AGX Orin Weight
I see on these forums that the weight of the AGX Orin dev kit without packaging is 1.58 kg. What is the weight of just the module itself with its thermal transfer plate?
Hi, all the docs that can be provided are all in DLC. As you can see in current Orin module datasheet, the weight of module is TBD. It will be updated in future, please keep following that.
