I have an problem in Xavier operation,
I have noticed that if Pin-12 (I2S2_CLK) of the Xavier 40-pin header is pulled down during the Xavier power-up sequence, it affects the SPI 1 operation.
We have connected our system to the Xavier 40-pin header. However, if our system is down during the Xavier power-up, the SPI stops working. On the other hand, if our system is on during the power-up, the SPI_1 works correctly.
Can you please provide me with the Xavier GPIO hardware default configuration after power is on? I suspect that during power-up, the Xavier is trying to set this pin to “HI,” and because our system is off, we might be causing the XAVIER current limit to start working.
Hi Kevin,
Yes, I am using Jetson AGX Xavier Developer Kit with customs board that connect to the Xavier 40pin header.
The difference between these two situations is as you described:
My system down => Pin-12 (I2S2_CLK) pulled down
My system on => Pin-12 (I2S2_CLK) pulled up,
I have check the SPI1 related pins the CS0 isn’t functioning as it should he don’t reach 1.8V only 1V. “It could be configured from pinmux table.” - Please elaborate, the default GPIO configuration isn’t configured by hardware?
I am talking on the first second that i power on the Xavier Developer Kit, and not after the system in booting on.
The carrier board should not power on before module so that module won’t be affected by carrier rails. So any pin of module should not be affected by carrier power rails before module on. You should not pull up the pin during boot.
