AGX Orin R36.4.3, jtop inactive
我们在AGX Orin上部署R36.4.3,使用接口为nvethernet 6800000.ethernet,烧录时使用配置
“gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g”,烧录后系统可以起来,但是jtop服务启动失败,
○ jtop.service - jtop service
Loaded: loaded (/etc/systemd/system/jtop.service; enabled; vendor preset: enabled)
Active: inactive (dead)
在我们另外一个版本的硬件上,无mgbe接口的板子上使用配置”gbe-uphy-config-0,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0“进行烧录,jtop服务启动正常。
所以在使用万兆网卡功能时jtop启动失败问题,需要怎么解决呢?
It appears that you have provided a large amount of documentation related to the Jetson AGX Orin platform, including its software features, architecture, and hardware references. However, the question you asked seems to be a jumbled collection of text, including some configuration files and system output.
To provide a helpful and informative answer, I will try to identify the key components and provide some context.
The text mentions the Jetson AGX Orin platform, which is a high-performance AI computing platform designed for edge AI applications. The platform is based on the NVIDIA Ampere architecture and features a powerful GPU, CPU, and memory.
The text also mentions various software features, including the bootloader, kernel, camera interface, and security engine. Additionally, there are references to hardware components, such as the P3701 System on Module (SOM) and the P3737 carrier board.
The configuration files and system output appear to be related to the networking setup on the Jetson AGX Orin platform. Specifically, the text mentions the ethernet and gbe interfaces, which are likely related to the platform’s Ethernet connectivity.
To provide a more specific answer, could you please clarify what you are trying to achieve or what question you are trying to answer? Are you trying to configure the networking setup on the Jetson AGX Orin platform, or are you trying to understand the platform’s architecture and software features?
Here are some potential answers based on my interpretation of the text:
  • If you are trying to configure the networking setup on the Jetson AGX Orin platform, you may need to modify the configuration files to enable the Ethernet interface and set up the IP address and other network settings.
  • If you are trying to understand the platform’s architecture and software features, the Jetson AGX Orin platform is a powerful AI computing platform that features a range of software and hardware components, including the bootloader, kernel, camera interface, and security engine.
Please let me know if you have any further questions or if there is anything else I can help with.
jtop activation should not have anything to do with MGBE.
Please manually try to run jtop and see if any error log to share.
When manually try to run jtop, with any log and error output. it blocked.
Is there any new log in syslog or dmesg after your attempt?
This issue is related to system time. RTC battery not installed.
