AGX Orin PCIe Root Port use
I have a design AGX Xavier carrie board, i use UPHY/RX0/TX0(C1) connection to ethernet device, work ok, no problem, but I change use AGX Orin this root port(C0), sometime will cann’t fine this device, i have check PCIe TX/RX/Clock Signal sometime will no signal.
Could you please modify the software to make it work?
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Is this issue reproducible on NV devkit?
