I flashed Orin with ROOTFS_AB=1. There A and B partitions came asymetric and there is no UDA partition:
root@orin:~# gdisk -l /dev/mmcblk0
GPT fdisk (gdisk) version 1.0.5
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: present
Found valid GPT with protective MBR; using GPT.
Disk /dev/mmcblk0: 124321792 sectors, 59.3 GiB
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): 202E73F0-83C8-465F-8400-1A008A8C6502
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 40, last usable sector is 124321752
Partitions will be aligned on 8-sector boundaries
Total free space is 24 sectors (12.0 KiB)
Number Start (sector) End (sector) Size Code Name
1 3050048 59673151 27.0 GiB 0700 APP
2 59673152 124321752 30.8 GiB 0700 APP_b
3 40 262183 128.0 MiB 0700 A_kernel
4 262184 263719 768.0 KiB 0700 A_kernel-dtb
5 263720 328487 31.6 MiB 0700 A_reserved_on_user
6 328488 590631 128.0 MiB 0700 B_kernel
7 590632 592167 768.0 KiB 0700 B_kernel-dtb
8 592168 656935 31.6 MiB 0700 B_reserved_on_user
9 656936 820775 80.0 MiB 0700 recovery
10 820776 821799 512.0 KiB 0700 recovery-dtb
11 821800 952871 64.0 MiB EF00 esp
12 952872 3050023 1024.0 MiB 0700 reserved
Is there a way to enable/configure the UDA partition (e.g.shrink APP_b to the size of APP and and add UDA)? I would like to have configuration similar to Xavier, which is:
1 40 29360167 14.0 GiB 0700 APP
2 29360168 58720295 14.0 GiB 0700 APP_b
42 60204288 61079518 427.4 MiB 0700 UDA
