AGX-Orin Kernel panic when using PTP4L cmd
Dear Sir:
We are using AGX-ORIN ( 900-13701-0050-000 ) with our own designed carrier board. The moudle is flashed with flash command according to doc Quick Start — Jetson Linux
Developer Guide 34.1 documentation (nvidia.com)
The flashed Jetson version is  35.3.1
Currently, we usd PTP tool to sync clock with outside  ridar. After we excuted the command : **sudo ptp4l  -i eth0 -m**, the system will breakdown. The desktop is frozen and there is no any reponse when move the mouse. Here is the debug com output.
Could you kindly give some indications to solve this problem. Thanks much.
The boot log is also provied for your reference.
orin-log.txt (97.6 KB)
Sorry for the late response.
There is no further forward with the problem. Help is still needed.
Please refer to this topic thread to do further testing/debugging. You may also try the same on AGX Orin developer kit.
How to enable IEEE1588 ptp on orin sdk
Thanks Danelll. I will test according to the method. Any results will be replied here.
