AGX Xavier Dev Kit Powered by 19V and 5A
I have a AGX Xavier Dev Kit,Can I power my Jetson AGX Xavier through its Jack connector in 19 V and 5A ?
Yes. Max is 19.6V. Do note that the regulation quality must be good or it will shut off at times under load even if the supply is rated at 5A.
thank you for you reply!
