Hi nvida
I connected two AGX Thor devkit motherboards together and both were using Jetpack 7.2 to run the iperf3 TCP test. Still unable to reach 25G.
Could you please tell me if the data obtained using Jetpack 7.2 is less than 25G? Also, do the results we obtained comply with the specifications provided by NVIDIA? Could we conduct the test using iperf3? Are there any other methods for measuring speed besides this one?
The following are the data we measured using two devkits:
[SUM] 0.00-10.00 sec 2.84 GBytes 2.44 Gbits/sec 8 sender
[SUM] 0.00-10.00 sec 2.54 GBytes 2.18 Gbits/sec 10 sender
[SUM] 0.00-10.00 sec 2.43 GBytes 2.09 Gbits/sec 10 sender
[SUM] 0.00-10.00 sec 2.54 GBytes 2.18 Gbits/sec 9 sender
[SUM] 0.00-10.00 sec 2.53 GBytes 2.17 Gbits/sec 14 sender
[SUM] 0.00-10.00 sec 2.69 GBytes 2.31 Gbits/sec 16 sender
[SUM] 0.00-10.00 sec 2.47 GBytes 2.12 Gbits/sec 8 sender
[SUM] 0.00-10.00 sec 2.69 GBytes 2.31 Gbits/sec 21 sender
[SUM] 0.00-10.00 sec 2.38 GBytes 2.04 Gbits/sec 8 sender
[SUM] 0.00-10.00 sec 2.46 GBytes 2.12 Gbits/sec 9 sender
[SUM] 0.00-10.01 sec 2.52 GBytes 2.16 Gbits/sec 9 sender
[SUM] 0.00-10.00 sec 2.46 GBytes 2.11 Gbits/sec 6 sender
[SUM] 0.00-10.00 sec 2.50 GBytes 2.14 Gbits/sec 7 sender
[SUM] 0.00-10.01 sec 2.26 GBytes 1.94 Gbits/sec 2 sender
[SUM] 0.00-10.00 sec 2.39 GBytes 2.05 Gbits/sec 4 sender
[SUM] 0.00-10.01 sec 2.60 GBytes 2.23 Gbits/sec 7 sender
[SUM] 0.00-10.00 sec 2.54 GBytes 2.18 Gbits/sec 5 sender
[SUM] 0.00-10.00 sec 2.53 GBytes 2.18 Gbits/sec 5 sender
[SUM] 0.00-10.00 sec 2.45 GBytes 2.10 Gbits/sec 7 sender
[SUM] 0.00-10.01 sec 2.40 GBytes 2.06 Gbits/sec 7 sender
[SUM] 0.00-10.01 sec 2.50 GBytes 2.15 Gbits/sec 6 sender
[SUM] 0.00-10.01 sec 2.55 GBytes 2.19 Gbits/sec 8 sender
[SUM] 0.00-10.01 sec 2.46 GBytes 2.11 Gbits/sec 5 sender
[SUM] 0.00-10.00 sec 2.17 GBytes 1.87 Gbits/sec 3 sender
[SUM] 0.00-10.01 sec 2.44 GBytes 2.10 Gbits/sec 3 sender
[SUM] 0.00-10.01 sec 2.54 GBytes 2.18 Gbits/sec 3 sender
[SUM] 0.00-10.00 sec 2.31 GBytes 1.98 Gbits/sec 6 sender
[SUM] 0.00-10.00 sec 2.32 GBytes 1.99 Gbits/sec 6 sender
[SUM] 0.00-10.00 sec 2.20 GBytes 1.89 Gbits/sec 4 sender
[SUM] 0.00-10.00 sec 2.51 GBytes 2.16 Gbits/sec 3 sender
[SUM] 0.00-10.00 sec 2.44 GBytes 2.10 Gbits/sec 10 sender
