Agx orin set qbv failed
Using nvethernet_sample_app to set qbv on agx orin, error occurred: IOCTL Error in program_est(), and I output the error detail: IOCTL Error in program_est(), ret: -1, error: Operation not permitted
Where did you get such “nvethernet_sample_app”?
Get the driveos 6.0.8.1 from nvidia NGC, install driveos on ubuntu 20.04 virtual machine. The nvethernet_sample_app is built from /drive/drive-linux/samples/nvethernet/ether_api.c. And using the nvethernet_sample_app to configurate qbv on agx orin with ubuntu 20.04
Are you reporting an issue for Drive platform or Jetson? These two platforms are different.
Your issue is filed in Jetson forum.
Thanks for your reminding.
I want to configure qbv of TSN on Jetson AGX Orin, so I find the nvethernet_sample_app. If the nvethernet_sample_app just only apply on Drive AGX Orin, is Jetson AGX Orin support the qbv of TSN
No, it does not support qbv. QBV is only validated on Drive but not Jetson.
Which TSN protocols are Jetson supported?
I find TSN API on TSN API | NVIDIA Docs
Actually if TSN is not listed in this page,
https://docs.nvidia.com/jetson/archives/r35.6.0/DeveloperGuide/SO/JetsonOrinSeries.html
Then even TSN is not supported.
