[AGX Thor DevKit / T5000][R39.2.0] Power-on failure after power interruption within first seconds of boot (RTC-1-like) — Secure Boot NOT enabled
Summary
On a Jetson AGX Thor Developer Kit (T5000) powered with 19 V through the J83 Micro-Fit DC input, with an RTC coin cell installed, if DC input is removed within ~5 s after power-on and then quickly re-applied, the system fails to power on with high reproducibility. Pressing the power button does not recover it.
Signal measurements show the carrier’s button MCU (EFM8SB10) asserts MODULE_POWER_ON, but the module never asserts CARRIER_POWER_ON (L62 stays at ~0.5 V). The EFM8 then times out after 100 ms and powers off, as its firmware is designed to do.
The symptom matches erratum RTC-1 in Jetson Thor Modules Hardware Errata DA-12711-001_v02 and PCN 213441. However, this unit does not use Secure Boot: UEFI Secure Boot is disabled with no keys enrolled, and the module appears not to be PKC-fused. The erratum lists Secure Boot as a required condition.
We would like to confirm whether RTC-1 / PCN 213441 also applies to non-Secure-Boot systems, and whether this module revision is affected.
Environment
Item Value
Platform Jetson AGX Thor Developer Kit (P4071 carrier, P3834-0008 / T5000 module)
TNSPEC 3834-400-0008-G.5-1-1-p3834-0008-p4071-0000-nvme-
Board IDs (/proc/device-tree/chosen/ids) 3834-0008-400 4071-0000-200
L4T / JetPack R39.2.0 (JetPack 7.2), GCID 45755727; bootloader updated via the stock capsule TEGRA_BL_3834_agx.Cap (nvidia-l4t-bootloader 39.2.0-20260601141651)
Power input 19 V DC via J83 (Micro-Fit 3.0 2x2 DC input, VCC_DCIN). USB-C PD is not used, so no PD negotiation is involved.
RTC battery Installed
UEFI Secure Boot Disabled: SecureBoot=0, SetupMode=1, PK/KEK/db not present; DT linux,uefi-secure-boot=2
Fuse-level Secure Boot Not directly readable from Linux. efuse_odm_id_0/1 and efuse_odm_info all read 0x00000000, and the unit boots the stock NVIDIA capsule, so it appears not to be PKC-fused.
Power sequencer nvvrs_pseq 5-003c: Vendor ID 0x9, Model Rev 0x86 (rtc0 = nvvrs-pseq-rtc)
Steps to reproduce
  1. Install an RTC coin cell and connect 19 V DC to J83 (Micro-Fit DC input). The system powers on.
  2. Within about 5 s of power-on, remove the 19 V input at J83.
  3. Re-apply 19 V to J83 within 5 s of removing it.
  4. Result: the system does not power on, and it stays off after pressing the power button.
  • Reproducibility: about 80% of attempts when the off time is 5 s or less.
  • Recovery: removing DC input completely for 10 s and then re-applying it recovers the system.
  • With the RTC coin cell removed: the failure rate drops noticeably, but the failure still occurs occasionally. The issue is strongly RTC-related, but the coin cell may not be the only thing keeping the failed state across a short power loss.
Observations (oscilloscope / DMM, failed state, power button pressed)
Ball names refer to the 699-pin module connector J3, per the P4071 A02 schematic and netlist.
Signal Observation
EFM8 (U79) P1.3 VIN_PWR_ON Goes high briefly, then low
EFM8 P1.5 PMIC_EN0 → MODULE_POWER_ON (L54) Goes high briefly, then low
CARRIER_POWER_ON (L62) Never asserted, stays at ~0.5 V. L62 connects to EFM8 P0.7 (PWR_GOOD) through R915 (0 Ω), confirmed in pstxnet.dat.
SYS_RESET_N (L60, carrier net SYS_RST_IN_N) Stays low
VDDIN_PWR_BAD_N (L55) Low (its carrier-side pull-up rail is not enabled in this state)
MODULE_SHDN_N (L52) → U102 input No activity
VDD_1V8 (enabled by CARRIER_POWER_ON) Off, so U102 is unpowered. The brief 3.3 V pulse on MOD_SHUTDOWN_N_3V3 is only the pull-up rail following VIN_PWR_ON.
EFM8 VDD / RSTb 3.3 V / 3.3 V (MCU is running, not held in reset)
The behavior matches the DevKit power button firmware v1.0 (FW 0.11, power.c): PoweringOn: VIN_PWR_ON=1 → wait 80 ms → PMIC_EN0 (MODULE_POWER_ON)=1 → wait up to 100 ms for PWR_GOOD (= CARRIER_POWER_ON) → not asserted → PoweringOff (PMIC_EN0=0, wait 10 ms, VIN_PWR_ON=0).
So the carrier side behaves as designed. The module’s power sequencer does not respond to MODULE_POWER_ON after the early power interruption. The failed state survives a short (≤5 s) power loss, clears after 10 s fully off, and occurs much less often without the RTC coin cell.
Additional observation (carrier firmware, secondary)
In PowerOff(), an ACOK-based auto power-on requires acok_deasserted. This flag is cleared on entry to PowerOff and is only set if ACOK is observed low while in PowerOff.
The EFM8SB10 can keep running from residual 3V3_AO charge during a short DC interruption. If DC (ACOK) returns before the EFM8 reaches PowerOff, the MCU never sees ACOK low, so it will not auto power-on even once the module issue is resolved. Please confirm whether this is expected.
Questions
  1. Does erratum RTC-1 / PCN 213441 also apply to systems without Secure Boot? This unit reproduces the issue with UEFI Secure Boot disabled and, apparently, no PKC fusing.
  2. The module board ID is 3834-0008-400 (699-13834-0008-400). In forum topic 381103, NVIDIA stated that “-400” indicates the pre-PCN213441 revision and “-401” is the updated revision. Please confirm that this unit is affected and eligible for replacement under PCN 213441, and describe the RMA/exchange process for DevKits.
  3. Is there any software or BCT workaround for R39.2.0? For example, is the MB1 PMIC configuration change discussed in forum thread 373570 (removing tegra264-mb1-bct-pmic-p3834-0008-vdd-fuse-on.dtsi) recommended or safe for production?
  4. We observe recovery after 10 s fully powered off. What is the minimum complete power-off time NVIDIA recommends to guarantee recovery after an interruption inside the 10 s window?
  5. With the RTC coin cell removed, the failure rate drops but is not zero. Besides the coin cell, what else can keep the power sequencer in this state across a short power loss (e.g. residual charge on module/carrier rails)? Is a carrier-side discharge circuit recommended?
  6. For custom carriers based on P4071, do you recommend changes to the button MCU firmware or hardware? Examples: forcing an EFM8 reset on input loss, latching ACOK deassertion in every state, or retrying power-on.
  • Oscilloscope captures of the failed attempt: VIN, VIN_PWR_ON, MODULE_POWER_ON (L54), CARRIER_POWER_ON (L62), SYS_RESET_N (L60)
  • UART debug log of the failed attempt (if any output)
  • /etc/nv_boot_control.conf, /etc/nv_tegra_release, dmesg
References
  • Jetson Thor Modules Hardware Errata DA-12711-001_v02, RTC-1
  • PCN 213441 (Jetson PCN Download Center)
  • Forum: “Clarification needed for bf_bl_rtc_rail_violation_detect_1b and PMIC EN12” (topic 373570)
  • Forum: “[Thor] RTC Time Issue” (topic 381060)
  • Forum: “T5000 SOM RTC errata PCN213441 applicability when RTC battery not used but secure boot enabled” (topic 381103)
hello 18074976899,
firstly, I don’t see your attachments, please double check the file upload process.
secondly, please give it a try to do NOT interrupt the power in the first 10s as the Errata mentioned.
Thanks for the reply. Sorry the attachments didn’t come through. I don’t have scope screenshots ready right now, so here are the measurements as text.
Measurements on the failed unit (power button pressed after the failed power-on):
• EFM8 (U79) VIN_PWR_ON (P1.3) and PMIC_EN0 → MODULE_POWER_ON (L54): both go high briefly, then drop.
• CARRIER_POWER_ON (L62): never asserted, stays at ~0.5 V. This line connects to EFM8 P0.7 (PWR_GOOD) through R915 (0 Ω).
• SYS_RESET_N (L60) stays low. VDD_1V8 (enabled by CARRIER_POWER_ON) stays off.
• EFM8 VDD and RSTb are both 3.3 V, so the MCU is running normally.
This matches the DevKit power button firmware (FW 0.11, power.c): VIN_PWR_ON=1 → wait 80 ms → MODULE_POWER_ON=1 → wait up to 100 ms for PWR_GOOD → not asserted → power off. In other words, the carrier behaves as designed, and the module never responds to MODULE_POWER_ON.
We understand the RTC-1 workaround is to avoid any power interruption during the first 10 s after power-on. Our product cannot guarantee that:
• The system is battery powered, so a battery swap or battery protection cut-off can remove power at any moment.
• Operators can hit the emergency stop or main power switch at any time, including right after power-on.
When an interruption happens inside that window, the unit stays dead until DC has been removed for at least 10 s. Even the power button cannot start it. So the workaround alone does not solve the problem for us.
Our key questions:
  1. Secure Boot is not enabled on this unit (UEFI SecureBoot=0, no PK/KEK/db enrolled, no PKC fuse burned), yet we get a hard boot failure, not just RTC time loss. PCN 213441 says customers who do not use Secure Boot need no action. Can you confirm that RTC-1 also applies to non-Secure-Boot systems with an RTC battery installed?
  2. The module EEPROM reads 699-13834-0008-400. PCN 213441 lists this as the old part number (new = 699-13834-0008-401). Is this unit eligible for exchange under PCN 213441?
    Unit details:
    • Module: 699-13834-0008-400 (rev G.5)
    • Carrier: P4071 DevKit carrier, 699-14071-0000-200 (rev D.1)
    • L4T: R39.2.0 (JetPack 7.2)
    • PD controller FW: b0.18 (FW1/FW2, read with nv_ccg_fw_update -i I2C2 -v)
    • Power: 19 V via J83 (Micro-Fit), J42 pins 5–6 jumpered for auto power-on, RTC coin cell installed
    Test and results:
    • Test: remove DC within 5 s after power-on, then re-apply it within 5 s.
    • Reproducibility: about 80%.
    • Recovery: remove DC for 10 s.
    • Without the RTC coin cell: the failure rate drops noticeably, but not to zero.
Our key questions:
    Unit details:
    Test and results:
hello 18074976899,
it is confirmed that the RTC power errata still applies even without secureboot use-case.
your reported revision-400 module is the earlier hardware revision associated with this issue. Exchange eligibility for your DevKit needs to be checked through the applicable support process.
The most useful comparison is an updated module on the same carrier, flashed with boot firmware generated for its actual module revision.
For further diagnosis, please provide waveform captures covering power removal, reconnection and a subsequent power-button attempt, including the actual module input supply and power-on handshake signals. For the failures without an RTC battery, please also capture ACOK and the EFM8 supply, and report whether manual power-on fails as well as automatic power-on.
Hi JerryChang,
Thanks for confirming that the RTC errata also applies without Secure Boot, and that the -400 module is the earlier hardware revision associated with this issue.
Regarding the comparison you suggested: we have already run it on two carriers.
  • On two carriers where a -400 module failed, we replaced the module with a -401 module and kept the same carrier.
  • We used the same test method as before: 19 V via J83, RTC coin cell installed, DC removed within 5 s after power-on, then re-applied within 5 s.
  • Each carrier went through more than 20 power cycles. All of them booted normally, and we did not see a single failure.
One point is still open. We have not yet verified that the boot firmware on these -401 units was generated for the -401 revision. We will check this (TNSPEC vs. module EEPROM, and reflash with the matching BSP if needed), repeat the test, and post the result here.
We will also capture the waveforms you requested on a failing -400 unit and post them in the same update:
  • Power removal → reconnection → power-button attempt, including the module input supply (VCC_SRC) and the power-on handshake signals (MODULE_POWER_ON, CARRIER_POWER_ON, SYS_RESET_N).
  • For the failures without the RTC battery: ACOK and the EFM8 supply (3V3_AO) as well, noting whether manual power-on fails in addition to automatic power-on.
Regarding exchange, could you point us to the applicable support process for DevKit units (e.g. a specific RMA portal or contact)? We plan to go through our purchasing channel and will reference this thread.
hello 18074976899,
you may refer to FAQ page for the RMA process.
We also have a T5000 module whose EEPROM reads 699-13834-0008-500 C.2. This part number is not listed in PCN 213441 (only -400 and -401). Could you confirm whether the -500 revision includes the RTC-1 fix?
hello 18074976899,
it’s the later hardware revision than the RTC-corrected assembly. it is expected to incorporate the RTC-1 correction.
BTW,
this topic has been solved, please start a new topic instead if you’re observing the same power-on failure on the -500 revision boards.
