Agx orin 如何从ssd启动
agx orin 开发板
jp6.2
emmc能正常启动,如何能切到ssd启动。根目录挂在在ssd
Hello @sorry.shao!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
Hi @sorry.shao,
JetPack 6.2 supports booting from an NVMe SSD on the Jetson AGX Orin developer kit. Please see the NVMe boot documentation.
Could you clarify:
  1. Is your SSD an NVMe drive, and have you already installed JetPack onto it?
  2. Is the root filesystem (/) currently on the SSD, or is that what you want to set up?
  1. 是的,是nvme格式的
  2. 现在是emmc根目录,没办法切到ssd启动系统
Have you already flashed JetPack 6.2 onto the NVMe SSD? If so, which method or command did you use?
用如下命令:
sudo ./flash.sh jetson-agx-orin-devkit external
With the standard AGX Orin configuration, flash.sh ... external configures the board to use an external root filesystem, but does not write the root filesystem onto the NVMe SSD.
To install the system onto the SSD, please follow the JetPack 6.2 NVMe initrd-flashing procedure.
Back up any important SSD data before flashing, as it can be overwritten.
用如新指令,还是没成功
sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --external-only --external-device mmcblk0p1   -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml   --network usb0   lcfc_jp6.2_b600_32g external
Not sure how you got that command… please try this.
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 lcfc_jp6.2_b600_32g  internal
If it got failed, show us the log file instead of only telling “it fails”.
用此指令刷机还是会报错,这是什么原因,谢谢
/mnt/internal/flash.cfg: line 2: syntax error near unexpected token `>>'
Flash failure
Either the device cannot mount the NFS server on the host or a flash command has failed. Check your network setting (VPN, firewall,...) to make sure the device can mount NFS server. Debug log saved to /tmp/tmp.iuyuflDQMY. You can access the target's terminal through "sshpass -p root ssh root@fc00:1:1:0::2"
Cleaning up...
flash_faillog.txt (303.0 KB)
Hi @sorry.shao,
The log shows a syntax error in the generated flash configuration:
Could you share the first 20 lines of this flash.cfg file?
Your command also uses lcfc_jp6.2_b600_32g. Are you using the NVIDIA developer kit carrier board or an LCFC carrier board? You mentioned you are using AGX Orin Devkit in the very beginning …
是我们公司自定义的板子,应该是lcfc_jp6.2_b600_32g文件修改的有问题,用英伟达开发板jetson-agx-orin-devkit没有报错,我在检查一下
OK. Thanks.
我通过修改uefi配置,也能直接从ssd启动,如果批量生产是不是可以修改uefi 代码来实现
Hi @sorry.shao,
Yes. For mass production, you can set NVMe first in DefaultBootPriority in your BSP’s L4TConfiguration.dtbo, for example:
nvme,emmc,usb,sd,ufs
Please follow the R36.4.3 default boot-order configuration guide to edit and regenerate the DTBO.
This sets the default boot order on the first boot after flashing. Please validate it on your custom carrier board before mass production.
