Agx orin industry flash
I am currently using the official development board for AGX Orin to successfully flash AGX Orin Industry. However, when I try to flash AGX Orin Industry using my own custom board, a flashing error occurs as follows:
[ 8.1073 ] ERROR: might be timeout in USB write.
Error: Return value 3.
I now know that NVIDIA’s development board uses a USB 3.0 port for flashing, while the flashing port on my custom board is USB 2.0. I want to confirm whether it is necessary to use a USB 3.0 interface to flash AGX Orin Industry.
No, it has nothing to do with USB3.0 interface. Even default flash is using USB2. USB3 flash requires extra fuse to make it enabled.
You could share full log first. Just 2 lines are not sufficient.
