Hi NVIDIA Jetson Team,
I’m encountering a recurring storage issue on the AGX Orin during a real-time object detection task and would appreciate your help.
System setup:
- Hardware: Jetson AGX Orin (64GB)
- Storage: NVMe SSD [8TB], formatted as EXT4
- JetPack version: [5.1.2]
- Power supply: [official 19V adapter / custom]
- Software: Python 3.8, multi‑process application continuously recording sonar data, logging, and running PyTorch‑based detection
Problem:
After several hours of continuous writes, the SSD starts returning I/O errors and the filesystem becomes read-only. The application fails with OSError: [Errno 5] Input/output error and then OSError: [Errno 30] Read-only file system. The kernel also reports Buffer I/O error on dev nvme0n1p1 and EXT4-fs error.
Log excerpts:
kernel: [29618.772596] Buffer I/O error on dev nvme0n1p1, logical block 999849984, lost sync page write
Aug 8 14:48:47 yu-desktop sonar_fls.sh[40892]: OSError: [Errno 5] Input/output error: ‘./DataRecords/DataRecord_2026-08-08_144847fls.dat’
Aug 8 14:48:47 yu-desktop kernel: [31656.196147] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1579: inode #95816148: comm python: reading directory lblock 0
Aug 8 14:48:48 yu-desktop sonar_fls.sh[40893]: OSError: [Errno 5] Input/output error: ‘./DataRecords/DataRecord_2026-08-08_144848fls.dat’
Aug 8 14:48:48 yu-desktop sonar_fls.sh[3282]: OSError: [Errno 30] Read-only file system
… (full dmesg can be attached if needed)
Questions:
- What are the likely causes of the
Buffer I/O erroron the NVMe under sustained write load? (SSD defect, overheating, insufficient power, compatibility?) - Is the automatic EXT4 read-only remount expected behavior? Can it be tuned without risking data loss?
- What preventive steps do you recommend? (Recommended SSD models, extra cooling, mount options, alternative filesystems, or write-caching strategies)
- Best way to diagnose the drive health post-incident on Jetson (nvme-cli, SMART)?
Full dmesg and nvme list output are available if needed. Thanks for any guidance!
