AGX Orin (L4T 36.3) — initrd flash kernel fails to boot, USB device mode dead
Hey folks,
AGX Orin on L4T 36.3 / JetPack 6.0 (firmware 36.3.0-gcid-36191598), rootfs on eMMC, [devkit / custom carrier].
The unit stopped booting to a usable state after I installed chromium via apt. It now stalls on two 90s timeouts (/dev/ttyTCU0 and “Configure USB flashing port for device mode”), with nv-l4t-usb-device-mode.service exiting status=1/FAILURE and nvpower.service failing. nvargus-daemon starts fine.
All USB paths to the unit are gone: the gadget network (192.168.55.1) never comes up, USB serial is unavailable, and a USB keyboard gets no VT switching response.
What I can’t explain: recovery mode works (0955:7023 APX) and the RCM transfer completes cleanly — all 19 binaries sent, “RCM-boot started” at 4.0s. But then:
Waiting for target to boot-up… (x120)
Timeout
Device failed to boot to the initrd flash kernel.
Command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --usb-instance 1-2 --initrd jetson-agx-orin-devkit mmcblk0p1
After the attempt the APX device disappears and nothing re-enumerates — no USB device, no network interface, no block device on the host. Already tried multiple ports (USB 2 and 3), different cables, direct connection with no hub, and --usb-instance set from lsusb -t.
Since the initrd kernel is a clean NVIDIA image with none of my software on it, and it fails to bring up USB device mode the same way the installed system does, I don’t think this is my rootfs. Is this a known failure mode on 36.3? Could a pinmux/DTB mismatch on the flashing port cause a successful RCM boot followed by no USB enumeration? The DTB in the flash sequence is tegra234-p3737-0000+p3701-0005-nv.dtb.
I would appreciate any pointers to resolve this issue. Thanks!
Please try to use below commands
$ sudo ./flash.sh jetson-agx-orin-devkit internal
Thanks David for the quick reply.
Before I run a full flash — I have unrecovered data on the eMMC I’d like to pull off first: user files under /home, plus a custom camera DTB and driver stack that aren’t fully mirrored elsewhere. My understanding is that flash.sh without -k rewrites the partition table and overwrites the APP partition, so that data would be lost. Please correct me if that’s wrong.
Two questions:
  1. Is there any way to reach the eMMC on this unit given that the initrd flash kernel won’t boot? I’m considering booting an arm64 live USB via the F11 boot manager and mounting mmcblk0p1 from there. Is there a better approach, or a way to make the initrd path work?
  2. Does the initrd failure itself suggest anything? RCM boot completes cleanly and the target then never enumerates. Since that initrd is a clean NVIDIA image with none of my software on it, I’d expect it to boot regardless of the state of the rootfs — which is what makes me think something below the OS is involved. If a full flash fixes the symptom without explaining that, I’m concerned the same failure could recur.
Happy to flash once I’ve recovered the data, but I’d like to understand the root cause if possible, since I have a second unit provisioned the same way.
Thanks again.
Please flash with the USB as a rootfs and you should mount the emmc and backup your data.’
It’s better to capture a serial console log when next time hit the issue. For current status, we recommend full flash the device.
