is it recommended to use the AGX orin SOM at maximum of 95% or 90% RH? because we have the requirement and sometimes Humidity may reaches >90%RH at our environment.
could you please share any recommendations to use the AGX orin SOM during >90%RH
Thanks for your response. Yes we are also aware of that. We would like to have the suggestions from nvidia to operate the SOM as >90%RH. because our environment may reach >90%RH.
Can you please share the absolute Humidity rating for the same?
Can i have any updates on this query? Please correct me if i any thing is wrong. As per my understanding, Relative Humidity is depends on Temperature as well (usually is inversely propositional).
That’s why i’m asking, Can we use ORIN SOM at >90%RH while ambient is controlled temperature (i.e, 5 to 10C as max)
