I am trying to setup a Nvidia Jetson AGX Orin Developer Kit in a headless configuration using a Linux system.
I am following the steps mentioned here .
When I run the the command “sudo screen /dev/ttyACM0 115200” to complete the CUI-based “Jetson Initial configuration” (oem-config) using the PC’s keyboard I see a blank new screen terminal open up.
I do not see any configuration CUI. Thus I am stuck with the setup for the Orin Developer Kit.
I also tried re-flashing the Orin Dev Kit using the steps mentioned under the “(1) How to use SDK Manager to Flash L4T BSP” section at Jetson AGX Orin Devkit User Guide but I get the same issue.
I encounter the same issue while trying the setup over a Windows 10 system using Putty and MobaXterm.
