Hello, I’ve been developing the AGX Orin 64GB using a custom carrier board and have run into issues getting USB working.
When running lsusb nothing appears. I’ve tried many different USB devices and I have used this carrier board with Jetpack 5.1.2 and had no issues with USB. There appears to be some changes in the device tree that could have something to do with this.
Notes:
I have only tested USB3 (USB2_3 on schematics, pins G10 and G11).
I do not have EEPROM on my carrier board so I made the following modification to tegra234-mb2-bct-common.dtsi so the Orin doesn’t go into a busy spin.
- cvb_eeprom_read_size = <0x100>
+ cvb_eeprom_read_size = <0x0>
I also do not have the GB phy so I made the following modification to p3701.conf.common
-ODMDATA="gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g";
+ODMDATA="gbe-uphy-config-0,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0";
I do not think these changes are related to the problem because when I plug the module into the old carrier board USB seems to work fine.
Here is the output of “dmesg | grep usb” when plugged into my custom carrier board:
[ 0.172340] usbcore: registered new interface driver usbfs
[ 0.172365] usbcore: registered new interface driver hub
[ 0.172384] usbcore: registered new device driver usb
[ 0.303628] usbcore: registered new interface driver usb-storage
[ 4.013403] usbcore: registered new interface driver usbhid
[ 4.013408] usbhid: USB HID core driver
[ 4.080501] usbcore: registered new interface driver snd-usb-audio
Here is the output when plugged into the official carrier board:
[ 0.172443] usbcore: registered new interface driver usbfs
[ 0.172470] usbcore: registered new interface driver hub
[ 0.172489] usbcore: registered new device driver usb
[ 0.302756] usbcore: registered new interface driver usb-storage
[ 4.084527] usbcore: registered new interface driver usbhid
[ 4.084533] usbhid: USB HID core driver
[ 4.151215] usbcore: registered new interface driver snd-usb-audio
[ 15.226116] tegra-xusb 3610000.usb: Adding to iommu group 55
[ 15.251851] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[ 15.251867] tegra-xusb 3610000.usb: xHCI Host Controller
[ 15.251892] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 15.252647] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[ 15.252681] tegra-xusb 3610000.usb: irq 125, io mem 0x03610000
[ 15.252848] tegra-xusb 3610000.usb: xHCI Host Controller
[ 15.252852] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 15.252857] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 15.270759] tegra-xudc 3550000.usb: Adding to iommu group 56
........ keeps going
There must be some with the Tegra xHCI controller preventing these interfaces from working.
I would appreciate any help!
