AGX THOR T5000 Mgbe QSFP28 AC caps position and voltage
Hi Nvidia eigneer
1.I have used AGX Thor T5000 to create a QSFP28 interface. Our block diagram is as follows
Could you please tell me if the placement of my AC caps is correct? Which ones need to be deleted? Which areas need to be expanded?
2.I have measured the voltage at the QSFP28 location. The voltage range is approximately 2.7V. Is this correct? If it’s incorrect, what should be the correct voltage range?
Please clarify the exact location you measured.
QSFP28 connector TXP&TXN
Below is my suggestion.
Please double confirm with the Re-driver support team if it requires AC cap as well ?
Does QSFP28 Connector mean a QSFP28 cage ?
QSFP28 Connector like this
1.I have confirmed with the AC cap and redriver manufacturers, and their suggestion is as shown in the diagram I provided.
So, is it your understanding that an AC cap needs to be added to both the TX/RX redriver’s left and right sides? Because I noticed that on the AGX Thor baseboard, no AC CAP was added near the QSFP28 connector. May I ask if there is any basis for you to place the AC cap in this way? Could you provide some reference documents?
2.You swapped the TX and RX after redriver. However, when I actually laid out the circuit for verification, it was fine according to my wiring method. Could you please explain the basis for this modification? Could you provide us with some references?
The Jedha reference schematic includes the note “Fiber: AC cap in module, SFF-8679”. This is why no external AC coupling capacitors are placed near the QSFP28 connector for the optical module connection.
Thank you,
Hi
What exactly is Jedha that you mentioned?
Reference SFF-8679,The AC coupling is inside the module and not
required on the host board.
1.So that means there is no need to add an AC cap near the QSFP28 connector?
  1. Yes, your understanding is correct. Per SFF-8679, the AC coupling capacitors are inside the module. Therefore, AC caps are not needed on the host board side near the QSFP28 connector.
  2. Your original connection direction is correct. No need to swap TX/RX.
Thank you,
