Hi Nvidia,
I’m using Marvell 88E1512 Phy on AGX Orin.
I have mainly referred to the following links and documents.
Currently, I can see Ethernet in the Settings, but it always shows as unplugged.
pnmux
eqos_txc_pe0 {
nvidia,pins = "eqos_txc_pe0";
nvidia,function = "eqos";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
eqos_td0_pe1 {
nvidia,pins = "eqos_td0_pe1";
eqos_td1_pe2 {
nvidia,pins = "eqos_td1_pe2";
eqos_td2_pe3 {
nvidia,pins = "eqos_td2_pe3";
eqos_td3_pe4 {
nvidia,pins = "eqos_td3_pe4";
eqos_tx_ctl_pe5 {
nvidia,pins = "eqos_tx_ctl_pe5";
eqos_rd0_pe6 {
nvidia,pins = "eqos_rd0_pe6";
nvidia,pull = <TEGRA_PIN_PULL_UP>;
nvidia,tristate = <TEGRA_PIN_ENABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
eqos_rd1_pe7 {
nvidia,pins = "eqos_rd1_pe7";
eqos_rd2_pf0 {
nvidia,pins = "eqos_rd2_pf0";
eqos_rd3_pf1 {
nvidia,pins = "eqos_rd3_pf1";
eqos_rx_ctl_pf2 {
nvidia,pins = "eqos_rx_ctl_pf2";
eqos_rxc_pf3 {
nvidia,pins = "eqos_rxc_pf3";
eqos_sma_mdio_pf4 {
nvidia,pins = "eqos_sma_mdio_pf4";
eqos_sma_mdc_pf5 {
nvidia,pins = "eqos_sma_mdc_pf5";
soc_gpio17_pg4 {
nvidia,pins = "soc_gpio17_pg4";
nvidia,function = "rsvd0";
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
soc_gpio18_pg5 {
nvidia,pins = "soc_gpio18_pg5";
dtsi
ethernet@2310000 {
status = "okay";
phy-mode = "rgmii-id";
phy-handle = <&phy>;
nvidia,phy-reset-gpio = <&gpio TEGRA234_MAIN_GPIO(G, 5) 0>;
nvidia,mac-addr-idx = <0>;
nvidia,skip_mac_reset = <0>;
nvidia,mdio_addr = <0>;
nvidia,pause_frames = <0>;
mdio {
compatible = "nvidia,eqos-mdio";
#address-cells = <1>;
#size-cells = <0>;
phy: phy@0 {
reg = <0>;
nvidia,phy-rst-pdelay-msec = <224>; /* msec */
nvidia,phy-rst-duration-usec = <10000>; /* usec */
interrupt-parent = <&gpio>;
interrupts = <TEGRA234_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
marvell,copper-mode;
/* Setup LED[2] as interrupt pin (active low) */
marvell,reg-init = <0x03 0x12 0x7fff 0x880>;
$ cat /proc/interrupts | grep eth
202: 1 0 0 0 0 0 0 0 GICv3 226 Level eth0.common_irq
203: 0 0 0 0 0 0 0 0 GICv3 218 Level eth0.vm0
204: 0 0 0 0 0 0 0 0 GICv3 219 Level eth0.vm1
205: 0 0 0 0 0 0 0 0 GICv3 220 Level eth0.vm2
206: 0 0 0 0 0 0 0 0 GICv3 221 Level eth0.vm3
304: 0 0 0 0 0 0 0 0 2200000.gpio 39 Level 2310000.ethernet:00
dmesg
dmesg.log (64.2 KB)
