Based on the provided information, it appears that you are trying to configure the PCIe lanes on the Jetson AGX Orin module. The PCIe lanes are controlled by the pinmux configuration, which is typically done using the OrinJetsonSeriesPinmuxConfigTemplatev21xlsm spreadsheet.
To configure the four groups of PCIe lanes (pexl0, pexl1, pexl2, and pexl3) as PCIe, you will need to modify the pinmux configuration in the spreadsheet. Here are the steps to follow:
- Open the OrinJetsonSeriesPinmuxConfigTemplatev21xlsm spreadsheet and navigate to the “Pinmux Configuration” sheet.
- Locate the rows corresponding to the PCIe lanes you want to configure (pexl0, pexl1, pexl2, and pexl3).
- In the “Pinmux Mode” column, select “PCIe” as the mode for each of the PCIe lanes.
- In the “Pinmux Configuration” column, select the corresponding PCIe configuration for each lane. For example, for pexl0, you might select “PCIe0” as the configuration.
- Make sure to update the “Pinmux Configuration” column for all four PCIe lanes (pexl0, pexl1, pexl2, and pexl3).
- Save the changes to the spreadsheet.
If you are unable to find the entries for the PCIe lanes in the spreadsheet, it is possible that they are not included in the template. In this case, you may need to add the PCIe lanes manually to the spreadsheet.
To add the PCIe lanes manually, follow these steps:
- Insert new rows for each of the PCIe lanes you want to configure (pexl0, pexl1, pexl2, and pexl3).
- In the “Pin Name” column, enter the name of the PCIe lane (e.g. “pexl0”).
After modifying the pinmux configuration, you will need to recompile the device tree and update the firmware on the Jetson AGX Orin module.
It’s worth noting that the pinmux configuration can be complex and requires careful attention to detail. If you are unsure about any aspect of the configuration, it is recommended to consult the Jetson AGX Orin documentation or seek assistance from a qualified engineer.
In comparison to other Jetson modules, the pinmux configuration for the Jetson AGX Orin module is similar, but with some differences in the specific pin assignments and configurations. The Jetson TX2, for example, has a different pinmux configuration template, and the PCIe lanes are controlled by different pinmux modes and configurations.
In summary, to configure the four groups of PCIe lanes on the Jetson AGX Orin module, you will need to modify the pinmux configuration in the OrinJetsonSeriesPinmuxConfigTemplatev21xlsm spreadsheet, either by updating the existing entries or adding new rows manually. After modifying the pinmux configuration, you will need to recompile the device tree and update the firmware on the module.
