I ran into a problem when deploying part of the Autoware code to AGX Xaiver (Jetpack 4.2.3)
I tested the same code on my 980M GPU (CUDA 10) and it works fine.
#include <cuda.h>
#include <cuda_runtime.h>
#define CUDAH forceinline host device
#define BLOCK_SIZE_X 1024
#define BLOCK_SIZE_X2 512
#define BLOCK_SIZE_X3 256
#define BLOCK_X 16
#define BLOCK_Y 16
#define BLOCK_Z 4
#define SHARED_MEM_SIZE 3072
#endif
Can I ask would the above BLOCK_SIZE and BLOCK_X/Y/Z settings be ok for AGX Xavier’s tegra GPU?
Bruce
Thank you
You can get the CUDA detailed information with our deviceQuery example:
(located at /usr/local/cuda-10.2/samples/1_Utilities/deviceQuery)
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "Xavier"
CUDA Driver Version / Runtime Version 10.2 / 10.2
CUDA Capability Major/Minor version number: 7.2
Total amount of global memory: 15817 MBytes (16584974336 bytes )
( 8) Multiprocessors, ( 64) CUDA Cores/MP: 512 CUDA Cores
GPU Max Clock rate: 1377 MHz (1.38 GHz)
Memory Clock rate: 1377 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 524288 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536) , 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: Yes
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 0 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simu ltaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.2, CUDA Runtime Vers ion = 10.2, NumDevs = 1
Result = PASS
