I am building my own custom dtb for my own custom linux.
For some reason, my AGX wont fully boot, it panics at PCIe.
I attached my dtb and part of the serial dmesg output below.
rnc.dtb (352.2 KB)
What I notice in my dtb, all phandles are different.
[ 6.663728] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 6.663867] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 6.664130] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[ 6.664314] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[ 6.664671] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 6.665103] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 6.679477] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 6.679796] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.681788] pcieport 0003:00:00.0: Adding to iommu group 7
[ 6.683584] pcieport 0003:00:00.0: PME: Signaling with IRQ 28
[ 6.685064] pcieport 0003:00:00.0: AER: enabled with IRQ 28
[ 6.686559] pci_bus 0003:01: busn_res: [bus 01-ff] is released
[ 6.687860] pci 0003:00:00.0: Removing from iommu group 7
[ 6.688200] pci_bus 0003:00: busn_res: [bus 00-ff] is released
[ 6.691326] tegra194-pcie 141a0000.pcie: Adding to iommu group 8
[ 6.719622] host1x 13e10000.host1x: Adding to iommu group 9
[ 6.735379] Unable to handle kernel paging request at virtual address 0000000000008080
[ 6.735743] Mem abort info:
[ 6.735956] ESR = 0x96000044
[ 6.736082] EC = 0x25: DABT (current EL), IL = 32 bits
[ 6.736266] SET = 0, FnV = 0
[ 6.736376] EA = 0, S1PTW = 0
[ 6.736487] Data abort info:
[ 6.736596] ISV = 0, ISS = 0x00000044
[ 6.736786] CM = 0, WnR = 1
[ 6.737028] [0000000000008080] user address but active_mm is swapper
[ 6.737268] Internal error: Oops: 96000044 [#1] PREEMPT SMP
[ 6.737442] Modules linked in:
[ 6.740404] CPU: 0 PID: 96 Comm: kworker/0:2 Not tainted 5.10.104 #7
[ 6.747006] Hardware name: Unknown Jetson-AGX/Jetson-AGX, BIOS 1.0-d7fb19b 08/10/2022
[ 6.754942] Workqueue: events deferred_probe_work_func
[ 6.759969] pstate: 60800009 (nZCv daif -PAN +UAO -TCO BTYPE=--)
[ 6.765851] pc : host1x_writel+0x44/0x80
[ 6.769589] lr : host1x_writel+0x28/0x80
[ 6.773265] sp : ffff8000112e3a40
[ 6.776763] x29: ffff8000112e3a40 x28: ffff5e1b83d08108
[ 6.781942] x27: 0000000000000000 x26: ffff5e1b83d08080
[ 6.787433] x25: ffffc486b82438b0 x24: ffff5e1b80f66410
[ 6.792964] x23: 0000000000000037 x22: 0000000000008080
[ 6.798279] x21: ffff5e1b80f66400 x20: 0000000000008080
[ 6.803372] x19: 0000000000000000 x18: ffffffffffffffff
[ 6.809041] x17: ffffc486b73230ec x16: 00000000ed6f6368
[ 6.814122] x15: ffff5e1b83d19a1c x14: ffff5e1b83d19339
[ 6.819632] x13: 0000000000000008 x12: 0000000000000008
[ 6.825147] x11: 000000000000000b x10: 0101010101010101
[ 6.830577] x9 : fffffffffffffff9 x8 : 7f7f7f7f7f7f7f7f
[ 6.836381] x7 : fefefeff646c606d x6 : 00170401e9e1ace3
[ 6.841608] x5 : 632c616901041700 x4 : 8080808000000000
[ 6.847040] x3 : ffff5e1b81a55000 x2 : ffffc486b6dbd4a0
[ 6.852638] x1 : ffffc486b89654b8 x0 : 0000000000000000
[ 6.857953] Call trace:
[ 6.860418] host1x_writel+0x44/0x80
[ 6.863913] t194_syncpt_reset+0x40/0x4c
[ 6.867615] nvhost_syncpt_reset+0x50/0x7c
[ 6.871614] power_on_host+0x80/0xac
[ 6.875112] nvhost_probe+0x874/0xd04
[ 6.879050] platform_drv_probe+0x5c/0xbc
[ 6.883083] really_probe+0xf8/0x4a8
[ 6.886593] driver_probe_device+0x60/0xbc
[ 6.890598] __device_attach_driver+0xb0/0x100
[ 6.894804] bus_for_each_drv+0x88/0xd8
[ 6.898599] __device_attach+0xcc/0x178
[ 6.902589] device_initial_probe+0x28/0x38
[ 6.906603] bus_probe_device+0xac/0xc0
[ 6.910570] deferred_probe_work_func+0x90/0xc4
[ 6.915107] process_one_work+0x1fc/0x4c0
[ 6.919113] worker_thread+0x210/0x450
[ 6.922650] kthread+0x15c/0x160
[ 6.925877] ret_from_fork+0x10/0x1c
[ 6.929474] Code: f9400436 8b3442d6 371800e0 d50332bf (b90002d3)
[ 6.936047] ---[ end trace 45b143cda8d5c300 ]---
[ 6.940304] Kernel panic - not syncing: Oops: Fatal exception
[ 6.946076] SMP: stopping secondary CPUs
[ 6.950234] Kernel Offset: 0x4486a6c10000 from 0xffff800010000000
[ 6.955973] PHYS_OFFSET: 0xffffa1e580000000
[ 6.960165] CPU features: 0x8240002,03802a30
[ 6.964790] Memory Limit: none
[ 6.967692] ---[ end Kernel panic - not syncing: Oops: Fatal exception ]---
