> BPMP_FW binary is read from storage
[0001.195] I> BPMP_FW binary integrity check is success
[0001.200] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.207] I> Slot: 0
[0001.209] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.214] I> Binary name: BPMP_FW_DTB
[0001.218] I> Size of crypto header is 8192
[0001.222] I> Size of crypto header is 8192
[0001.226] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.232] I> BCH of BPMP_FW_DTB read from storage
[0001.236] I> BCH address is : 0x807fc000
[0001.240] I> BPMP_FW_DTB header integrity check is success
[0001.246] I> Binary magic in BCH component 0 is BPMD
[0001.250] I> component binary type is 16
[0001.254] I> Size of crypto header is 8192
[0001.258] I> strt_pg_num(13072) num_of_pgs(502) read_buf(0x807bd3f0)
[0001.267] I> BPMP_FW_DTB binary is read from storage
[0001.273] I> BPMP_FW_DTB binary integrity check is success
[0001.278] I> Binary BPMP_FW_DTB loaded successfully at 0x807bd3f0 (0x3eb00)
[0001.285] I> Task: BPMP fw ast config
[0001.288] I> Task: Load psc-fw
[0001.291] I> Slot: 0
[0001.293] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.299] I> Binary name: PSC_FW
[0001.302] I> Size of crypto header is 8192
[0001.306] I> Size of crypto header is 8192
[0001.310] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.316] I> BCH of PSC_FW read from storage
[0001.320] I> BCH address is : 0x80ffe000
[0001.324] I> PSC_FW header integrity check is success
[0001.329] I> Binary magic in BCH component 0 is PFWP
[0001.334] I> component binary type is 17
[0001.337] I> Size of crypto header is 8192
[0001.341] I> strt_pg_num(21264) num_of_pgs(591) read_buf(0x80fb4200)
[0001.351] I> PSC_FW binary is read from storage
[0001.356] I> PSC_FW binary integrity check is success
[0001.361] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.367] I> Task: Load nvdec-fw
[0001.370] I> Slot: 0
[0001.372] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.378] I> Binary name: NVDEC
[0001.381] I> Size of crypto header is 8192
[0001.385] I> Size of crypto header is 8192
[0001.389] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.395] I> BCH of NVDEC read from storage
[0001.399] I> BCH address is : 0x800fe000
[0001.403] I> NVDEC header integrity check is success
[0001.407] I> Binary magic in BCH component 0 is NDEC
[0001.412] I> component binary type is 7
[0001.416] I> Size of crypto header is 8192
[0001.420] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.429] I> NVDEC binary is read from storage
[0001.434] I> NVDEC binary integrity check is success
[0001.439] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.445] I> Size of crypto header is 8192
[0001.457] I> Task: Load tsec-fw
[0001.460] I> TSEC-FW load support not enabled
[0001.464] I> Task: GPIO interrupt map
[0001.467] I> Task: SC7 context save
[0001.471] I> Slot: 0
[0001.473] I> Binary[27] block-0 (partition size: 0x100000)
[0001.478] I> Binary name: BR_BCT
[0001.481] I> Size of crypto header is 8192
[0001.485] I> Size of crypto header is 8192
[0001.489] I> Size of crypto header is 8192
[0001.493] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.499] I> BR_BCT binary is read from storage
[0001.503] I> BR_BCT binary integrity check is success
[0001.508] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.515] I> Slot: 0
[0001.517] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.522] I> Binary name: SC7-FW
[0001.525] I> Size of crypto header is 8192
[0001.529] I> Size of crypto header is 8192
[0001.533] I> Size of crypto header is 8192
[0001.537] I> Size of crypto header is 8192
[0001.541] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.547] I> BCH of SC7-FW read from storage
[0001.551] I> BCH address is : 0xa0002000
[0001.555] I> SC7-FW header integrity check is success
[0001.560] I> Binary magic in BCH component 0 is WB0B
[0001.565] I> component binary type is 13
[0001.569] I> Size of crypto header is 8192
[0001.573] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[0001.581] I> SC7-FW binary is read from storage
[0001.586] I> SC7-FW binary integrity check is success
[0001.590] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b920)
[0001.597] I> Slot: 0
[0001.599] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.604] I> Binary name: PSC_RF
[0001.607] I> Size of crypto header is 8192
[0001.611] I> Size of crypto header is 8192
[0001.615] I> Size of crypto header is 8192
[0001.619] I> Size of crypto header is 8192
[0001.623] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f920)
[0001.629] I> BCH of PSC_RF read from storage
[0001.634] I> BCH address is : 0xa002f920
[0001.637] I> PSC_RF header integrity check is success
[0001.642] I> Binary magic in BCH component 0 is PSCR
[0001.647] I> component binary type is 22
[0001.651] I> Size of crypto header is 8192
[0001.655] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031920)
[0001.662] I> PSC_RF binary is read from storage
[0001.667] I> PSC_RF binary integrity check is success
[0001.672] I> Binary PSC_RF loaded successfully at 0xa0031920 (0x1be60)
[0001.681] I> Task: Save WP0 payload to SC7 ctx
[0001.685] I> Task: Load MB2rf binary to SC7 ctx
[0001.690] I> Slot: 0
[0001.692] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.697] I> Binary name: MB2_RF
[0001.701] I> Size of crypto header is 8192
[0001.704] I> Size of crypto header is 8192
[0001.708] I> Size of crypto header is 8192
[0001.712] I> Size of crypto header is 8192
[0001.716] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.723] I> BCH of MB2_RF read from storage
[0001.727] I> BCH address is : 0xa00d5d10
[0001.731] I> MB2_RF header integrity check is success
[0001.735] I> Binary magic in BCH component 0 is MB2R
[0001.740] I> component binary type is 14
[0001.744] I> Size of crypto header is 8192
[0001.748] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.755] I> MB2_RF binary is read from storage
[0001.760] I> MB2_RF binary integrity check is success
[0001.765] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf30)
[0001.771] I> Task: Save fuse alias data to SC7 ctx
[0001.776] I> Task: Save PMIC data to SC7 ctx
[0001.780] I> Task: Save Pinmux data to SC7 ctx
[0001.784] I> Task: Save Pad Voltage data to SC7 ctx
[0001.789] I> Task: Save controller prod data to SC7 ctx
[0001.794] I> Task: Save prod cfg data to SC7 ctx
[0001.799] I> Task: Save I2C bus freq data to SC7 ctx
[0001.803] I> Task: Save SOCTherm data to SC7 ctx
[0001.808] I> Task: Save FMON data to SC7 ctx
[0001.812] I> Task: Save VMON data to SC7 ctx
[0001.816] I> Task: Save TZDRAM data to SC7 ctx
[0001.820] I> Task: Save GPIO int data to SC7 ctx
[0001.825] I> Task: Save clock data to SC7 ctx
[0001.829] I> Task: Save debug data to SC7 ctx
[0001.833] I> Task: Save MBWT data to SC7 ctx
[0001.841] I> SC7 context save done
[0001.845] I> Task: Load MB2/Applet/FSKP
[0001.848] I> Loading MB2
[0001.851] I> Slot: 0
[0001.853] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.858] I> Binary name: MB2
[0001.861] I> Size of crypto header is 8192
[0001.865] I> Size of crypto header is 8192
[0001.869] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.875] I> BCH of MB2 read from storage
[0001.879] I> BCH address is : 0x8007e000
[0001.883] I> MB2 header integrity check is success
[0001.887] I> Binary magic in BCH component 0 is MB2B
[0001.892] I> component binary type is 6
[0001.896] I> Size of crypto header is 8192
[0001.900] I> strt_pg_num(8464) num_of_pgs(844) read_buf(0x80000000)
[0001.911] I> MB2 binary is read from storage
[0001.915] I> MB2 binary integrity check is success
[0001.920] I> Binary MB2 loaded successfully at 0x80000000 (0x696a0)
[0001.926] I> Task: Map CCPLEX SHARED carveout
[0001.930] I> Task: Prepare MB2 params
[0001.934] I> Task: Dram ecc test
[0001.937] I> Task: Misc NV security settings
[0001.942] I> NVDEC sticky bits programming done
[0001.946] I> Successfully powergated NVDEC
[0001.950] I> Task: Disable/Reload WDT
[0001.953] I> Task: Program misc carveouts
[0001.957] I> Program IPC carveouts
[0001.961] I> Task: Disable SCPM/POD reset
[0001.965] I> SLCG Global override status := 0x0
[0001.969] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-af79ed0a)
I> Emulation:
I> Entry timestamp: 0x001e7de0
I> DMA heap: [base:0x102e000000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: Configure OEM set LA/PTSA values
I> Task: Enable clock for external modules
I> Secondary storage device: QSPI_FLASH instance: 0
I> strt_pg_num(1) num_of_pgs(1) read_buf(0x102e001000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0x102e001000)
I> strt_pg_num(131039) num_of_pgs(32) read_buf(0x102e001200)
I> Found 60 partitions in QSPI_FLASH (instance 0)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Unpowergate done
I> Successfully register PVA FW load task with MB2 loader
I> strt_pg_num(55040) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(55056) num_of_pgs(512) read_buf(0x102d600000)
I> strt_pg_num(56192) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(56208) num_of_pgs(880) read_buf(0x102d200000)
I> Binary spe loaded successfully at 0x102d600000
I> strt_pg_num(44800) num_of_pgs(16) read_buf(0x40066880)
I> Binary rce loaded successfully at 0x102d200000
I> strt_pg_num(44816) num_of_pgs(1) read_buf(0x102e1400d8)
I> strt_pg_num(44816) num_of_pgs(8) read_buf(0x102e1400d8)
I> strt_pg_num(44824) num_of_pgs(512) read_buf(0x102e0000c0)
I> strt_pg_num(45336) num_of_pgs(512) read_buf(0x102e0400c0)
I> dce : will be decompressed at 0x1036000000
I> strt_pg_num(45848) num_of_pgs(512) read_buf(0x102e0800c0)
I> dce : decompressed to 12152960 bytes
I> strt_pg_num(58240) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(58256) num_of_pgs(800) read_buf(0x1038800000)
I> Binary dce loaded successfully at 0x1036000000
I> strt_pg_num(9472) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(9488) num_of_pgs(312) read_buf(0x102d700000)
I> Binary ape loaded successfully at 0x1038800000
I> Partition name: A_pva-fw
I> Binary@ device:3/0 block-62336 (partition size: 0x40000), name: A_pva-fw
I> strt_pg_num(62336) num_of_pgs(16) read_buf(0x40066880)
I> Binary xusb loaded successfully at 0x102d700000
I> pva-fw : oem authentication of header done
I> strt_pg_num(62352) num_of_pgs(1) read_buf(0x102e1400d8)
I> strt_pg_num(62352) num_of_pgs(8) read_buf(0x102e1400d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(62360) num_of_pgs(512) read_buf(0x102e0000c0)
I> pva-fw : will be decompressed at 0x102d980000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x102d980000
I> Successfully register PVA FW context save task with MB2 loader
I> Enable FSI-SE clock...
I> CPUBL-params @ 0x1032000000
I> Task: Memctrl reconfig pending clients
I> Powergating APE
I> Powergate done
I> Unhalting SPE..
spe: early_init
vic initialized
tsc initialized
aon lic initialized
spe: SafeRTOS v8.4
spe: init
aon hsp initialized
tag initialized
tcu initialized
spe: late init
pm initialized
I> Task: Start secure NOR provision
I> Skip Secure NOR provisioning
I> Task: Trigger load FSI keyblob
I> Skipping FSI key blob copy
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d t
bpmp: socket 0
bpmp: base binary md5 is 3b0e1a33cf85c7f62a7e8b93c2af97ed
bpmp: combined binary md5 is 2aafe334513692db071cfc4bbbaf4115
bpmp: firmware tag is 2aafe334513692db071c-3b0e1a33cf8
initialized vwdt
initialized fuse
initialized vfrel
initialized adc
initialized fmon
initialized mc
initialized reset
initialized pm
initialized io_dpd
initialized regime
initialized i2c
initialized vrmon
o psc
I> Task: Unhalt FSI
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> Task: Load HV/CPUBL
I> Task: Load TOS
I> Task: Trigger load TS[ 2.519195] Camera-FW on t234-rce-safe started
EC leyblob
I> Seninitialized dvs
initialized suspend
initialized strap
ding opcode 0x53535452 to psc
I> Sent opcode to psc
DCE Started
I> strt_pg_num(24832) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(24848) num_of_pgs(1) read_buf(0x102e143c98)
DCE_R5_Init
I> strt_pg_num(24848) num_of_pgs(8) read_buf(0x102e143c98)
I> strt_pg_num(24856) num_of_pinitialized emc
initialized emc_mrq
MPU enabled
DCE_SW_Init
gs(512) read_buf(0x10initialized clk_cal
initialized uphy_dt
2e003cinitialized uphy
80)
initialized pg_late
initialized bwmgr
initialized oc_mrq
initialized clk_mrq
initialized i2c_mrq
initialized tag_mrq
I> strt_pg_num(25368) num_of_pgs(512) read_buf(0x102e043c80)
I> cpubl : will be decompressed at 0x102c8000initialized clk_cal_late
initialized cvc
00
I> version 1 Bin 1 BCheckSum 0 coinitialized avfs_clk_mach_post
initialized rm
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable dsi_lp
initialized pg_post[ 2.722648] Camer
initialized profile
initialized mrq
initialized cactmon
initiaa-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.434 ms, total boot 216.960 mlized extras_post
bpmp: init complete
s)
I> strt_pg_num(25880) num_of_pgs(512) read_buf(0x102e083c80)
I> strt_pg_num(26392) num_of_pgs(512) read_buf(0x102e0c3c80)
I> strt_pg_num(26904) num_of_pgs(512) read_buf(0x102e103c80)
I> strt_pg_num(27416) num_of_pgs(512) read_buf(0x102e003c80)
I> strt_pg_num(27928) num_of_pgs(512) read_buf(0x102e043c80)
I> strt_pg_num(28440) num_of_pgs(512) read_buf(0x102e083c80)
I> strt_pg_num(28952) num_of_pgs(512) read_buf(0x102e0c3c80)
I> strt_pg_num(29464) num_of_pgs(512) read_buf(0x102e103c80)
I> strt_pg_num(29976) num_of_pgs(512) read_buf(0x102e003c80)
I> strt_pg_num(30488) num_of_pgs(512) read_buf(0x102e043c80)
Admin Task Init
Admin Task Init complete
Print Task Init
RM Task Init
SHA Task Init
Admin Task Started
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
SHA Task Started
DCE: FW Boot Complete
Admin Task Running
SHA Task RunI> strt_pg_num(31000) num_of_pgs(512) read_buf(0x102e083c80)
ning
I> cpubl : decompressed to 3616896 bytes
I> strt_pg_num(32000) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(32016) num_of_pgs(3176) read_buf(0x103fd73000)
I> NSDRAM carveout base: 0x80000000, size: 0xfacdf0000
I> Binary cpubl loaded successfully at 0x102c800000
I> Binary tos loaded successfully at 0x103fd73000
I> Relocating OP-TEE dtb from: 0x103feff0f0 to 0x103c040020, size: 0x2889
I> [0] START: 0x80000000, SIZE: 0xfacdf0000
I> [1] START: 0x1032000000, SIZE: 0x2000000
I> strt_pg_num(44288) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(44304) num_of_pgs(8) read_buf(0x103c020000)
I> Binary eks loaded successfully at 0x103c020000
I> EKB detected (length: 0x410) @ VA:0x103c020000
I> Task: Add cpubl params integrity check
I> Added cpubl params digest.
I> Setting OPTEE arg3: 0x103c040020
I> Task: SMMU init
I> Task: Burn RESERVED_ODM0 fuse
I> Task: Lock fusing
I> Task: Clear dec source key
I> MB2 finished
NOTICE: BL31: v2.8(release):e12e3fa93
NOTICE: BL31: Built : 19:36:31, Apr 24 2024
I/TC:
I/TC: OP-TEE version: 3.22 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Thu Apr 25 02:48:28 UTC 2024 aarch64
Jetson UEFI firmware (version 36.3.0-gcid-36106755 built on 2024-04-25T02:38:25+00:00)
I/TC: WARNING: Test UEFI variable auth key is being used !
I/TC: WARNING: UEFI variable protection is not fully enabled !
[ 5.880466] Camera-FW on t234-rce-safe started
E/TC:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 r[ 5.939211] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 0.919 ms, totet_oal boot 59.717 ms)
rigin=0
Jetson System firmware version 36.3.0-gcid-36106755 date 2024-04-25T02:38:25+00:
00
ESC to enter Setup.
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
debugfs initialized
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.136-tegra (baozhu@bz) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Thu May 9 11:44:49 CST 2024 ()
[ 0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x1027fff198 SMBIOS=0xffff0000 SMBIOS 3.0=0x10279d0000 MEMATTR=0x1020f67018 ESRT=0x10221b2f98 RNG=0x10156a0018 MEMRESERVE=0x10161e4c18
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x00000010221b2f98 to 0x00000010221b2fd0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000ff5000000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x1022d1c800-0x1022d1efff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001033ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000001018a64fff]
[ 0.000000] node 0: [mem 0x0000001018a65000-0x0000001018bdbfff]
[ 0.000000] node 0: [mem 0x0000001018bdc000-0x00000010260bffff]
[ 0.000000] node 0: [mem 0x00000010260c0000-0x0000001027ffffff]
[ 0.000000] node 0: [mem 0x0000001028000000-0x000000102c5fffff]
[ 0.000000] node 0: [mem 0x000000102c600000-0x000000102c7fffff]
[ 0.000000] node 0: [mem 0x000000102c800000-0x000000102cd6ffff]
[ 0.000000] node 0: [mem 0x000000102d700000-0x000000102d7fffff]
[ 0.000000] node 0: [mem 0x0000001032000000-0x0000001033ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] On node 0, zone Normal: 2448 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 18432 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16187760
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=PARTUUID=8f8ede6d-b874-4a92-986c-5b3c41faca53 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x102C610000 bl_prof_ro_ptr=65536@0x102C600000
[ 0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x102C610000 bl_prof_ro_ptr=65536@0x102C600000", will be passed to user space.
WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla1_core
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla1_core
[ 0.000000] Memory: 63806868K/65780160K available (19008K kernel code, 4060K rwdata, 10020K rodata, 7616K init, 529K bss, 1449004K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] trace event string verifier disabled
WARNING: cl[ 8.661471] pcie_tegra194: module verification failed: signature and/or required key missing - tainting kernel
[ 8.677103] tegra194-pcie 14100000.pcie: Adding to iommu group 5
[ 8.680200] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[ 8.680226] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 8.680232] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 8.680235] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 8.681310] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[ 8.681315] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 8.751542] tegra-xudc 3550000.usb: Adding to iommu group 6
[ 9.787095] tegra194-pcie 14100000.pcie: Phy link never came up
[ 10.788196] tegra194-pcie 14100000.pcie: Phy link never came up
[ 10.788300] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 10.788305] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 10.788308] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 10.788312] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 10.788313] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 10.788368] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 10.788545] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 10.794775] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 10.794903] pcieport 0001:00:00.0: Adding to iommu group 5
[ 10.795002] pcieport 0001:00:00.0: PME: Signaling with IRQ 203
[ 10.795285] pcieport 0001:00:00.0: AER: enabled with IRQ 203
[ 10.795527] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 10.795606] pci 0001:00:00.0: Removing from iommu group 5
[ 10.795616] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 10.797487] tegra194-pcie 14160000.pcie: Adding to iommu group 7
[ 10.799294] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[ 10.799306] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 10.799310] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 10.799313] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 10.799628] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[ 10.799630] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 10.911086] tegra194-pcie 14160000.pcie: Link up
[ 10.913742] tegra194-pcie 14160000.pcie: Link up
[ 10.913798] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 10.913802] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 10.913804] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.913806] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 10.913807] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 10.913850] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 10.914000] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 10.917392] pci 0004:01:00.0: [1d97:2263] type 00 class 0x010802
[ 10.917586] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 10.933980] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 10.933985] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 10.934071] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 10.934075] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 10.934172] pcieport 0004:00:00.0: Adding to iommu group 7
[ 10.934257] pcieport 0004:00:00.0: PME: Signaling with IRQ 205
[ 10.934842] pcieport 0004:00:00.0: AER: enabled with IRQ 205
[ 10.935043] nvme 0004:01:00.0: Adding to iommu group 7
[ 10.935610] nvme nvme0: pci function 0004:01:00.0
[ 10.935665] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 10.936347] tegra194-pcie 14180000.pcie: Adding to iommu group 8
[ 10.937013] tegra194-pcie 14180000.pcie: supply vddio-pex-ctl not found, using dummy regulator
[ 10.938928] tegra194-pcie 14180000.pcie: host bridge /bus@0/pcie@14180000 ranges:
[ 10.938947] tegra194-pcie 14180000.pcie: MEM 0x2440000000..0x2727ffffff -> 0x2440000000
[ 10.938953] tegra194-pcie 14180000.pcie: MEM 0x2728000000..0x272fffffff -> 0x0040000000
[ 10.938956] tegra194-pcie 14180000.pcie: IO 0x0038100000..0x00381fffff -> 0x0038100000
[ 10.939445] tegra194-pcie 14180000.pcie: iATU unroll: enabled
[ 10.939449] tegra194-pcie 14180000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 10.944240] nvme nvme0: missing or invalid SUBNQN field.
[ 10.946024] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x402, iova=0xffffb000, fsynr=0x2d0003, cbfrsynra=0xc13, cb=1
[ 10.946276] tegra-mc 2c00000.memory-controller: pcie4r: secure read @0x000000ffffffff00: EMEM address decode error (EMEM decode error)
[ 10.946282] tegra-mc 2c00000.memory-controller: pcie4w: secure write @0x00000003ffffff00: VPR violation ((null))
[ 11.047082] tegra194-pcie 14180000.pcie: Link up
[ 11.049880] tegra194-pcie 14180000.pcie: Link up
[ 11.049948] tegra194-pcie 14180000.pcie: PCI host bridge to bus 0000:00
[ 11.049953] pci_bus 0000:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x38100000-0x381fffff])
[ 11.049955] pci_bus 0000:00: root bus resource [mem 0x2728000000-0x272fffffff] (bus address [0x40000000-0x47ffffff])
[ 11.049958] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 11.049960] pci_bus 0000:00: root bus resource [mem 0x2440000000-0x2727ffffff pref]
[ 11.050001] pci 0000:00:00.0: [10de:229c] type 01 class 0x060400
[ 11.050147] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 11.053620] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601
[ 11.053765] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x007f]
[ 11.053827] pci 0000:01:00.0: reg 0x14: [io 0x0000-0x007f]
[ 11.053888] pci 0000:01:00.0: reg 0x18: [io 0x0000-0x007f]
[ 11.053948] pci 0000:01:00.0: reg 0x1c: [io 0x0000-0x007f]
[ 11.054009] pci 0000:01:00.0: reg 0x20: [io 0x0000-0x007f]
[ 11.054070] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
[ 11.054131] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 11.054905] pci 0000:01:00.0: PME# supported from D3hot
[ 11.058389] pci 0000:00:00.0: BAR 14: assigned [mem 0x2728000000-0x27280fffff]
[ 11.058392] pci 0000:00:00.0: BAR 13: assigned [io 0x200000-0x200fff]
[ 11.058394] pci 0000:01:00.0: BAR 6: assigned [mem 0x2728000000-0x272800ffff pref]
[ 11.058396] pci 0000:01:00.0: BAR 5: assigned [mem 0x2728010000-0x2728011fff]
[ 11.058421] pci 0000:01:00.0: BAR 0: assigned [io 0x200000-0x20007f]
[ 11.058446] pci 0000:01:00.0: BAR 1: assigned [io 0x200080-0x2000ff]
[ 11.058472] pci 0000:01:00.0: BAR 2: assigned [io 0x200100-0x20017f]
[ 11.058497] pci 0000:01:00.0: BAR 3: assigned [io 0x200180-0x2001ff]
[ 11.058522] pci 0000:01:00.0: BAR 4: assigned [io 0x200200-0x20027f]
[ 11.058548] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 11.058551] pci 0000:00:00.0: bridge window [io 0x200000-0x200fff]
[ 11.058554] pci 0000:00:00.0: bridge window [mem 0x2728000000-0x27280fffff]
[ 11.058644] pcieport 0000:00:00.0: Adding to iommu group 8
[ 11.058724] pcieport 0000:00:00.0: PME: Signaling with IRQ 207
[ 11.059275] pcieport 0000:00:00.0: AER: enabled with IRQ 207
[ 11.059456] ahci 0000:01:00.0: Adding to iommu group 8
[ 11.059552] ahci 0000:01:00.0: enabling device (0000 -> 0003)
[ 11.059918] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
[ 11.059989] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x3 impl SATA mode
[ 11.059993] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh
[ 11.061557] scsi host0: ahci
[ 11.062793] scsi host1: ahci
[ 11.063751] scsi host2: ahci
[ 11.064884] scsi host3: ahci
[ 11.066069] scsi host4: ahci
[ 11.066149] ata1: SATA max UDMA/133 abar m8192@0x2728010000 port 0x2728010100 irq 252
[ 11.066153] ata2: SATA max UDMA/133 abar m8192@0x2728010000 port 0x2728010180 irq 253
[ 11.066155] ata3: DUMMY
[ 11.066156] ata4: DUMMY
[ 11.066156] ata5: DUMMY
[ 11.066807] tegra194-pcie 141a0000.pcie: Adding to iommu group 9
[ 11.176622] tegra194-pcie 141a0000.pcie: host bridge /bus@0/pcie@141a0000 ranges:
[ 11.176642] tegra194-pcie 141a0000.pcie: MEM 0x2800000000..0x2b27ffffff -> 0x2800000000
[ 11.176647] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 11.176650] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 11.177179] tegra194-pcie 141a0000.pcie: iATU unroll: enabled
[ 11.177184] tegra194-pcie 141a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 11.385252] ata1: SATA link down (SStatus 0 SControl 300)
[ 12.284914] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 13.283514] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 13.283634] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 13.283639] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 13.283642] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 13.283646] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 13.283647] pci_bus 0005:00: root bus resource [mem 0x2800000000-0x2b27ffffff pref]
[ 13.283699] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 13.283868] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 13.290090] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 13.290233] pcieport 0005:00:00.0: Adding to iommu group 9
[ 13.290339] pcieport 0005:00:00.0: PME: Signaling with IRQ 209
[ 13.290887] pcieport 0005:00:00.0: AER: enabled with IRQ 209
[ 13.291670] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 13.291763] pci 0005:00:00.0: Removing from iommu group 9
[ 13.291775] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 23.896868] ERROR: PARTUUID=8f8ede6d-b874-4a92-986c-5b3c41faca53 mount fail...
[ 23.898340] ttyTCU0: Press [ENTER] to start bash in 30 seconds...
[ 26.898777] ttyTCU0: Press [ENTER] to start bash in 27 seconds...
[ 29.899139] ttyTCU0: Press [ENTER] to start bash in 24 seconds...
[ 32.899465] ttyTCU0: Press [ENTER] to start bash in 21 seconds...
[ 35.899788] ttyTCU0: Press [ENTER] to start bash in 18 seconds...
[ 38.900107] ttyTCU0: Press [ENTER] to start bash in 15 seconds...
[ 41.900424] ttyTCU0: Press [ENTER] to start bash in 12 seconds...
[ 44.900744] ttyTCU0: Press [ENTER] to start bash in 9 seconds...
[ 47.901059] ttyTCU0: Press [ENTER] to start bash in 6 seconds...
[ 50.901377] ttyTCU0: Press [ENTER] to start bash in 3 seconds...
[ 53.903542] ttyAMA0: Press [ENTER] to start bash in 30 seconds...
[ 56.903929] ttyAMA0: Press [ENTER] to start bash in 27 seconds...
[ 59.904234] ttyAMA0: Press [ENTER] to start bash in 24 seconds...
[ 62.904534] ttyAMA0: Press [ENTER] to start bash in 21 seconds...
[ 65.904837] ttyAMA0: Press [ENTER] to start bash in 18 seconds...
[ 68.905139] ttyAMA0: Press [ENTER] to start bash in 15 seconds...
[ 71.905437] ttyAMA0: Press [ENTER] to start bash in 12 seconds...
[ 72.671114] nvme nvme0: I/O 26 QID 0 timeout, disable controller
[ 72.795474] nvme nvme0: failed to set APST feature (-4)
[ 72.795480] nvme nvme0: Removing after probe failure status: -4
[ 73.124262] ata2: SATA link down (SStatus 0 SControl 300)
[ 74.905734] ttyAMA0: Press [ENTER] to start bash in 9 seconds...
[ 77.906033] ttyAMA0: Press [ENTER] to start bash in 6 seconds...
[ 80.906330] ttyAMA0: Press [ENTER] to start bash in 3 seconds...
[ 83.906649] Rebooting system...
[ 83.908966] sysrq: Resetting
[ 83.908989] ------------[ cut here ]------------
[ 83.908990] Voluntary context switch within RCU read-side critical section!
[ 83.908998] WARNING: CPU: 2 PID: 424 at kernel/rcu/tree_plugin.h:316 rcu_note_context_switch+0x418/0x500
[ 83.909011] Modules linked in: pwm_fan(E) pwm_tegra(E) tegra_bpmp_thermal(E) tegra_xudc(E) ucsi_ccg(E) typec_ucsi(E) typec(E) nvme(E) nvme_core(E) phy_tegra194_p2u(E) pcie_tegra194(E)
[ 83.909026] CPU: 2 PID: 424 Comm: reboot Tainted: G E 5.15.136-tegra #1
[ 83.909029] Hardware name: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.3.0-gcid-36106755 04/25/2024
[ 83.909031] pstate: 604000c9 (nZCv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 83.909033] pc : rcu_note_context_switch+0x418/0x500
[ 83.909035] lr : rcu_note_context_switch+0x418/0x500
[ 83.909036] sp : ffff80000c7d3a70
[ 83.909037] x29: ffff80000c7d3a70 x28: 0000000000000001 x27: 0000000000000001
[ 83.909040] x26: ffff0000858ebe00 x25: 4fb0b7f61f47f7a0 x24: 0000000000000000
[ 83.909041] x23: ffffb7f61ffdb008 x22: 0000000000000000 x21: ffff0000858ebe00
[ 83.909043] x20: 0000000000000000 x19: ffff000fa2bf1480 x18: 0000000000000000
[ 83.909045] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
e
[0000.065] I> MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0000.071] I> t234-A01-0-Silicon (0x12347) Prod
[0000.075] I> Boot-mode : Coldboot
[0000.078] I> Entry timestamp: 0x00000000
[0000.082] I> last_boot_error: 0x0
[0000.085] I> BR-BCT: preprod_dev_sign: 0
[0000.089] I> rst_source: 0xb, rst_level: 0x1
[0000.093] I> Task: SE error check
[0000.096] I> Task: Bootchain select WAR set
[0000.100] I> Task: Enable SLCG
[0000.103] I> Task: CRC check
[0000.106] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0000.113] I> Task: Initialize MB2 params
[0000.117] I> MB2-params @ 0x40060000
[0000.121] I> Task: Crypto init
[0000.123] I> Task: Perform MB1 KAT tests
[0000.127] I> Task: NVRNG health check
[0000.131] I> NVRNG: Health check success
[0000.135] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.141] I> Task: Enabling and initialization of Bandwidth limiter
[0000.147] I> No request to configure MBWT settings for any PC!
[0000.152] I> Task: Secure debug controls
[0000.156] I> Task: strap war set
[0000.159] I> Task: Initialize SOC Therm
[0000.163] I> Task: Program NV master stream id
[0000.167] I> Task: Verify boot mode
[0000.173] I> Task: Alias fuses
[0000.176] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.184] I> Task: Print SKU type
[0000.187] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.192] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.196] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.200] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.205] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.209] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.213] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.218] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.222] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.226] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.231] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.235] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.239] I> FUSE_SKU_INFO_0 = 0xd0
[0000.242] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.246] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.250] I> SKU: Prod
[0000.252] I> Task: Boost clocks
[0000.255] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.260] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.266] I> BPMP NAFLL lock success.
[0000.269] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.274] I> Initializing PLLC2 for AXI_CBB.
[0000.278] I> AXI_CBB : src = 35, divisor = 0
[0000.282] I> Task: Voltage monitor
[0000.285] I> VMON: Vmon re-calibration and fine tuning done
[0000.291] I> Task: UPHY init
[0000.296] I> HSIO UPHY init done
[0000.299] W> Skipping GBE UPHY config
[0000.302] I> Task: Boot device init
[0000.306] I> Boot_device: QSPI_FLASH instance: 0
[0000.310] I> Qspi clock source : pllc_out0
[0000.314] I> QSPI Flash: Macronix 64MB
[0000.318] I> QSPI-0l initialized successfully
[0000.322] I> Task: TSC init
[0000.325] I> Task: Load membct
[0000.328] I> RAM_CODE 0x4000431
[0000.331] I> Loading MEMBCT
[0000.334] I> Slot: 0
[0000.336] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.341] I> Binary name: MEM-BCT-0
[0000.348] I> Size of crypto header is 8192
[0000.352] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.359] I> BCH of MEM-BCT-0 read from storage
[0000.363] I> BCH address is : 0x40050000
[0000.367] I> MEM-BCT-0 header integrity check is success
[0000.372] I> Binary magic in BCH component 0 is MEM0
[0000.377] I> component binary type is 0
[0000.380] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.387] I> MEM-BCT-0 binary is read from storage
[0000.392] I> MEM-BCT-0 binary integrity check is success
[0000.397] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.404] I> RAM_CODE 0x4000431
[0000.409] I> RAM_CODE 0x4000431
[0000.413] I> Task: Load Page retirement list
[0000.417] I> Task: SDRAM params override
[0000.421] I> Task: Save mem-bct info
[0000.425] I> Task: Carveout allocate
[0000.428] I> RCM blob carveout will not be allocated
[0000.433] I> Update CCPLEX IST carveout from MB1-BCT
[0000.438] I> ECC region[0]: Start:0x0, End:0x0
[0000.442] I> ECC region[1]: Start:0x0, End:0x0
[0000.446] I> ECC region[2]: Start:0x0
[ 5.885982] Camera-FW on t234-rce-safe started
E/TC:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_[ 5.945783] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 0.925 ms, totorigial boot 60.779 ms)
n=0
00
ESC to enter Setup.
I tried to install this to modify it, but it didn’t work, it would still hang after 700+ restart.
