I Have a Jetson Orin Industrial variant and when I try to flash the yocto meta-tegra(wrynose branch) with image generated with the jetson-agx-orin-devkit-industrial.conf. I faced the following issue:
Initially, MB1 failed with MEM-BCT-1 binary magic_id not found.
[0013.801] I> MB1 (version: 1.0.1.17-t234-54845784-9b0d5809)
[0013.806] I> t234-A01-1-Silicon (0x12347) Prod
[0013.810] I> Boot-mode : Coldboot
[0013.813] I> Entry timestamp: 0x00000000
[0013.817] I> last_boot_error: 0x0
[0013.820] I> BR-BCT: preprod_dev_sign: 0
[0013.824] C> rst_source: 0xb, rst_level: 0x1
[0013.828] I> Total boot-chains: 2 Active-chain: 0|A - BR-BCT based selection
[0013.835] I> Default chain: 0|A
[0013.838] I> Task: SE error check
[0013.842] I> Task: Bootchain select WAR set
[0013.846] I> Task: Update Boot chain markers
[0013.850] I> Task: Send error information to MCU
[0013.854] I> Task: Enable SLCG
[0013.857] I> Task: CRC check
[0013.860] I> Task: Initialize MB2 params
[0013.864] I> MB2-params @ 0x40060000
[0013.867] I> Task: Crypto init
[0013.870] I> Task: Perform MB1 KAT tests
[0013.874] I> Task: NVRNG health check
[0013.878] I> NVRNG: Health check success
[0013.881] I> Task: Check ECID against ECID in fuses
[0013.886] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0013.892] I> Task: Enabling and initialization of Bandwidth limiter
[0013.898] I> No request to configure MBWT settings for any PC!
[0013.904] I> Task: Secure debug controls
[0013.908] I> Task: strap war set
[0013.911] I> Task: Initialize SOC Therm
[0013.915] I> Task: Program NV master stream id
[0013.919] I> Task: Verify boot mode
[0013.925] I> Task: Alias fuses
[0013.928] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0013.935] I> Task: Print SKU type
[0013.938] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0013.943] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0013.947] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0013.952] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0013.956] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0013.960] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0013.965] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0013.969] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0013.973] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0013.978] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0013.982] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0013.986] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0013.990] I> FUSE_SKU_INFO_0 = 0x90
[0013.993] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0013.998] I> FUSE_PACKAGE_INFO_0 = 0x2
[0014.001] I> SKU: Prod
[0014.003] I> Task: Boost clocks
[0014.006] I> Initializing NAFLL for BPMP_CPU_NIC.
[0014.011] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0014.017] I> BPMP NAFLL lock success.
[0014.020] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0014.025] I> Initializing PLLC2 for AXI_CBB.
[0014.029] I> AXI_CBB : src = 35, divisor = 0
[0014.033] I> Task: Voltage monitor
[0014.037] I> VMON: Vmon re-calibration and fine tuning done
[0014.042] I> Task: UPHY init
[0014.047] I> HSIO UPHY init done
[0014.050] W> Skipping GBE UPHY config
[0014.053] I> Task: Boot device init
[0014.057] I> Boot_device: RCM
[0014.060] I> USB configuration success
[0014.064] I> Task: TSC init
[0014.066] I> Task: Load membct
[0014.069] I> RAM_CODE 0x4000041
[0014.072] I> Loading MEMBCT
[0014.075] I> Chain: 0
[0014.077] I> Binary[1] block-0 (partition size: 0x40000)
[0014.082] I> Binary name: MEM-BCT-1
[0014.086] I> Size of crypto header is 8192
[0014.090] I> Size of crypto header is 8192
[0014.094] I> BCH of MEM-BCT-1 read from storage
[0014.098] I> BCH address is : 0x40050000
[0014.102] I> component binary type is 0
[0014.106] I> MEM-BCT-1 header integrity check is success
[0014.111] E> MEM-BCT-1 binary magic_id not found
[0014.116] C> LOADER: Could not read binary 1.
[0014.120] C> MSS: Failed to load MEMBCT.
[0014.124] C> Task 0x1e failed (err: 0x4822970d)
[0014.128] E> Top caller module: MSS, error module: LOADER, reason: 0x0d, aux_info: 0x97
[0014.136] C> Boot Info Table status dump :
011111111100111000111111111111
After setting RAMCODE=4 (TEGRA_FLASHVAR_RAMCODE ?= "4"), MB1 successfully loads MEM-BCT-1 , and execution proceeds through MB2. Now stuck here during flash:
[0013.670] I> MB1 (version: 1.0.1.17-t234-54845784-9b0d5809)
[0013.676] I> t234-A01-1-Silicon (0x12347) Prod
[0013.680] I> Boot-mode : Coldboot
[0013.683] I> Entry timestamp: 0x00000000
[0013.687] I> last_boot_error: 0x0
[0013.690] I> BR-BCT: preprod_dev_sign: 0
[0013.694] C> rst_source: 0xb, rst_level: 0x1
[0013.698] I> Total boot-chains: 2 Active-chain: 0|A - BR-BCT based selection
[0013.705] I> Default chain: 0|A
[0013.708] I> Task: SE error check
[0013.712] I> Task: Bootchain select WAR set
[0013.716] I> Task: Update Boot chain markers
[0013.720] I> Task: Send error information to MCU
[0013.724] I> Task: Enable SLCG
[0013.727] I> Task: CRC check
[0013.730] I> Task: Initialize MB2 params
[0013.734] I> MB2-params @ 0x40060000
[0013.737] I> Task: Crypto init
[0013.740] I> Task: Perform MB1 KAT tests
[0013.744] I> Task: NVRNG health check
[0013.748] I> NVRNG: Health check success
[0013.751] I> Task: Check ECID against ECID in fuses
[0013.756] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0013.762] I> Task: Enabling and initialization of Bandwidth limiter
[0013.768] I> No request to configure MBWT settings for any PC!
[0013.774] I> Task: Secure debug controls
[0013.778] I> Task: strap war set
[0013.781] I> Task: Initialize SOC Therm
[0013.785] I> Task: Program NV master stream id
[0013.789] I> Task: Verify boot mode
[0013.795] I> Task: Alias fuses
[0013.798] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0013.805] I> Task: Print SKU type
[0013.808] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0013.813] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0013.817] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0013.822] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0013.826] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0013.830] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0013.835] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0013.839] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0013.843] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0013.848] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0013.852] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0013.856] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0013.860] I> FUSE_SKU_INFO_0 = 0x90
[0013.863] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0013.867] I> FUSE_PACKAGE_INFO_0 = 0x2
[0013.871] I> SKU: Prod
[0013.873] I> Task: Boost clocks
[0013.876] I> Initializing NAFLL for BPMP_CPU_NIC.
[0013.881] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0013.887] I> BPMP NAFLL lock success.
[0013.890] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0013.895] I> Initializing PLLC2 for AXI_CBB.
[0013.899] I> AXI_CBB : src = 35, divisor = 0
[0013.903] I> Task: Voltage monitor
[0013.906] I> VMON: Vmon re-calibration and fine tuning done
[0013.912] I> Task: UPHY init
[0013.917] I> HSIO UPHY init done
[0013.920] W> Skipping GBE UPHY config
[0013.923] I> Task: Boot device init
[0013.927] I> Boot_device: RCM
[0013.930] I> USB configuration success
[0013.933] I> Task: TSC init
[0013.936] I> Task: Load membct
[0013.939] I> RAM_CODE 0x4000041
[0013.942] I> Loading MEMBCT
[0013.945] I> Chain: 0
[0013.947] I> Binary[1] block-0 (partition size: 0x40000)
[0013.952] I> Binary name: MEM-BCT-1
[0013.956] I> Size of crypto header is 8192
[0013.960] I> Size of crypto header is 8192
[0013.964] I> BCH of MEM-BCT-1 read from storage
[0013.968] I> BCH address is : 0x40050000
[0013.972] I> component binary type is 1
[0013.976] I> MEM-BCT-1 header integrity check is success
[0013.981] I> Binary magic in BCH component 0 is MEM1
[0013.986] I> component binary type is 1
[0013.989] I> component binary type is 1
[0013.996] I> MEM-BCT-1 binary is read from storage
[0014.001] I> MEM-BCT-1 binary integrity check is success
[0014.006] I> Binary MEM-BCT-1 loaded successfully at 0x40040000 (0xe580)
[0014.013] I> RAM_CODE 0x4000041
[0014.018] I> RAM_CODE 0x4000041
[0014.021] I> Task: Load Page retirement list
[0014.025] I> Task: SDRAM params override
[0014.029] I> Task: Save mem-bct info
[0014.033] E> GPCDMA: TZ to non-TZ or vice versa memcpy using DMA is not supported.
[0014.041] E> GPCDMA: Failed DMA xfer.
[0014.045] E> GPCDMA: TZ to non-TZ or vice versa memcpy using DMA is not supported.
[0014.053] E> GPCDMA: Failed DMA xfer.
[0014.056] I> Task: Carveout allocate
[0014.059] I> Update CCPLEX IST carveout from MB1-BCT
[0014.064] I> ECC region[0]: Start:0x80000000, End:0xe80000000
[0014.070] I> ECC region[1]: Start:0x0, End:0x0
[0014.074] I> ECC region[2]: Start:0x0, End:0x0
[0014.078] I> ECC region[3]: Start:0x0, End:0x0
[0014.083] I> ECC region[4]: Start:0x0, End:0x0
[0014.087] I> Non-ECC region[0]: Start:0x0, End:0x0
[0014.092] I> Non-ECC region[1]: Start:0x0, End:0x0
[0014.096] I> Non-ECC region[2]: Start:0x0, End:0x0
[0014.101] I> Non-ECC region[3]: Start:0x0, End:0x0
[0014.106] I> Non-ECC region[4]: Start:0x0, End:0x0
[0014.116] I> allocated(CO:44) base:0xe49800000 size:0x36800000 align: 0x100000
[0014.123] I> allocated(CO:31) base:0xe40000000 size:0x8000000 align: 0x8000000
[0014.131] I> allocated(CO:28) base:0xe3c000000 size:0x4000000 align: 0x2000000
[0014.138] I> allocated(CO:43) base:0xe38000000 size:0x4000000 align: 0x200000
[0014.145] I> allocated(CO:39) base:0xe35e00000 size:0x2200000 align: 0x10000
[0014.152] I> allocated(CO:15) base:0xe33e00000 size:0x2000000 align: 0x100000
[0014.159] I> allocated(CO:20) base:0xe30000000 size:0x2000000 align: 0x2000000
[0014.166] I> allocated(CO:21) base:0xe2e000000 size:0x2000000 align: 0x2000000
[0014.173] I> allocated(CO:24) base:0xe2c000000 size:0x2000000 align: 0x2000000
[0014.180] I> allocated(CO:29) base:0xe2a000000 size:0x2000000 align: 0x2000000
[0014.187] I> allocated(CO:35) base:0xe28000000 size:0x2000000 align: 0x100000
[0014.194] I> allocated(CO:22) base:0xe48000000 size:0x1000000 align: 0x1000000
[0014.201] I> allocated(CO:41) base:0xe32e00000 size:0x1000000 align: 0x100000
[0014.208] I> allocated(CO:02) base:0xe49000000 size:0x800000 align: 0x800000
[0014.215] I> allocated(CO:03) base:0xe32000000 size:0x800000 align: 0x800000
[0014.222] I> allocated(CO:06) base:0xe27800000 size:0x800000 align: 0x800000
[0014.229] I> allocated(CO:56) base:0xe27000000 size:0x800000 align: 0x200000
[0014.236] I> allocated(CO:07) base:0xe32800000 size:0x400000 align: 0x400000
[0014.243] I> allocated(CO:33) base:0xe26c00000 size:0x400000 align: 0x200000
[0014.250] I> allocated(CO:19) base:0xe26980000 size:0x280000 align: 0x10000
[0014.257] I> allocated(CO:17) base:0xe32c00000 size:0x200000 align: 0x200000
[0014.264] I> allocated(CO:23) base:0xe26600000 size:0x200000 align: 0x200000
[0014.271] I> allocated(CO:01) base:0xe26800000 size:0x100000 align: 0x100000
[0014.278] I> allocated(CO:05) base:0xe26500000 size:0x100000 align: 0x100000
[0014.285] I> allocated(CO:08) base:0xe26400000 size:0x100000 align: 0x100000
[0014.292] I> allocated(CO:09) base:0xe26300000 size:0x100000 align: 0x100000
[0014.299] I> allocated(CO:12) base:0xe26200000 size:0x100000 align: 0x100000
[0014.306] I> allocated(CO:27) base:0xe26100000 size:0x100000 align: 0x100000
[0014.313] I> allocated(CO:42) base:0xe26000000 size:0x100000 align: 0x100000
[0014.319] I> allocated(CO:54) base:0xe26900000 size:0x80000 align: 0x80000
[0014.326] I> allocated(CO:52) base:0xe25fd0000 size:0x30000 align: 0x10000
[0014.333] I> allocated(CO:34) base:0xe25fc0000 size:0x10000 align: 0x10000
[0014.340] I> allocated(CO:72) base:0xe25dc0000 size:0x200000 align: 0x10000
[0014.347] I> allocated(CO:46) base:0xe00000000 size:0x20000000 align: 0x20000000
[0014.354] I> allocated(CO:47) base:0xe21c00000 size:0x4000000 align: 0x200000
[0014.361] I> allocated(CO:50) base:0xe21a00000 size:0x200000 align: 0x100000
[0014.368] I> allocated(CO:48) base:0xe25da0000 size:0x20000 align: 0x10000
[0014.375] I> allocated(CO:69) base:0xe25d80000 size:0x20000 align: 0x10000
[0014.381] I> allocated(CO:49) base:0xe25d70000 size:0x10000 align: 0x10000
[0014.388] I> NSDRAM base: 0x80000000, end: 0xe25dc0000, size: 0xda5dc0000
[0014.395] I> Task: Thermal check
[0014.398] I> (MB1 SKU-specific) max_chip_limit = 125
[0014.403] I> (MB1 SKU-specific) min_chip_limit = -43
[0014.408] I> (MB1 BCT) max_chip_limit = 118
[0014.412] I> (MB1 BCT) min_chip_limit = -43
[0014.416] I> max temp read = 27
[0014.419] I> min temp read = 26
[0014.422] I> Task: Update FSI SCR with thermal fuse data
[0014.427] I> Task: Enable WDT 5th expiry
[0014.431] I> Task: I2C register
[0014.434] I> Task: Set I2C bus freq
[0014.437] I> Task: Reset FSI
[0014.440] I> FSI Reset successful
[0014.443] I> Task: Pad voltage init
[0014.446] I> Task: Pinmux init
[0014.449] I> Task: Prod config init
[0014.453] I> Task: Prod init
[0014.456] I> Task: Program rst req config reg
[0014.460] I> Task: Common rail init
[0014.464] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0014.475] I> DONE: Thermal config
[0014.479] I> DONE: SOC rail config
[0014.483] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0014.490] I> DONE: MEMIO rail config
[0014.493] I> DONE: GPU rail info
[0014.497] I> DONE: CV rail info
[0014.500] I> Task: Mem clock src
[0014.503] I> Task: Misc. board config
[0014.507] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0014.513] I> Task: SDRAM init
[0014.515] I> MemoryType: 4 MemBctRevision: 8
[0014.522] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0014.529] I> MSS CAR: Init PLLM
[0014.533] I> MSS CAR: Init PLLHUB
[0014.537] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0014.549] I> SDRAM initialized!
[0014.552] I> SDRAM Size in Total 0xe00000000
[0014.556] I> Task: Dram Ecc scrub
[0014.559] I> DRAM ECC Scrub Mode: full
[0016.281] I> SDRAM scrub successful
[0016.284] I> Task: DRAM alias check
[0016.296] I> Task: Program NSDRAM carveout
[0016.300] I> NSDRAM carveout encryption is enabled
[0016.304] I> Program NSDRAM carveout
[0016.308] I> Task: Check MSS settings
[0016.312] I> Task: MSS Encrypt status check
[0016.316] I> Task: Register checker
[0016.319] I> Task: Enable clock-mon
[0016.333] I> FMON: Fmon re-programming done
[0016.337] I> Task: Mapper init
[0016.340] I> Task: SC7 Context Init
[0016.344] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0016.349] I> Task: CCPLEX IST init
[0016.353] I> Task: CPU WP0
[0016.356] I> Loading MCE
[0016.359] I> Chain: 0
[0016.361] I> Binary[8] block-134217728 (partition size: 0x80000)
[0016.367] I> Binary name: MCE
[0016.369] I> Size of crypto header is 8192
[0016.373] I> Size of crypto header is 8192
[0020.827] I> BCH of MCE read from storage
[0020.831] I> BCH address is : 0x4003e000
[0020.835] I> component binary type is 8
[0020.839] I> MCE header integrity check is success
[0020.843] I> Binary magic in BCH component 0 is MTSM
[0020.848] I> component binary type is 8
[0020.852] I> Size of crypto header is 8192
[0020.856] I> component binary type is 8
[0020.860] I> MCE binary is read from storage
[0020.864] I> MCE binary integrity check is success
[0020.869] I> Binary MCE loaded successfully at 0x40000000 (0x2bbc0)
[0020.875] I> Size of crypto header is 8192
[0020.879] I> Sending WP0 mailbox command to PSC
[0020.888] I> Task: XUSB Powergate
[0020.891] I> Skipping powergate XUSB.
[0020.895] I> Task: MB1 fixed firewalls
[0020.900] I> Task: Load bpmp-fw
[0020.903] I> Chain: 0
[0020.905] I> Binary[15] block-251658240 (partition size: 0x180000)
[0020.912] I> Binary name: BPMP_FW
[0020.915] I> Size of crypto header is 8192
[0020.919] I> Size of crypto header is 8192
[0020.923] I> BCH of BPMP_FW read from storage
[0020.927] I> BCH address is : 0x807fe000
[0020.931] I> component binary type is 15
[0020.934] I> BPMP_FW header integrity check is success
[0020.939] I> Binary magic in BCH component 0 is BPMF
[0020.944] I> component binary type is 15
[0020.948] I> Size of crypto header is 8192
[0020.952] I> component binary type is 15
[0020.957] I> BPMP_FW binary is read from storage
[0020.963] I> BPMP_FW binary integrity check is success
[0020.968] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfd640)
[0020.975] I> Chain: 0
[0020.977] I> Binary[16] block-268435456 (partition size: 0x300000)
[0020.983] I> Binary name: BPMP_FW_DTB
[0020.986] I> Size of crypto header is 8192
[0020.990] I> Size of crypto header is 8192
[0020.994] I> BCH of BPMP_FW_DTB read from storage
[0020.999] I> BCH address is : 0x807fc000
[0021.002] I> component binary type is 16
[0021.006] I> BPMP_FW_DTB header integrity check is success
[0021.012] I> Binary magic in BCH component 0 is BPMD
[0021.016] I> component binary type is 16
[0021.020] I> Size of crypto header is 8192
[0021.024] I> component binary type is 16
[0021.028] I> BPMP_FW_DTB binary is read from storage
[0021.033] I> BPMP_FW_DTB binary integrity check is success
[0021.038] I> Binary BPMP_FW_DTB loaded successfully at 0x807d7ef0 (0x24100)
[0021.045] I> Task: Load psc-fw
[0021.048] I> Chain: 0
[0021.050] I> Binary[17] block-285212672 (partition size: 0xc0000)
[0021.056] I> Binary name: PSC_FW
[0021.060] I> Size of crypto header is 8192
[0021.063] I> Size of crypto header is 8192
[0021.067] I> BCH of PSC_FW read from storage
[0021.072] I> BCH address is : 0x80ffe000
[0021.075] I> component binary type is 17
[0021.079] I> PSC_FW header integrity check is success
[0021.084] I> Binary magic in BCH component 0 is PFWP
[0021.089] I> component binary type is 17
[0021.093] I> Size of crypto header is 8192
[0021.097] I> component binary type is 17
[0021.101] I> PSC_FW binary is read from storage
[0021.106] I> PSC_FW binary integrity check is success
[0021.111] I> Binary PSC_FW loaded successfully at 0x80fac6c0 (0x51940)
[0021.117] I> SCRATCH_PSC_FW_LOADADDR: 0x80fac6c0
[0021.122] I> Task: Load nvdec-fw
[0021.125] I> Chain: 0
[0021.127] I> Binary[7] block-117440512 (partition size: 0x100000)
[0021.133] I> Binary name: NVDEC
[0021.136] I> Size of crypto header is 8192
[0021.140] I> Size of crypto header is 8192
[0021.144] I> BCH of NVDEC read from storage
[0021.148] I> BCH address is : 0x800fe000
[0021.151] I> component binary type is 7
[0021.155] I> NVDEC header integrity check is success
[0021.160] I> Binary magic in BCH component 0 is NDEC
[0021.165] I> component binary type is 7
[0021.168] I> Size of crypto header is 8192
[0021.172] I> component binary type is 7
[0021.176] I> NVDEC binary is read from storage
[0021.181] I> NVDEC binary integrity check is success
[0021.186] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0021.195] I> Task: Load tsec-fw
[0021.198] I> TSEC-FW load support not enabled
[0021.202] I> Task: GPIO interrupt map
[0021.206] I> Task: SC7 context save
[0021.209] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0021.215] I> Task: Load MB2/Applet/FSKP
[0021.219] I> Loading MB2
[0021.221] I> Chain: 0
[0021.223] I> Binary[6] block-100663296 (partition size: 0x80000)
[0021.229] I> Binary name: MB2
[0021.232] I> Size of crypto header is 8192
[0021.236] I> Size of crypto header is 8192
[0021.240] I> BCH of MB2 read from storage
[0021.244] I> BCH address is : 0x8007e000
[0021.247] I> component binary type is 6
[0021.251] I> MB2 header integrity check is success
[0021.256] I> Binary magic in BCH component 0 is MB2B
[0021.261] I> component binary type is 6
[0021.264] I> Size of crypto header is 8192
[0021.268] I> component binary type is 6
[0021.272] I> MB2 binary is read from storage
[0021.277] I> MB2 binary integrity check is success
[0021.282] I> Binary MB2 loaded successfully at 0x80000000 (0x69410)
[0021.288] I> Task: Map CCPLEX SHARED carveout
[0021.292] I> Task: Prepare MB2 params
[0021.296] I> Task: Dram ecc test
[0021.299] I> Task: Misc NV security settings
[0021.304] I> NVDEC sticky bits programming done
[0021.308] I> Successfully powergated NVDEC
[0021.312] I> Task: Disable/Reload WDT
[0021.315] I> Task: Program misc carveouts
[0021.320] I> Task: Disable SCPM/POD reset
[0021.323] I> SLCG Global override status := 0x0
[0021.328] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-5b8edbc4-01Jun26-131747-0700)
I> Boot-mode : RCM BOOT
I> Entry timestamp: 0x0145cc4f
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0xe27000000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Check MC errors
I> Task: SMMU external bypass disable
I> Task: Enable hot-plug capability
I> Task: Set blob address
I> Task: TZDRAM heap init
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM not enabled
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0xe3c000000
I> Task: Load Misc-Config
I> Skip loading MISC-Config
I> Task: Configure OEM set LA/PTSA values
I> LA/PTSA updates are done from mb2-bct
I> Task: Validity check on SPE UART instance
I> Task: Load AUXP FWs
I> Unpowergating APE
I> Unpowergate done
I> spe ratchet check pass
I> rce ratchet check pass
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0xe26400000
I> dce ratchet check pass
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0xe32c00000
I> ape ratchet check pass
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0xe30000000
I> fsi ratchet check pass
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0xe32800000
I> xusb ratchet check pass
I> fsi: Authentication Finalize Done
I> Binary fsi loaded successfully at 0xe2e000000
I> Configuring FSI PLL
I> FSI_CHSM_ATCM DMA xfer done
I> FSI_CHSM_BTCM DMA xfer done
I> FSI_CPU0_ATCM DMA xfer done
I> FSI_CPU0_BTCM DMA xfer done
I> FSI_CPU0_CTCM DMA xfer done
I> FSI_CPU1_ATCM DMA xfer done
I> FSI_CPU1_BTCM DMA xfer done
I> FSI_CPU1_CTCM DMA xfer done
I> FSI_CPU2_ATCM DMA xfer done
I> FSI_CPU2_BTCM DMA xfer done
I> FSI_CPU2_CTCM DMA xfer done
I> FSI_CPU3_ATCM DMA xfer done
I> FSI_CPU3_BTCM DMA xfer done
I> FSI_CPU3_CTCM DMA xfer done
I> FSI_SRAM DMA xfer done
I> pva-fw ratchet check pass
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0xe26500000
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0xe26980000
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSI VMON
I> FSI VMON: recalibration done
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Enable FSI-SE clock
I> Task: Initialize SBSA UART CAR
I> Task: Prepare eeprom data
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Restore OEM firewalls to restrict Flush control
I> Task: Unhalt AUXPs
I> Unhalting SPE..
I> Enabling combined UART
����spe: early_init
����vic initialized
�Ḹ��tsc initialized
����aon lic initialized
�ุ��spe: tag is aba4fbe46f5cf77a32ef5977211b71e5
����spe: SafeRTOS v8.4
�ุ��spe: init
����scheduler initialized
�ุ��aon hsp initialized
����tag initialized
�ุ��tcu initialized
����bpmp ipc initialized
�ุ��spe: late init
����cpu_nic clock initialized
�ุ��apb clock initialized
����pm initialized
�ุ��bpmp hsp initialized
����top1 hsp initialized
�ุ��ccplex ipc initialized
����spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load HV/CPUBL
I> Task: Load TOS
I> cpubl ratchet check pass
I> tos ratchet check pass
I> NSDRAM co base 0x80000000 size 0xda5dc0000
I> cpubl nsdram co=1 encryption=1
I> cpubl: Authentication Finalize Done
I> Binary��
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is bfff9e30f72531a69d7e98af55204154
bpmp: combined binary md5 is 12a7d326b445a78a99d0041a8092ae44
bpmp: firmware tag is 12a7d326b445a78a99d0-bfff9e30f72
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
ini��[ 7.950617] Camera-FW on t234-rce-safe (FuSa) started
��tialized regulator
��TCU early console enabled.
[TS:1060543986499846144]DCE Started
[TS:1062590388092534784]DCE_R5_Init
[TS:1064767665928667136]MPU enabled
[TS:1066885690395983872]DCE_SW_Init
[TS:1067255929461800960][dce_mem_init_from_gsc] Failed to get ast region 2 mapping rc=:0x184549380
[TS:1068042767470428160]Using fdt fr�� cpubl loaded successfully at 0xe21c00000
��om ��initialized avfs_clk_platform
initialized powergate
��I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0xe3bd71640
��dce��initialized dvs
��_fw
��initialized clk_mach_config
suspend progress: 0x0
initialized suspend
initialized strap
initialized mce_dbell
��I> OPTEE dtb: 0xe3beff400->0xe38040020 sz 0x3068
I> [0] 0x80000000 sz 0xda5dc0000
I> [1] 0xe3c000000 sz 0x4000000
I> NS mem ranges set
I> eks ratchet check pass
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0xe38020000
I> EKB detected (length: 0x410) @ VA:0xe38020000
I> Task: Compute cpubl params hash
I> Added cpubl params hash.
I> Task: Unhalt FSI
I> ��MODS: CHSM firmware version 1.2.3 (a2dc4fb)
Overtemp Threshold set to 0xec0
Undertemp Threshold set to 0x3aa0
��FSI unhalt successful
I> Task: Trigger load TSEC ��initialized emc
initialized emc_mrq
��Unhalted R52 co Using DEFAULT(COMBINED_UART) for logging
��ley��
FSI INTERNAL ��initialized clk_cal
��FIRMWARE version: 1.0��initialized uphy_dt
��.0welco��initialized uphy_mrqHSIO UPHY reset has be��me to lk/��en de-asse��MP
boot ��rted 0x0start PLL 8 calibration timeout
FATAL ERROR [FILE=plat��args 0x24��form/drivers/uphy/uphy-tegra234.c, ERR_UID=2251]: start PLL 8 calib�� 0x13 0x0 0x30c70839
INIT: cpu 0��ration failed
r0_usr 0x5009a99a
r1_usr 0x000008cb
r2_usr 0x50038778
r3_usr 0x50181edc
r4_usr 0x50002148
r5_usr 0x50038778
r6_usr 0x000008cb
r7_usr 0x5009a99a
r8_usr 0x50181edc r8_fiq 0x00000000
��, calling��r9_usr 0x5020456c r9_fiq 0x00000000
r10_usr 0x00000009 r10_fiq 0x00000000
r11_usr 0x50080006 r11_fiq 0x00000000
r12_usr 0�� hook 0x1c659 (versio��x50181b90 r12_fiq 0x00000000
sp_usr 0x50181ec0 sp_fiq ��n) at level 0x3ffff, ��0x50010820 sp_irq 0x50010c00
sp_svc 0x50011400 sp_abt ��flags 0x1
version:
a��0x50010800 sp_und 0x50010770
lr_usr 0x50003361 lr_fiq ��rch: ARM
platf��0x00000000 lr_irq 0x50001022
lr_svc 0x5000a738 lr_abt ��orm: FSI_VDK
targe��0x00000000 lr_und 0x5000214c
pc 0x50002148
spsr 0x20000010
fpscr 0x80000010��t: FS��
00: base: 50000000 size: 00800000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
01: base: 00000000 size: 40000000 XN P_RW U_RW Shareable strongly-ordered
02: base: 00000000 size: 000000��I_VDK
project: FS��40 X P_RO U_NA Non-shareable outer: WB, no WA inner: W��I_VDK_BRINGUP
buildi��B, no WA
03: base: 50000000 size: 00010000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.1: base: 50020000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.2: base: 50040000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.3: base: 5006��d: P61��0000 size: 00020000 X P_RO U_RO Non-shareab��K7_LOCAL
��le outer: ��initializ��WB, no WA inner: WB, no WA
04.4: base: 5008��ing heap
calling cons��0000 size: 00020000 X P_RO U_RO��tructors
initializing�� Non-shareable outer: WB, no WA �� mp
initializing thre��inner: WB, no WA
04.5: base: 500a0000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inn��ads
initializing timers
initiali��er: WB, no WA
04.6: base: 500c0000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
05.1: base: 500c4000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.2: base: 500c��zing port��8000 size: 00004000 XN P_RW U_RW Non-shareab��s
creating bootstrap ��le outer: WB, no WA inner: WB, no WA
05.3: base: 500cc000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.4: base: 500d0000 s��completio��ize: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB��n thread
��, no WA
05.5: base: 500d4000 size: 00004000��top of bootstrap2()
c�� XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.6: base: 500��reating b��d8000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.7: base: 500dc000 size: 00004000 XN P_��ootstrap completion t��RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
06: base: 50180000 size: 0008000��hread for cpu 1
��0 XN P_RO U_NA Non-shareable outer: WB, no WA inner: WB, no WA
07: base: 507c0000 size: 00040000 XN P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
08: base: 50202000 size: 00002000 XN P_RW U_RW Non-shareable outer: WT, no WA inner: WT, no WA
10: base: 40070000 size: 00010000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
15: base: 50180000 size: 00002000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
Bootstrap@0x50218f40 sp 0x50181ec0 stack: 50180000 - 50181ffc
Per task regions for Bootstrap
04: base: 50180000 size: 00002000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
Enable MMIO: 1, Enable data R/W: 1
call stack:
sp 0x50181ec0 pc 0x50002148
sp 0x50181ec0 pc 0x50003360
sp 0x50181ed8 pc 0x5003876c
sp 0x50181f20 pc 0x500395ae
sp 0x50181f78 pc 0x5002f290
sp 0x50181fb8 pc��creating �� 0x5002dc90
sp 0x50181fe0 pc 0x50069766
sp 0x50181ff8 pc 0xaaaaaa��bootstrap��aa
eht_idx_find: 0xaaaaaaaa not a valid code address
no eidx for �� completi��0xaaaaaaaa
��on thread for cpu 2
��blo��creating bootstrap completion thread for cpu 3
��b��releasing 3 secondary cpus
initializing platform
��INIT: cpu 1, calling hook 0x1148d (arm_generic_timer_init_secondary_cpu) at level 0x6ffff, flags 0x2
INIT: cpu 2, calling hook 0x1148d (arm_generic_timer_init_secondary_cpu) at level 0x6ffff, flags 0x2
2
s
1
2
3
0
0
s
NvHsm_Init : initializing SCE HSM Interrupts
NvHsm_Init : module initialized
��k: ��sc7 : LIC init - Done
��Loa��sc7 : BPMP_HSP SM6 and SM7 init - Done
��d a��sc7 : FSI SC7 Init Done
initializing target
��nd ��calling apps_init()
��aut��starting app shell
��hen��entering main console p
t
d
t
I
8
��Info: ccplex_to_fsi_mailbox_init: tegra_hsp_init success for HSP_CCPLEX_TO_FSI_FSICOM
��I> ��Info: ccplex_to_fsi_mailbox_init: tegra_hsp_set_sm_type success for HSP_CCPLEX_TO_FSI_FSICOM, SM_CCPLEX_FSI_8
D
8
X
8
��Info: chsm_hsp_init: tegra_hsp_init success for FSI_HSP_TX
Info: chsm_hsp_init: tegra_hsp_set_sm_type success for FSI_HSP_TX, SM_INDEX 0, and HSP_SM_TYPE_128
��I> ��Info: chsm_hsp_init: tegra_hsp_init sX
8
b
I> OPTEE arg3: 0xe38040020
I> Task: Cleanup MISC config loader handler
I> Task: Disable MSS perf stats
I> Task: Program display sticky bits
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Clear dec source key
I> MB2 finished��NOTICE: BL31: v2.13.0(release):l4t-r39.2.0
NOTICE: BL31: Built : 2026-06-01 20:08:13
��[TS:1184276612703584256]Admin Task Init
[TS:1184633545960718336]Admin Task Init complete
[TS:1185049595147714560]Print Task Init
[TS:1185444272577445888]RM Task Init
[TS:1185789944430329856]SHA Task Init
[TS:1186103524287578112]SHA INIT
[TS:276247245]Admin Task Started
[TS:276313339]RM Task Started
[TS:276382824]DCE SC7 SHA Disabled
[TS:276452639]RM Task Running [id:2]
��I/TC:
I/TC: Non-secure external DT found
��ERROR: camera-ip/isp5/isp5.c:2709 [isp5_pm_init] “ERROR: Failed to turn isp1 power on”
BUG: core/init/init.c:129 [init_all] “*** FIRMWARE INIT FAILED AT LEVEL 95 FEATURE ID 13 ***”
��I/TC: Switching console to device: /serial@0c198000
I/TC: OP-TEE version: 4.6 (gcc version 15.3.0 (GCC)) #1 Mon Jun 1 21:16:36 UTC 2026 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
t23x_minimal UEFI firmware (version v39.2.0 built on 2026-05-13T20:53:10+00:00)
I am seeking for any guidance or any suggestion.
Thanks,
