The length of C2M does not exceed 46mm. However, when I checked the agx thor T5000 reference design, the longest trace for RX was 73mm, and for TX it was 68mm. Both the length specifications did not meet the requirements of the design guide.
As described in Note2 for Table 7-25 of the Design Guide, the 46mm C2M trace length is based on EM370z. If you use a different PCB material or stackup, please ensure that your configuration meets the specified loss budget.
I understand what you mean. As long as my dB loss is less than 4.15, then the trace length can exceed 46mm?
According to your statement, was the dB loss of the agx thor T5000 reference design not exceeding 4.15?
Does this mean that the agx thor T5000 reference design uses better materials than the EM370z (FR4)?
Yes, the 46mm and 4.15dB in the Design Guide are based on EM370z material. If you use a lower-loss material, longer traces are acceptable as long as the channel insertion loss remains within the loss budget.
We are unable to share internal details about the PCB material used in the reference design.
