Agx orin无法关机
AGX ORIN 64G,
jp5.1.1
客户自定义板子
关机的时候无法关机,会疯狂打印,请问一下是什么原因导致的,感谢
[  190.697666] ---[ end trace 6cefef3ed6531072 ]---
[  190.701995] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.711479] ---[ end trace 6cefef3ed6531073 ]---
[  190.715820] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.725312] ---[ end trace 6cefef3ed6531074 ]---
[  190.729646] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.739142] ---[ end trace 6cefef3ed6531075 ]---
[  190.743469] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.752978] ---[ end trace 6cefef3ed6531076 ]---
[  190.757297] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.766801] ---[ end trace 6cefef3ed6531077 ]---
[  190.771114] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.780626] ---[ end trace 6cefef3ed6531078 ]---
[  190.784946] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.794443] ---[ end trace 6cefef3ed6531079 ]---
[  190.798771] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.808263] ---[ end trace 6cefef3ed653107a ]---
[  190.812595] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.822085] ---[ end trace 6cefef3ed653107b ]---
[  190.826424] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.835902] ---[ end trace 6cefef3ed653107c ]---
[  190.840246] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.849740] ---[ end trace 6cefef3ed653107d ]---
[  190.854075] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.863572] ---[ end trace 6cefef3ed653107e ]---
[  190.867897] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.877398] ---[ end trace 6cefef3ed653107f ]---
[  190.881721] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.891232] ---[ end trace 6cefef3ed6531080 ]---
[  190.895547] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.905049] ---[ end trace 6cefef3ed6531081 ]---
[  190.909370] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.918872] ---[ end trace 6cefef3ed6531082 ]---
[  190.923197] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.932690] ---[ end trace 6cefef3ed6531083 ]---
[  190.937020] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.946519] ---[ end trace 6cefef3ed6531084 ]---
[  190.950847] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.960347] ---[ end trace 6cefef3ed6531085 ]---
[  190.964682] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.974168] ---[ end trace 6cefef3ed6531086 ]---
[  190.978496] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  190.987989] ---[ end trace 6cefef3ed6531087 ]---
[  190.992323] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  191.001828] ---[ end trace 6cefef3ed6531088 ]---
[  191.006147] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  191.015657] ---[ end trace 6cefef3ed6531089 ]---
[  191.019970] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[  191.029480] ---[ end trace 6cefef3ed653108a ]---
The Jetson AGX Orin 64GB (P3701-0005) is a production module that is part of the Jetson AGX Orin series. Here’s a comprehensive overview of this module and a comparison with other related modules:
Key Features:
  • 64GB of DRAM
  • Compatible with the Jetson AGX Orin reference carrier board (P3737-0000)
  • Flashes QSPI-NOR and eMMC
  • Part of the Jetson AGX Orin series, which is a high-performance AI computing platform
Comparison with Jetson AGX Orin 32GB:
  • The main difference between the Jetson AGX Orin 64GB and the Jetson AGX Orin 32GB (P3701-0004) is the amount of DRAM. The 64GB module has twice the amount of memory as the 32GB module.
  • Both modules are production modules and are compatible with the same carrier board (P3737-0000).
  • Both modules flash QSPI-NOR and eMMC.
Comparison with Jetson AGX Orin Developer Kit:
  • The Jetson AGX Orin Developer Kit (P3701-0000) is a development module that is part of the Jetson AGX Orin series. It has 32GB of DRAM and is only sold as part of a developer kit.
  • The Jetson AGX Orin 64GB module is a production module that is sold separately and is compatible with the Jetson AGX Orin reference carrier board (P3737-0000).
  • The developer kit is intended for development and testing, while the production module is intended for production use.
Comparison with Jetson AGX Orin Industrial:
  • The Jetson AGX Orin Industrial (P3701-0008) is a production module that is part of the Jetson AGX Orin series. It has 32GB of DRAM and is designed for industrial use cases.
  • The Jetson AGX Orin 64GB module is also a production module, but it has 64GB of DRAM and is not specifically designed for industrial use cases.
  • Both modules are compatible with the same carrier board (P3737-0000) and flash QSPI-NOR and eMMC.
In summary, the Jetson AGX Orin 64GB module is a high-performance production module with 64GB of DRAM, compatible with the Jetson AGX Orin reference carrier board. It is part of the Jetson AGX Orin series and is intended for production use.
Please upgrade to the r36.5 to cross check the problem.
您的意思就是jp5.1.1一直有这个问题,在后面的版本里面修复了此问题。
能在jp5.1.1上加补丁,修复此问题吗?
The issue shown in your log might have been resolved in BSP r36.x, so please upgrade and verify.
刚刚刷完机,验证10次,jp6.2.1确实能正常关机
只有在jp6的版本上才修复此问题了,jp5的版本都有问题吗,有没有jp5对于的补丁,能修复此问题呢
补充说明一下,
目前从log,怀疑和HDMI热插拔有关系; 实验验证:拔掉HDMI之后,在jp5.1.1不会复现此问题。
Yes, this issue is related to HDMI hot-plug and is only resolved in r36.x.
If you need to continue development on JP5.1.1, please use the workaround:
