AGX Orin vs Orin NX Dimensions LxWxH
Hello all,
I’m trying to get the tech specs on the AGX Orin and Orin NX 16GB. I found the length and width but there isn’t anything I can find on height.
Is the Orin NX the same as the Orin Nano in overall dimension?
100 mm x 79 mmx 21 mm?
Are all AGX Orin Overall dimensions 110mm x 110mm x 71.65mm?
I’m interested in the AGX Orin but the height is going to be an issue. The 110mmx110mm just barely will fit for me but the height is going to be a problem. I don’t suppose there are other carrier boards or different heat sync option. Is the general bulk of the height in the heat sink? Are there any other options to make the developer kit shorter or am I out of luck.
Yes.
Yes.
Please note, devkit is for development only, not for product.
Are there any other solutions to decrease the height of the AGX Orin?
On the Jetson Orin NX 16 it says “Up to 4 cameras (8 via virtual channels***)” yet I see only two connectors (22pin CSI connectors).? Are two cameras shared on each connector?
No such way for devkit.
Up to 4 cameras thru custom design.
