Hello @linuxdev and @WayneWWW
Thanks a lot. We flashed the JetPack-5.1 with SDK Manager and got the same problem in it.
Then, we flashed JetPack-4.6.3 to reproduce this issue. However, the ethernet connecting has not any dropped packages.
Here are the results of the commands in JetPack-5.1:
nvidia@ubuntu:~$ ip -s addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
RX: bytes packets errors dropped overrun mcast
12868 172 0 0 0 0
TX: bytes packets errors dropped carrier collsns
12868 172 0 0 0 0
2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 56:ab:8b:cf:3c:70 brd ff:ff:ff:ff:ff:ff
0 0 0 0 0 0
0 0 0 0 0 0
3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 48:b0:2d:3d:b1:3d brd ff:ff:ff:ff:ff:ff
inet 192.168.2.135/24 brd 192.168.2.255 scope global dynamic noprefixroute eth0
valid_lft 3187sec preferred_lft 3187sec
inet6 fe80::5f64:9cc3:5593:9e42/64 scope link noprefixroute
442813 3542 0 828 0 0
24804 241 0 0 0 0
4: l4tbr0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 9e:f6:b7:a2:43:7d brd ff:ff:ff:ff:ff:ff
0 0 0 0 0 0
0 0 0 0 0 0
5: rndis0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast master l4tbr0 state DOWN group default qlen 1000
0 0 0 0 0 0
0 0 0 0 0 0
6: usb0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast master l4tbr0 state DOWN group default qlen 1000
link/ether 9e:f6:b7:a2:43:7f brd ff:ff:ff:ff:ff:ff
0 0 0 0 0 0
0 0 0 0 0 0
nvidia@ubuntu:~$ cat /proc/interrupts
CPU0 CPU1 CPU2 CPU3
9: 0 0 0 0 GICv2 25 Level vgic
11: 0 0 0 0 GICv2 30 Level kvm guest ptimer
12: 0 0 0 0 GICv2 27 Level kvm guest vtimer
13: 96514 71740 70669 66119 GICv2 26 Level arch_timer
14: 0 0 0 0 GICv2 262 Level 2300000.cbb-noc
15: 0 0 0 0 GICv2 263 Level 2300000.cbb-noc
16: 0 0 0 0 GICv2 292 Level c600000.aon-noc
17: 0 0 0 0 GICv2 204 Level c600000.aon-noc
18: 0 0 0 0 GICv2 294 Level d600000.bpmp-noc
19: 0 0 0 0 GICv2 206 Level d600000.bpmp-noc
20: 0 0 0 0 GICv2 291 Level be00000.rce-noc
21: 0 0 0 0 GICv2 207 Level be00000.rce-noc
22: 0 0 0 0 GICv2 293 Level b600000.sce-noc
23: 0 0 0 0 GICv2 205 Level b600000.sce-noc
24: 0 0 0 0 GICv2 104 Level tegra-pcie-intr
26: 1 0 0 0 GICv2 77 Level tegra-pcie-intr, PCIe PME, aerdrv
28: 0 0 0 0 GICv2 81 Level tegra-pcie-intr
30: 0 0 0 0 GICv2 85 Level tegra-pcie-intr
32: 1 0 0 0 GICv2 226 Level eth0.common_irq
33: 52 0 0 0 GICv2 218 Level eth0.tx0
34: 3363 0 0 0 GICv2 222 Level eth0.rx0
35: 5 0 0 0 GICv2 144 Level 3100000.serial
38: 0 0 0 0 GICv2 152 Level 3c00000.tegra-hsp
39: 10490 0 0 0 GICv2 97 Level mmc0
40: 0 0 0 0 GICv2 94 Level mmc1
41: 0 0 0 0 GICv2 68 Level 3210000.spi
42: 0 0 0 0 GICv2 69 Level c260000.spi
43: 35 0 0 0 GICv2 57 Level 3160000.i2c
44: 268 0 0 0 GICv2 58 Level c240000.i2c
45: 0 0 0 0 GICv2 59 Level 3180000.i2c
46: 0 0 0 0 GICv2 60 Level 3190000.i2c
47: 0 0 0 0 GICv2 62 Level 31b0000.i2c
48: 16 0 0 0 GICv2 63 Level 31c0000.i2c
49: 720 0 0 0 GICv2 64 Level c250000.i2c
50: 0 0 0 0 GICv2 65 Level 31e0000.i2c
53: 9653 0 0 0 GICv2 193 Level snd_hda_tegra
54: 0 0 0 0 GICv2 51 Level bc00000.rtcpu
55: 133 0 0 0 GICv2 242 Level d230000.actmon
56: 37952 0 0 0 GICv2 297 Level host_syncpt
57: 1 0 0 0 GICv2 295 Level host_status
58: 0 0 0 0 GICv2 238 Level vic
59: 0 0 0 0 GICv2 268 Level nvdla0
60: 0 0 0 0 GICv2 269 Level nvdla1
61: 29762 0 0 0 GICv2 185 Level 15200000.display
62: 0 0 0 0 GICv2 186 Level 15210000.display
63: 0 0 0 0 GICv2 187 Level 15220000.display
64: 0 0 0 0 GICv2 189 Level 15210000.display
65: 0 0 0 0 GICv2 190 Level 15220000.display
66: 11 0 0 0 GICv2 275 Level 15200000.display
67: 0 0 0 0 GICv2 191 Level tegra_dp
68: 0 0 0 0 GICv2 192 Level tegra_dp
71: 0 0 0 0 GICv2 194 Level cec_irq
74: 0 0 0 0 GICv2 266 Level pva-isr
75: 0 0 0 0 GICv2 267 Level pva-isr
76: 0 0 0 0 GICv2 416 Level arm-pmu
77: 0 0 0 0 GICv2 417 Level arm-pmu
78: 0 0 0 0 GICv2 418 Level arm-pmu
79: 0 0 0 0 GICv2 419 Level arm-pmu
80: 0 0 0 0 GICv2 420 Level arm-pmu
81: 0 0 0 0 GICv2 421 Level arm-pmu
82: 0 0 0 0 GICv2 422 Level arm-pmu
83: 0 0 0 0 GICv2 423 Level arm-pmu
85: 0 0 0 0 GICv2 169 Level tegra-oc-event
86: 0 0 0 0 GICv2 255 Level mc_status
88: 0 0 0 0 GICv2 272 Level arm-smmu global fault, arm-smmu-context-fault, arm-smmu-context-fault
89: 0 0 0 0 GICv2 202 Level arm-smmu global fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault
90: 0 0 0 0 GICv2 264 Level arm-smmu global fault, arm-smmu-context-fault
93: 9195 0 0 0 GICv2 165 Level c150000.tegra-hsp
97: 236773 0 0 0 GICv2 208 Level 3c00000.tegra-hsp
105: 98 0 0 0 GICv2 214 Level b950000.tegra-hsp
109: 0 0 0 0 GICv2 315 Level 3ad0000.se_elp
111: 0 0 0 0 GICv2 108 Level gpcdma.0
112: 0 0 0 0 GICv2 109 Level gpcdma.1
113: 0 0 0 0 GICv2 110 Level gpcdma.2
114: 0 0 0 0 GICv2 111 Level gpcdma.3
115: 0 0 0 0 GICv2 112 Level gpcdma.4
116: 0 0 0 0 GICv2 113 Level gpcdma.5
117: 0 0 0 0 GICv2 114 Level gpcdma.6
118: 0 0 0 0 GICv2 115 Level gpcdma.7
119: 0 0 0 0 GICv2 116 Level gpcdma.8
120: 0 0 0 0 GICv2 117 Level gpcdma.9
121: 8 0 0 0 GICv2 118 Level gpcdma.10
122: 0 0 0 0 GICv2 119 Level gpcdma.11
123: 0 0 0 0 GICv2 120 Level gpcdma.12
124: 0 0 0 0 GICv2 121 Level gpcdma.13
125: 0 0 0 0 GICv2 122 Level gpcdma.14
126: 0 0 0 0 GICv2 123 Level gpcdma.15
127: 0 0 0 0 GICv2 124 Level gpcdma.16
128: 0 0 0 0 GICv2 125 Level gpcdma.17
129: 0 0 0 0 GICv2 126 Level gpcdma.18
130: 0 0 0 0 GICv2 127 Level gpcdma.19
131: 1 0 0 0 GICv2 128 Level gpcdma.20
132: 0 0 0 0 GICv2 129 Level gpcdma.21
195: 0 0 0 0 GICv2 45 Level c1e0000.gte
196: 15 0 0 0 GICv2 39 Level 30c0000.watchdog
200: 0 0 0 0 GICv2 198 Level 3550000.xudc
201: 3573 0 0 0 GICv2 195 Level xhci-hcd:usb1
202: 8 0 0 0 GICv2 196 Level 3610000.xhci
203: 5473 0 0 0 GICv2 102 Level gk20a_stall
204: 0 0 0 0 GICv2 103 Level gk20a_nonstall
220: 3 0 0 0 c360000.pmc 82 Level 3610000.xhci
221: 0 0 0 0 c360000.pmc 73 Level tegra_rtc
222: 0 0 0 0 GICv2 241 Level max77620-top
223: 0 0 0 0 max77620-top 3 Edge max77620-gpio
224: 0 0 0 0 max77620-top 4 Edge max77686-rtc
225: 0 0 0 0 max77686-rtc 1 Edge rtc-alarm1
227: 0 0 0 0 max77620-top 8 Edge max77620-thermal
228: 0 0 0 0 max77620-top 9 Edge max77620-thermal
230: 53 0 0 0 agic-controller 73 Edge
231: 27 0 0 0 agic-controller 64 Edge
233: 26 0 0 0 agic-controller 94 Edge
243: 168 0 0 0 agic-controller 32 Level dma1chan0
244: 106 0 0 0 agic-controller 33 Level
275: 0 0 0 0 gpio 43 Edge 3400000.sdhci cd
276: 7 0 0 0 gpio 77 Edge 15200000.display
277: 0 0 0 0 c360000.pmc 83 Edge sw-wake
278: 0 0 0 0 gpio 36 Edge force-recovery
279: 0 0 0 0 gpio 27 Edge power-key
280: 0 0 0 0 PCI-MSI 134742016 Edge ahci[0001:01:00.0]
281: 0 0 0 0 gpio 149 Edge bluetooth hostwake
283: 0 0 0 0 gpio 46 Level tmp451
284: 1 0 0 0 gpio 119 Edge rt5659
285: 15 0 0 0 gpio 10 Level 1-0008
286: 1 0 0 0 gpio 40 Level 2490000.ethernet:00
IPI0: 27060 79857 20131 20011 Rescheduling interrupts
IPI1: 26082 70918 85125 87804 Function call interrupts
IPI2: 0 0 0 0 CPU stop interrupts
IPI3: 0 0 0 0 CPU stop (for crash dump) interrupts
IPI4: 0 0 0 0 Timer broadcast interrupts
IPI5: 28906 5384 4748 4972 IRQ work interrupts
IPI6: 0 0 0 0 CPU wake-up interrupts
Err: 0
nvidia@ubuntu:~$ hwinfo --network
12: None 00.0: 10701 Ethernet
[Created at net.126]
Unique ID: usDW.ndpeucax6V1
Parent ID: QHf_.TfPFe67fIBB
SysFS ID: /class/net/eth0
SysFS Device Link: /devices/platform/2490000.ethernet
Hardware Class: network interface
Model: "Ethernet network interface"
Driver: "nvethernet"
Device File: eth0
HW Address: 48:b0:2d:3d:b1:3d
Permanent HW Address: 48:b0:2d:3d:b1:3d
Link detected: yes
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #3 (Ethernet controller)
13: None 00.0: 10701 Ethernet
Unique ID: wudW.ndpeucax6V1
SysFS ID: /class/net/rndis0
SysFS Device Link: /devices/platform/3550000.xudc/gadget
Driver: "g_ether"
Device File: rndis0
HW Address: 9e:f6:b7:a2:43:7d
Link detected: no
14: None 00.0: 10700 Loopback
Unique ID: ZsBS.GQNx7L4uPNA
SysFS ID: /class/net/lo
Model: "Loopback network interface"
Device File: lo
Link detected: yes
15: None 00.0: 10701 Ethernet
Unique ID: Hl71.ndpeucax6V1
SysFS ID: /class/net/l4tbr0
Driver: "bridge"
Device File: l4tbr0
Link detected: no
16: None 00.0: 10701 Ethernet
Unique ID: WVs7.ndpeucax6V1
SysFS ID: /class/net/dummy0
Driver: "dummy"
Device File: dummy0
HW Address: 56:ab:8b:cf:3c:70
17: None 00.0: 1070c USB-Link
Unique ID: IhCv.SyfSGg7YspF
SysFS ID: /class/net/usb0
Model: "USB-Link network interface"
Driver: "g_ether"
Device File: usb0
HW Address: 9e:f6:b7:a2:43:7f
Link detected: no
nvidia@ubuntu:~$ sudo ethtool eth0
[sudo] password for nvidia:
Settings for eth0:
Supported ports: [ TP MII FIBRE ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
MDI-X: Unknown
Supports Wake-on: g
Wake-on: d
Link detected: yes
nvidia@ubuntu:~$
And here are the results from JetPack-4.6.3
nvidia@nvidia-desktop:~$ ip -s addr
73154 1119 0 0 0 0
73154 1119 0 0 0 0
link/ether 86:2e:ae:7b:ec:6a brd ff:ff:ff:ff:ff:ff
0 0 0 0 0 0
0 0 0 0 0 0
inet 192.168.2.129/24 brd 192.168.2.255 scope global dynamic noprefixroute eth0
valid_lft 3431sec preferred_lft 3431sec
inet6 fe80::b40:df2f:ed66:a3ad/64 scope link noprefixroute
2026381 2564 0 0 0 0
90210 1152 0 0 0 0
link/ether 9a:be:57:71:1f:99 brd ff:ff:ff:ff:ff:ff
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
link/ether 9a:be:57:71:1f:9b brd ff:ff:ff:ff:ff:ff
0 0 0 0 0 0
0 0 0 0 0 0
7: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:52:a0:0f:65 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
0 0 0 0 0 0
0 0 0 0 0 0
nvidia@nvidia-desktop:~$ cat /proc/interrupts
CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
2: 0 0 0 0 0 0 0 0 GICv2 29 Level trusty
3: 57047 54554 40166 35783 48415 41343 53945 44121 GICv2 30 Level arch_timer
6: 13695 0 0 0 0 0 0 0 GICv2 208 Level hsp
7: 0 0 0 0 0 0 0 0 GICv2 202 Level arm-smmu global fault
8: 0 0 0 0 0 0 0 0 GICv2 203 Level arm-smmu global fault
9: 0 0 0 0 0 0 0 0 GICv2 264 Level arm-smmu global fault
10: 0 0 0 0 0 0 0 0 GICv2 265 Level arm-smmu global fault
11: 0 0 0 0 0 0 0 0 GICv2 272 Level arm-smmu global fault
12: 0 0 0 0 0 0 0 0 GICv2 273 Level arm-smmu global fault
13: 0 0 0 0 0 0 0 0 GICv2 368 Level tegra-p2u-intr
14: 0 0 0 0 0 0 0 0 GICv2 369 Level tegra-p2u-intr
15: 0 0 0 0 0 0 0 0 GICv2 370 Level tegra-p2u-intr
16: 0 0 0 0 0 0 0 0 GICv2 371 Level tegra-p2u-intr
17: 0 0 0 0 0 0 0 0 GICv2 372 Level tegra-p2u-intr
18: 0 0 0 0 0 0 0 0 GICv2 373 Level tegra-p2u-intr
19: 0 0 0 0 0 0 0 0 GICv2 374 Level tegra-p2u-intr
20: 0 0 0 0 0 0 0 0 GICv2 375 Level tegra-p2u-intr
21: 0 0 0 0 0 0 0 0 GICv2 376 Level tegra-p2u-intr
22: 0 0 0 0 0 0 0 0 GICv2 377 Level tegra-p2u-intr
23: 0 0 0 0 0 0 0 0 GICv2 253 Level tegra-p2u-intr
24: 0 0 0 0 0 0 0 0 GICv2 254 Level tegra-p2u-intr
25: 0 0 0 0 0 0 0 0 GICv2 378 Level tegra-p2u-intr
26: 0 0 0 0 0 0 0 0 GICv2 379 Level tegra-p2u-intr
27: 0 0 0 0 0 0 0 0 GICv2 380 Level tegra-p2u-intr
28: 0 0 0 0 0 0 0 0 GICv2 381 Level tegra-p2u-intr
29: 0 0 0 0 0 0 0 0 GICv2 382 Level tegra-p2u-intr
30: 0 0 0 0 0 0 0 0 GICv2 383 Level tegra-p2u-intr
31: 0 0 0 0 0 0 0 0 GICv2 235 Level tegra-p2u-intr
32: 0 0 0 0 0 0 0 0 GICv2 252 Level tegra-p2u-intr
33: 0 0 0 0 0 0 0 0 GICv2 104 Level tegra-pcie-intr
34: 0 0 0 0 0 0 0 0 GICv2 105 Level tegra-pcie-msi
35: 1 0 0 0 0 0 0 0 GICv2 77 Level tegra-pcie-intr, PCIe PME, aerdrv
36: 0 0 0 0 0 0 0 0 GICv2 78 Level tegra-pcie-msi
37: 0 0 0 0 0 0 0 0 GICv2 81 Level tegra-pcie-intr
38: 0 0 0 0 0 0 0 0 GICv2 82 Level tegra-pcie-msi
39: 0 0 0 0 0 0 0 0 GICv2 85 Level tegra-pcie-intr
40: 0 0 0 0 0 0 0 0 GICv2 86 Level tegra-pcie-msi
41: 1 0 0 0 0 0 0 0 GICv2 226 Level ether_qos.common_irq
43: 2415 0 0 0 0 0 0 0 GICv2 222 Level 2490000.ether_qos.rx0
44: 1154 0 0 0 0 0 0 0 GICv2 218 Level 2490000.ether_qos.tx0
51: 20 0 0 0 0 0 0 0 GICv2 144 Level 3100000.serial
54: 0 0 0 0 0 0 0 0 GICv2 152 Level combined_uart rx
55: 19824 0 0 0 0 0 0 0 GICv2 97 Level mmc0
56: 0 0 0 0 0 0 0 0 GICv2 94 Level mmc1
57: 0 0 0 0 0 0 0 0 GICv2 76 Level ufshcd
58: 0 0 0 0 0 0 0 0 GICv2 68 Level 3210000.spi
59: 0 0 0 0 0 0 0 0 GICv2 69 Level c260000.spi
60: 17 0 0 0 0 0 0 0 GICv2 57 Level 3160000.i2c
61: 295 0 0 0 0 0 0 0 GICv2 58 Level c240000.i2c
62: 0 0 0 0 0 0 0 0 GICv2 59 Level 3180000.i2c
63: 0 0 0 0 0 0 0 0 GICv2 60 Level 3190000.i2c
64: 0 0 0 0 0 0 0 0 GICv2 62 Level 31b0000.i2c
65: 4 0 0 0 0 0 0 0 GICv2 63 Level 31c0000.i2c
66: 513 0 0 0 0 0 0 0 GICv2 64 Level c250000.i2c
67: 0 0 0 0 0 0 0 0 GICv2 65 Level 31e0000.i2c
70: 550 0 0 0 0 0 0 0 GICv2 193 Level snd_hda_tegra
71: 0 0 0 0 0 0 0 0 GICv2 51 Level bc00000.rtcpu
72: 128 0 0 0 0 0 0 0 GICv2 242 Level d230000.actmon
73: 52613 0 0 0 0 0 0 0 GICv2 297 Level host_syncpt
74: 2 0 0 0 0 0 0 0 GICv2 295 Level host_status
75: 0 0 0 0 0 0 0 0 GICv2 238 Level vic
76: 0 0 0 0 0 0 0 0 GICv2 268 Level nvdla0
77: 0 0 0 0 0 0 0 0 GICv2 269 Level nvdla1
78: 33090 0 0 0 0 0 0 0 GICv2 185 Level 15200000.nvdisplay
79: 0 0 0 0 0 0 0 0 GICv2 186 Level 15210000.nvdisplay
80: 0 0 0 0 0 0 0 0 GICv2 187 Level 15220000.nvdisplay
81: 0 0 0 0 0 0 0 0 GICv2 191 Level tegra_dp
82: 0 0 0 0 0 0 0 0 GICv2 192 Level tegra_dp
85: 4 0 0 0 0 0 0 0 GICv2 194 Level cec_irq
87: 0 0 0 0 0 0 0 0 GICv2 266 Level pva-isr
88: 0 0 0 0 0 0 0 0 GICv2 267 Level pva-isr
97: 0 0 0 0 0 0 0 0 GICv2 397 Level carmel-pmu
98: 0 0 0 0 0 0 0 0 GICv2 169 Level tegra-oc-event
99: 0 0 0 0 0 0 0 0 GICv2 270 Level noc_nonsecure_irq
100: 0 0 0 0 0 0 0 0 GICv2 271 Level noc_secure_irq
101: 0 0 0 0 0 0 0 0 PM 42 Level tegra_rtc
102: 0 0 0 0 0 0 0 0 GICv2 255 Level mc_status
104: 4 0 0 0 0 0 0 0 GICv2 165 Level c150000.tegra-hsp
115: 28 0 0 0 0 0 0 0 GICv2 214 Level b950000.tegra-hsp, b950000.tegra-hsp, b950000.tegra-hsp
119: 0 0 0 0 0 0 0 0 GICv2 315 Level 3ad0000.se_elp
121: 0 0 0 0 0 0 0 0 GICv2 108 Level gpcdma.0
122: 0 0 0 0 0 0 0 0 GICv2 109 Level gpcdma.1
123: 0 0 0 0 0 0 0 0 GICv2 110 Level gpcdma.2
124: 0 0 0 0 0 0 0 0 GICv2 111 Level gpcdma.3
125: 0 0 0 0 0 0 0 0 GICv2 112 Level gpcdma.4
126: 0 0 0 0 0 0 0 0 GICv2 113 Level gpcdma.5
127: 0 0 0 0 0 0 0 0 GICv2 114 Level gpcdma.6
128: 0 0 0 0 0 0 0 0 GICv2 115 Level gpcdma.7
129: 4 0 0 0 0 0 0 0 GICv2 116 Level gpcdma.8
130: 4 0 0 0 0 0 0 0 GICv2 117 Level gpcdma.9
131: 0 0 0 0 0 0 0 0 GICv2 118 Level gpcdma.10
132: 0 0 0 0 0 0 0 0 GICv2 119 Level gpcdma.11
133: 0 0 0 0 0 0 0 0 GICv2 120 Level gpcdma.12
134: 0 0 0 0 0 0 0 0 GICv2 121 Level gpcdma.13
135: 0 0 0 0 0 0 0 0 GICv2 122 Level gpcdma.14
136: 0 0 0 0 0 0 0 0 GICv2 123 Level gpcdma.15
137: 0 0 0 0 0 0 0 0 GICv2 124 Level gpcdma.16
138: 0 0 0 0 0 0 0 0 GICv2 125 Level gpcdma.17
139: 0 0 0 0 0 0 0 0 GICv2 126 Level gpcdma.18
140: 0 0 0 0 0 0 0 0 GICv2 127 Level gpcdma.19
141: 0 0 0 0 0 0 0 0 GICv2 128 Level gpcdma.20
142: 0 0 0 0 0 0 0 0 GICv2 129 Level gpcdma.21
143: 0 0 0 0 0 0 0 0 GICv2 130 Level gpcdma.22
144: 0 0 0 0 0 0 0 0 GICv2 131 Level gpcdma.23
145: 0 0 0 0 0 0 0 0 GICv2 132 Level gpcdma.24
146: 0 0 0 0 0 0 0 0 GICv2 133 Level gpcdma.25
147: 0 0 0 0 0 0 0 0 GICv2 134 Level gpcdma.26
148: 0 0 0 0 0 0 0 0 GICv2 135 Level gpcdma.27
149: 0 0 0 0 0 0 0 0 GICv2 136 Level gpcdma.28
150: 0 0 0 0 0 0 0 0 GICv2 137 Level gpcdma.29
151: 0 0 0 0 0 0 0 0 GICv2 138 Level gpcdma.30
249: 0 0 0 0 0 0 0 0 tegra-gpio 48 Edge force-recovery
253: 2 0 0 0 0 0 0 0 tegra-gpio 52 Level phy_interrupt
256: 0 0 0 0 0 0 0 0 tegra-gpio 55 Edge 3400000.sdhci cd
259: 0 0 0 0 0 0 0 0 tegra-gpio 58 Level tmp451
299: 1 0 0 0 0 0 0 0 tegra-gpio 98 Edge 15200000.nvdisplay
350: 1 0 0 0 0 0 0 0 tegra-gpio 149 Edge rt5659
393: 0 0 0 0 0 0 0 0 tegra-gpio 192 Edge bluetooth hostwake
439: 17 0 0 0 0 0 0 0 tegra-gpio-aon 10 Level ccg_irq
461: 0 0 0 0 0 0 0 0 tegra-gpio-aon 32 Edge ufs_cd_gpio
465: 0 0 0 0 0 0 0 0 tegra-gpio-aon 36 Edge power-key
469: 16 0 0 0 0 0 0 0 GICv2 39 Level 30c0000.watchdog
473: 0 0 0 0 0 0 0 0 GICv2 198 Level 3550000.xudc
474: 5956 0 0 0 0 0 0 0 PM 195 Level xhci-hcd:usb1
475: 3 0 0 0 0 0 0 0 PM 196 Level 3610000.xhci
476: 0 0 0 0 0 0 0 0 PM 199 Level 3610000.xhci
477: 8113 0 0 0 0 0 0 0 GICv2 102 Level gk20a_stall
478: 0 0 0 0 0 0 0 0 GICv2 103 Level gk20a_nonstall
479: 0 0 0 0 0 0 0 0 GICv2 424 Level ras-fhi
480: 0 0 0 0 0 0 0 0 GICv2 425 Level ras-fhi
481: 0 0 0 0 0 0 0 0 GICv2 426 Level ras-fhi
482: 0 0 0 0 0 0 0 0 GICv2 427 Level ras-fhi
483: 0 0 0 0 0 0 0 0 GICv2 428 Level ras-fhi
484: 0 0 0 0 0 0 0 0 GICv2 429 Level ras-fhi
485: 0 0 0 0 0 0 0 0 GICv2 430 Level ras-fhi
486: 0 0 0 0 0 0 0 0 GICv2 431 Level ras-fhi
487: 0 0 0 0 0 0 0 0 GICv2 262 Level noc_nonsecure_irq
488: 0 0 0 0 0 0 0 0 GICv2 263 Level noc_secure_irq
489: 0 0 0 0 0 0 0 0 GICv2 292 Level noc_nonsecure_irq
490: 0 0 0 0 0 0 0 0 GICv2 204 Level noc_secure_irq
491: 0 0 0 0 0 0 0 0 GICv2 294 Level noc_nonsecure_irq
492: 0 0 0 0 0 0 0 0 GICv2 206 Level noc_secure_irq
493: 0 0 0 0 0 0 0 0 GICv2 291 Level noc_nonsecure_irq
494: 0 0 0 0 0 0 0 0 GICv2 207 Level noc_secure_irq
495: 0 0 0 0 0 0 0 0 GICv2 293 Level noc_nonsecure_irq
496: 0 0 0 0 0 0 0 0 GICv2 205 Level noc_secure_irq
498: 0 0 0 0 0 0 0 0 PM 241 Edge max77620-top
502: 0 0 0 0 0 0 0 0 max77620-top 3 Edge max77620-gpio
503: 0 0 0 0 0 0 0 0 max77620-top 4 Edge max77686-rtc
507: 0 0 0 0 0 0 0 0 max77620-top 8 Edge max77620-thermal
508: 0 0 0 0 0 0 0 0 max77620-top 9 Edge max77620-thermal
531: 115 0 0 0 0 0 0 0 agic-controller 32 Level
532: 54 0 0 0 0 0 0 0 agic-controller 33 Level
563: 0 0 0 0 0 0 0 0 max77686-rtc 1 Edge rtc-alarm1
565: 0 0 0 0 0 0 0 0 PCI-MSI 0 Edge ahci[0001:01:00.0]
821: 0 0 0 0 0 0 0 0 PM 211 Level sw-wake
IPI0: 60335 54468 36610 36467 36256 30236 104076 80932 Rescheduling interrupts
IPI1: 531 575 2230 2457 2503 4337 2362 2346 Function call interrupts
IPI2: 0 0 0 0 0 0 0 0 CPU stop interrupts
IPI3: 0 0 0 0 0 0 0 0 Timer broadcast interrupts
IPI4: 0 0 2 2 0 1 0 1 IRQ work interrupts
IPI5: 0 0 0 0 0 0 0 0 CPU wake-up interrupts
Err: 0
nvidia@nvidia-desktop:~$ hwinfo --network
14: None 00.0: 10701 Ethernet
Driver: "dummy"
Device File: dummy0
HW Address: 86:2e:ae:7b:ec:6a
Unique ID: 7iXG.ndpeucax6V1
SysFS ID: /class/net/docker0
Driver: "bridge"
Device File: docker0
HW Address: 02:42:52:a0:0f:65
Link detected: no
16: None 00.0: 1070c USB-Link
SysFS Device Link: /devices/3550000.xudc/gadget
Driver: "g_ether"
Device File: usb0
HW Address: 9a:be:57:71:1f:9b
Link detected: no
17: None 00.0: 10700 Loopback
Device File: lo
Link detected: yes
18: None 00.0: 10701 Ethernet
Driver: "g_ether"
Device File: rndis0
HW Address: 9a:be:57:71:1f:99
Link detected: no
19: None 00.0: 10701 Ethernet
Parent ID: +jd0.nuQvqdpV7ND
SysFS Device Link: /devices/2490000.ether_qos
Driver: "eqos"
Device File: eth0
Link detected: yes
20: None 00.0: 10701 Ethernet
Driver: "bridge"
Device File: l4tbr0
Link detected: no
nvidia@nvidia-desktop:~$ sudo ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Advertised pause frame use: Symmetric Receive-only
1000baseT/Full
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Supports Wake-on: g
Wake-on: d
Link detected: yes
Thanks again
