AGX Thor T5000 QSFP28 25G TX/RX eye digram Test
Hi Nvidia engineer
According to Chapter 2.4 of the Jetson_Thor_Series_VerificationGuide_DA-12308-001_v1.2 document, there is a TX eye diagram testing method for MGBE. It seems that no additional programs or accessories need to be installed. We can directly follow the SOP to submit the package and then conduct the test, right?
The 2.4 chapter of the Jetson_Thor_Series_VerificationGuide_DA-12308-001_v1.2 only contains the test section for the TX. May I ask about the MGBE RX part? How should we proceed with the verification?
For TX: yes, you can follow the Chapter 2.4. No additional programs or accessories are not required.
For RX: Chapter 2.4 also provides PRBS checker modes Use option 6 or 7.
Thank you,
Hi hiwata
I’m a bit confused and not sure if it’s correct.
*FOR TX:*Do I only need to input 4 or 5 from the command? Then just connect the probe of the oscilloscope to the TX, right?
*FOR RX:*I’m connecting two hosts together. Should I enter command 4 or 5 on one of them, and then enter 6 or 7 on the other one?Is this method a way to test the eye diagram? If I want to test RX using an oscilloscope, how should I do it?
Can someone help me with this?
For TX: Yes, enter echo 4 (PRBS9) or 5 (PRBS31) to generate a continuous PRBS pattern on the TX lanes. Then connect an oscilloscope to measure the TX eye diagram,
The probing method depends on the customer’s carrier board design:
  • If suitable high-speed probing points are provided on the MGBE TX lanes, the signal can be measured directly using an appropriate high-bandwidth probe.
  • If no suitable probing points are available, a QSFP28 host compliance test fixture or breakout fixture should be used to connect the TX lanes to the oscilloscope.
For RX: Thor supports two methods:
  1. Use command 6 (PRBS9) or 7 (PRBS31) to check the received PRBS error count. The PRBS signal can be generated by another Thor or an external BERT.
  2. Use the EOM function to check the internal RX eye opening and margin.
The Thor RX path includes internal equalization and a clock and data recovery, which process the incoming signal before recovering data. An oscilloscope connected at the RX input only shows the waveform before this internal processing. It does not indicate whether Thor can correctly recover the data after equalization. Therefore, use the PRBS checker or EOM to evaluate the Thor RX side.
Thank you,
