I was having trouble reflashing the AGX Xavier, so I connected to the serial console to see what might be wrong.
I am getting a strange error – what is happening ?
(skip to the bottom to see these set of messages in context)
[0300.932] E> OCR failed, error = f0f0a06
[0300.933] E> Failed to open sdmmc-3, err = f0f0a06
[0300.933] E> Failed to initialize boot device
[0300.933] E> Top caller module: SDMMC, error module: SDMMC, reason: 0x06, aux_info: 0x0a
[0300.934] I> TBoot-CPU Recovery hang
^^ What is wrong here ??
Full log –
Here is the full output:
[0008.929] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0008.937] I> MB1 (prd-version: 2.6.0.0-t194-41334769-cab45716)
[0008.943] I> Boot-mode: Platform RCM
[0008.946] I> Platform: Silicon
[0008.949] I> Chip revision : A02P
[0008.952] I> Bootrom patch version : 15 (correctly patched)
[0008.957] I> ATE fuse revision : 0x200
[0008.960] I> Ram repair fuse : 0x0
[0008.963] I> Ram Code : 0x2
[0008.966] I> rst_source: 0x0, rst_level: 0x0
[0008.971] I> USB configuration success
[0011.091] I> mb2 image downloaded
[0011.114] I> Recovery boot mode 0
[0011.119] I> UPHY full init done
[0011.126] I> MB1 done
[0011.131] I> Welcome to MB2(TBoot-BPMP) Applet (version: default.t194-mobile-dba32e6d)
[0011.138] I> DMA Heap @ [0x40020000 - 0x40065800]
[0011.143] I> Default Heap @ [0xd486400 - 0xd48a400]
[0011.147] W> Profiler not initialized
[0012.151] E> OCR failed, error = f0f0a06
[0012.155] I> SDMMC is not present.
[0012.159] E> SPI_FLASH: Invalid value device id: 7.
[0012.164] I> QSPI Flash is not present.
[0012.170] E> CLK_RST: instance 6 not found in module 44.
[0012.175] E> MPhy CAR configuration failed error = 1747992077
[0012.181] E> UFS initialization failed
[0012.184] I> UFS is not present
[0012.187] W> Profiler not initialized
[0012.190] I> Entering 3p server
[0012.194] I> USB configuration success
[0012.261] I> Populate chip info
[0012.279] I> Populate eeprom info
[0012.283] I> Populate eeprom info for module cvm
[0012.288] > DEVICE_PROD: device prod is not initialized.
[0012.358] I> Rebooting : reboot-recovery
[0012.363] I> Reset to recovery mode
[0292.381] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0292.389] I> MB1 (prd-version: 2.6.0.0-t194-41334769-cab45716)
[0292.394] I> Boot-mode: RCM
[0292.397] I> Platform: Silicon
[0292.400] I> Chip revision : A02P
[0292.403] I> Bootrom patch version : 15 (correctly patched)
[0292.408] I> ATE fuse revision : 0x200
[0292.412] I> Ram repair fuse : 0x0
[0292.415] I> Ram Code : 0x2
[0292.417] I> rst_source: 0xb, rst_level: 0x1
[0292.422] I> USB configuration success
[0294.431] I> bct_bootrom image downloaded
[0294.441] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0294.448] I> Temperature = 35500
[0294.452] W> Skipping boost for clk: BPMP_CPU_NIC
[0294.456] W> Skipping boost for clk: BPMP_APB
[0294.460] W> Skipping boost for clk: AXI_CBB
[0294.464] W> Skipping boost for clk: AON_CPU_NIC
[0294.468] W> Skipping boost for clk: CAN1
[0294.472] W> Skipping boost for clk: CAN2
[0294.476] I> Boot-device: SDMMC (instance: 3)
[0294.480] I> bct_mb1 image downloaded
[0294.493] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0294.501] W> Thermal config not found in BCT
[0294.509] W> MEMIO rail config not found in BCT
[0294.526] I> bct_mem image downloaded
[0297.573] I> blob image downloaded
[0297.601] I> Recovery boot mode 0
[0297.645] W> Platform config not found in BCT
[0297.678] I> MB1 done
����main enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
[0297.689] I> Welcome to MB2(TBoot-BPMP) Recovery (version: default.t194-mobile-405defbc)
[0297.689] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0297.690] I> Default Heap @ [0xd486400 - 0xd48a400]
[0297.692] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0297.697] W> device prod register failed
[0297.713] I> Relocating BR-BCT
[0297.714] > DEVICE_PROD: device prod is not initialized.
[0297.740] E> I2C: slave not found in slaves.
[0297.741] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0297.742] E> I2C_DEV: Failed to send register address 0x00000000.
[0297.743] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0297.743] E> eeprom: Failed to read I2C slave device
[0297.747] I> Failed to read CVB eeprom data @ AE
[0297.751] I> Retrying CVB eeprom read @ AC ...
[0297.787] I> Relocating OP-TEE dtb from: 0x6bfffc10 to 0x70050000, size: 1008
[0297.788] I> [0] START: 0x80000000, SIZE: 0x47af0000
[0297.788] I> [1] START: 0xca000000, SIZE: 0x800000
[0297.789] I> dram_block larger than 80000000
[0297.789] I> [2] START: 0x100000000, SIZE: 0x780000000
[0297.794] I> Setting NS memory ranges to OP-TEE dtb finished.
[0297.797] I> found decompressor handler: lz4
[0298.367] I> EKB detected (length: 0x410) @ VA:0x526fa200
[0298.369] I> Setting EKB blob info to OPTEE dtb finished.
��NOTICE: BL31: v2.6(release):5e1f8b33d
NOTICE: BL31: Built : 01:45:47, Aug 28 2024
I/TC: Physical secure memory base 0xcb040000 size 0xf00000
bpmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
��I/TC:
��clk_early initialized
mail_early initialized
fuse initialized
hwwdt initialized
t194_ec_get_ec_list: found 45 ecs
ec initialized
vmon_setup_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
��I/��avfs_clk_platform initialized
��TC: Non-sec��soctherm initialized
��u��aotag initialized
��re ��powergate initialized
��external DT found
��dvs initialized
pm initialized
suspend initialized
pg_late initialized
pg_mrq_init initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
/uphy is not enabled status = disabled
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
clk_dt_late initialized
noc_late initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
avfs_clk_mach_post initialized
��I��avfs_clk_platform_post initialized
��/TC��cvc_late initialized
regulator_post initialized
��: OP��rm initialized
console_late initialized
clk_dt_post initialized
��-TE��mc_reg initialized
pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] ��E version: 3.22 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Wed Aug 28 08:55:09 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
[0299.293] I> Welcome to TBoot-CPU Recovery
[0299.294] I> Heap: [0xa0f00000 ... 0xa9f00000
[0299.294] I> gpio framework initialized
[0299.311] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0299.323] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0299.323] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0299.332] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0299.339] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0299.340] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0299.340] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0299.347] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0299.353] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0299.355] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0299.366] I> fixed regulator driver initialized
[0299.542] I> CPU: Nvidia Carmel
[0299.542] I> CPU: MIDR: 0x4e0f0040, MPIDR: 0x80000000
[0299.543] I> Platform: Silicon
[0299.543] I> chip revision : A02P
[0299.543] I> Boot_device: SDMMC_BOOT instance: 3
[0299.544] I> sdmmc-3 params source = boot args
