From DRM layer: /sys/class/drm/card2-HDMI-A-1/status shows disconnected, and /sys/class/drm/card2-HDMI-A-1/edid is empty. dmesg | grep -i hdmi also shows no hotplug events.
From xrandr (X11 layer):
Running xrandr --verbose shows HDMI-0 disconnected as well.
So the issue occurs already at the DRM / kernel level before reaching X11.
I connected both a DP monitor and an HDMI monitor. When I run the command xrandr --monitors, only the DP monitor is shown, and the HDMI monitor does not appear.
This record was captured while both the DP and HDMI monitors were connected. Even though the HDMI monitor was plugged in, it still appeared as ‘disconnected,’ and only the DP monitor could be detected using the command xrandr --listmonitors.
Thanks ~0121
